8.2.4 "Evidence of conformity with the acceptance criteria shall be maintained."
Douglas E. Purdy
#11
May be - May be not!
TBR01 said:
That makes sense, thanks.
Maybe I'm making a mountain of paperwork where there only needs to be a molehill. We do have records of the person doing final inspection and product release, but we don't keep records of in-process inspections, and I'd rather not start now.
Tim
Tim,
If your planned arrangements are to only verify that product requirements have been met at Final Inspection, then you do not have to generate in-process inspection records. But if your planned arrangements are to verify product requirements at other appropriate stages, then you would need that 'Evidence of Conformity' and 'Records shall indicate the person(s) authorizing release of product.'
Fuzzy,
Thanks for catching my error - the definitions are in 9000 and not 9001. In your situation, did you plan for In-process Inspection and not have the 'Evidence of Conformity' and 'Records'?
Additional Question
If in the planned arrangements, you are requiring some certification(s) from your supplier (e.g. Material Certification, Certificate of Conformance, etc.), are you required to have those certifications in hand before you release the product or deliver your service per 8.2.4.?
Doug
F
fuzzy
#12
Scary Mind-Reading
Fuzzy,
Additional Question
Doug[/QUOTE]
Doug,
Do you work here with me? How could you be in IL? :D Your two questions bore to the heart of some issues our QMS has. My 20+ years in automotive supply color my thinking within my current industrial commodity / technical government project enterprise. The documentation of in-process inspections was/ is not a fully established system in my view (I like to call them "practices"). So in the absence of well defined criteria, training, and records, we have adapted more general assessments of conformance. These seem to have served the purpose of compliance, but may not have added value ultimately. Trying to apply a Contol Plan methodology to our product has recently driven this home.
If your additional question was posed to me, I am scared as I know someone :ca: who has recently been assigned to get a system in place for QA control of Receiving Inspection and the very issue you posed. Does the Forum allow a viewport into my PC????:mg:
V
vanputten
#13
Inprocess inspections may be a tool to understand the process, or at least the output of a process. There may be no reason to use them to monitor inspectors, technicians, or operators. You could use them to monitor maintenance, engineering, design, etc. It may be a tool to improve a process.
I would say that you are required to have supplier certifications in hand before you release the product. Otherwise, what is the point? To have them after you release product? Closing the barn door after the horse is gone? Why ask for them at all?
Seems like there is some unnecessary risk in releasing product without the defined verification in hand, which in this case is the supplier cert.
Regards, Dirk
Douglas E. Purdy
#14
Regards, Dirk
Dirk,
I am in agreement with you, but I am in a QC culture that is fragmented. Why does an inspector who is performing Final Inspection having to go verify that the material certifications from the steel and carbide are retained? If we really did hold up the material until the certs were received, then we must have the certs available for when we release the finished product.
Doug
Douglas E. Purdy
#15
Re: 8.2.4 & Product Release
Based on the definition of 'release' (3.6.13 - ISO 9001) "permission to proceed to the next stage of a process" - what or who determines the next stage? Case in point, a manufacturing route identifies the sequence of operations and the practice is that as long as the operations are in a given work-center the product can move from one operation to another in that work-center without having the previous operation complete or signed-off on the manufacturing route. Is the 8.2.4 requirement being met if this situation is deemed acceptable during the monitoring and measurement, or could a registration auditor say we are not in compliance with the standard?
Another question on this subject: Is the second paragraph with the requirement "Records shall indicate the person(s) authorizing release of product" relating to the same product release in the third paragraph "Product release and service delivery shall not proceed until the planned arrangements (see 7.1) have been satisfactorilly completed"? Or is the standard informally identifying In-Process Inspection in the second paragraph and Final Inspection in the third paragraph?
I look forward to any feedback on this matter.
Thanks,
Doug
PREFACE
A little over 2 years later and in a QMS registered to ISO / TS-16949 (A Control Plan Environment) and I still do not have a definite answer to my questions above. Currently I have an issue with Management on the subject and they believe that it is only my interpretation - since our registrar has never issued a finding.
The finding was where a partial lot of product waiting Verification of Purchased Product per Control Plan is released to Finished Goods and to Shipping where a Dock Audit is performed. Both the Receiving of Plated Product and the Dock Audit are on the Control Plan. The Dock Audit is basically a visual (similar to the Receiving Inspection which also reviews the Supplier Certification to the PO requirements) along with checking the packaging and labeling requirements, but at a lesser sampling size.
The current employer has a procedure for "Urgent Release" but has only practiced it in reqards to receiving raw material (coils of metal strips). The following requirement comes from a procedure for Inspection & Test Status:
2.5 In all cases, product may not be moved to the next operation without the proper inspection approval unless Urgent Release processes have been properly followed. Employees at each operation are responsible for ensuring that the means of identifying approval is clearly marked on the product before it is used.
This procedural requirement is contradictory. The first statement would be in-line with the control plan, while the second sentence just ensures the status without necessarily having the inspections completed (i.e., Last Piece).
I wrote the finding against 8.2.4 and their Inspection & Test Status procedure. Management does not agree with the finding. What should I do?
Thanks,
Doug
V
vandenbar
#16
Doug,
If I interpreted your post correctly it sounds like you have a different understanding of the wording in a procedure then the management group. Why not propose changing the wording in the procedure that would clarify it for you and remove any misinterpretation? Sell it under the premiss that if you find it confusing or open for question then an external auditor might or even worse an operator. You could remove the finding to smooth out the situation or capture it as a PAR. If it gets clarified then either way you've accomplished the final objective and improved the system.
My two cents,
Douglas E. Purdy
#17
Doug,
My two cents,
Thanks for your feedback, I definitely was heading in that direction - to clarify the Inspection & Test Status requirement. But I have to get management to understand the requirement first - which is centered on the questions posted in 2005:
What is the proper understanding of the second and third paragraph of 8.2.4, and what am I to do with Management who believes that this is just my interpretation, when the registrar has never given them a finding in this matter?
Just to clarify my understanding, I believe that the 8.2.4 requirement is saying what the first sentence in the Inspection & Test Status procedure states:
I was not here when this procedure was written, so I am not the only one who believes that this is what 8.2.4 is requiring.
Thanks,
Doug
V
vandenbar
#18
Doug,
You've got some good questions. IMO or my interpretation of the standard (referring to 8.2.4) I believe that the second paragraph is referring to all points in your process where the acceptance criteria is checked. This could be inprocess inspection, receiving inspection, final inspection, reviewing performance test data or CofA's, etc. Anywhere in your process where someone checks the product/service to see if it is meeting the requirements set out by your company or your customer.
The third paragraph states product release and service delivery - this seems to suggest the end of the process and delivery to the customer but you can release product from receiving to storage or production or from one operation to the next so it is also applicable to your entire process.
You need to ask yourself what the intent of this requirment is. I would say it is to:
1. Check to see if your product meets the requirements where and when you already determined it to be important in your process (appropriate stages).
2. When you check it, document that you did and know who did it. Also make sure that who did is allowed to do it.
3. Don't move it to the next step until it passes all the requirements you've set for it, unless someone with the authority says you can go ahead - typically the cusotmer or someone with the guts to put their name on a waiver. At this point the "Urgent release" process comes into play.
That's what I think anyway.
Douglas E. Purdy
#19
vandenbar,
Nicely Stated! At least I do not feel like a complete incompetent. Now how do I convince Management that this is the requirement, when they have been operating this way for years?
You previously indicated:
How can I remove the finding and capture it as a PAR, when it is a known nonconformance?
Thanks,
Doug
CliffK
#20
PREFACE
Thanks,
Doug
Forget the finding unless you can show a demonstrable impact on quality. From everything that's been said so far, it seems that the management team supports the current document, they are managing successfully according to their interpretation of the document and the product quality is not adversely affected.
What happens if you push your CAR and "win?" Will there be a measurable improvement in product quality or a reduction in cost? If not, all the time spent arguing the point will have been wasted effort. In addition, you will probably succeed in alienating the management team against yourself and creating one of those "auditor made us do it" situations.
M ISO9001 - 8.2.4. - Evidence of conformity with the acceptance criteria ... maintained ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Monitoring and Measurement of Product - ISO 9001 - 8.2.4 "Evidence of Conformity" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
G Definition Evidence of Conformity - Interpretation of ISO 9001 Clause 8.2.4 (data - yes or no?) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
G Solderability - Objective Evidence of Conformity to Standards - J-STD-610 Manufacturing and Related Processes 1
C How to Provide Evidence of Product Conformity during Manufacture? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Evidence of Product Conformity IATF 16949 - Automotive Quality Systems Standard 1
Douglas E. Purdy Inspection & Test System - Evidence of conformity but no actual measurements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
A 8.6 Release of products and services, 8.3 Design and development - evidence required ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Where to draw the line for "sufficient evidence" to verify safety/performance of a device? CE Marking (Conformité Européene) / CB Scheme 2
D Device functionality over service life - Objective evidence required? Design and Development of Products and Processes 10
C MDCG 2020-06 Clinical evidence legacy devices EU Medical Device Regulations 3
Mr Roo ISO 9001 - 7.1.3 Infrastructure - questions concerning evidence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
M Informational Critical Thinking and the Process of Evidence-Based Practice Medical Device and FDA Regulations and Standards News 0
M Informational How to perform a clinical evaluation of medical devices – Part 2 – Level of clinical evidence and what sufficient clinical evidence means Medical Device and FDA Regulations and Standards News 9
M Informational US FDA paper – Epidemiological Evidence on the Adverse Health Effects Reports in Relation to Mercury from Dental Amalgam: Systematic Literature Review Medical Device and FDA Regulations and Standards News 0
S Level of Clinical Evidence - MDR EU Medical Device Regulations 3
qualprod Evidence of a talk or phone call in approvals? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
H Clinical evidence for Class II medical devices in EU and US EU Medical Device Regulations 6
CPhelan Using clinical trial safety data for evidence for CE marking EU Medical Device Regulations 8
N Best practices for capturing audit objective evidence in a practical manner? Internal Auditing 3
M Informational Health Canada – Guidance Document: Supporting Evidence for Implantable Medical Devices Manufactured by 3D Printing Medical Device and FDA Regulations and Standards News 0
R Timeframe for IATF 16949 certification to accumulate evidence of conformance of systems? IATF 16949 - Automotive Quality Systems Standard 2
M Informational TGA – Q&A: Use of market authorisation evidence from comparable overseas regulatory bodies for medical devices Medical Device and FDA Regulations and Standards News 0
E ISO 9001:2015 Clause 10.2.2 - Evidence of all nonconformities and actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R 8.1.3 Management of change - Evidence of HIRA and related things Occupational Health & Safety Management Standards 3
Q Evidence of precautions (clinical evaluation report, risk management report) EU Medical Device Regulations 6
S Ways to demonstrate objective evidence that employee is trained and competent ISO 13485:2016 - Medical Device Quality Management Systems 28
mikinnear Evidence - Class IIb Disinfectant Sanitiser EU Medical Device Regulations 2
G FAI Objective Evidence AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Interested parties requirements - Evidence of control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Is evidence of second party audits required for every supplier? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J MDR and Creative Clinical Evidence Other ISO and International Standards and European Regulations 2
B IATF 16949 Cl. 9.2.2.1 - Internal audit program - Types of evidence Internal Auditing 1
E IATF 16949 Cl. 7.1.5.1 - Documented information as evidence of fitness for purpose IATF 16949 - Automotive Quality Systems Standard 3
Q How to provide evidence of Strategic Direction (Easy) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B IATF 16949 Cl. 7.1.6 - Organizational Knowledge - What evidence to have? IATF 16949 - Automotive Quality Systems Standard 1
D No evidence of certain processes on our scope being audited at our remote location IATF 16949 - Automotive Quality Systems Standard 4
R CAPA Verification - ISO 13485:2016 Requirements and Objective Evidence ISO 13485:2016 - Medical Device Quality Management Systems 2
R What kind of Objective Evidence - AS9100 Cl. 7.1.6 - Organizational Knowledge AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q Informational Context of the Organization & Interested Parties Evidence - ISO 9001:2015 Cl. 4.1/4.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 82
O ISO 9001:2015 4.4.1 - Providing Evidence of QMS Processes "Shalls" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Type of evidence for Mandatory procedures 4.4.2 A ad 8.5.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Clinical Evidence - Clinical Evaluation Report for Class I medical devices EU Medical Device Regulations 1
L AIs the R&R study a training evidence considered ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R What objective evidence can/can't be supplied during a customer audit? General Auditing Discussions 3
W Evidence for Review of Requirements - AS9100 Clause 7.2.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Audit Ethics and Practices regarding Evidence Internal Auditing 18
S Evidence of Competence, Training and Awareness Training - Internal, External, Online and Distance Learning 5
S Design and Development Document evidence for Engineering Consultant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Chennaiite Audit Objective Evidence - the holy **** Imported Legacy Blogs 1
