8.3.2.1 Monitoring/Measurement Audit Finding
John B.
Registered Visitor
Any help is greatly appreciated.
During our last audit we could not produce any evidence of a feature called out on the CP was being measured.
An 8D has been started.
D3 (Interim Containment Action) - Correct Receiving Inspection Instructions to measure and record feature. Sample in house parts. If any are found to have this feature out of spec. Implement 100% inspection of all parts in house.
Question: How do i verify effectiveness of ICA? If no defects are found can I consider it verified?
Gratefully,
John
AndyN
Moved On
Gratefully,
John
No, you simply audit that the feature is being measured! End of story. You might want to see if other CPs are being followed closely - how did this get past your own internal audits? Does anyone do CP audits? Your root cause may also lie there!
John B.
Registered Visitor
Thanks AndyN.
What happened was that someone recently (between internal audits) made a change to the master CP without notifying anyone.
Our 5-why:
Why 1. Control Plan not followed
Why 2. Because nobody knew it changed
Why 3. No flow down of Control Plan to RII (Receiving Insp Instr)
Why 4. Control Plan modified outside of review process
Why 5. No requirement to review Control Plan accuracy to eng dwg and RII before release to floor
Root Cause: Unrestricted access to CP software
Comments/Thoughts?
Gratefully,
John
AndyN
Moved On
Thanks AndyN.
Our 5-why:
Comments/Thoughts?
Gratefully,
John
Surely the 5 Why's should be focused less on the CP and more on why someone changed the CP and followed the document control/CP change procedure and - it appears - no one knew?
Is this a deficiency of the change procedure? How do people become informed of CP changes? Didn't an alarm go off with someone?
I'm left wondering how your change control process works and if it should be beefed up or whether this individual plain just didn't follow it. I'm feeling like your own internal audit should do a deep dive on the story around this situation...
John B.
Registered Visitor
Thanks Andy.
The teams focus is initially on protecting the customer. Measuring and recording the missing feature.
Based on the root cause we are driving towards a PCA that addresses the change procedure.
We do not have a "Change Review Board". Honestly our system is a manual system consisting of "check sheets" and routers. Anyone with access can make a change without intiating the "check sheet" and router. The software does not require a new revision. You can type right over, delete or add anything to PFD, FMEA or CP.
Gratefully,
John
bpritts
Involved - Posts
I would reinforce Andy's comments - who changed the CP without then updating the appropriate inspection instruction? That seems to be the broken link.
In our company, the people updating the CP are the same ones accountable for developing the appropriate instructions. So the responsibility would be clear. Now, we're very small. So, if someone changes the CP in a bigger organization perhaps they should be responsible to advise the people creating and maintaining the inspection instructions, and doing the inspection -- to make sure that the CP "happens".
To verify the effectiveness, you might consider auditing several more CP's to verify that all of the specified inspections are included on inspection instructions, and being done. In particular, it might be good to check the most recently changed CP's to ensure that they were accurately implemented.
Verification of effectiveness is intended to focus on the root cause (broken link from CP - implementation) -- NOT the details of the inspection.
Hope this helps!
Brad
AndyN
Moved On
Thanks Andy.
Gratefully,
John
John, you don't need a review board. What's needed is a key mechanism in your document control procedure and some other basic controls. In fact, having a manual system makes it good to instil some discipline in people before making it electronic. I'd suggest that the key mechanism is a "Document Change Request/Note" and this is walked around the various functions who should sign off on changes. Make only one or two (admin) people responsible for implementing the change in the document etc.
E Any template/ form of Monitoring and Measurement of Processes and product to ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 1
I QMS monitoring, measurement, analysis and evaluation requirement - Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
O Monitoring performance - How do I determine performance measurement basis within my organization? Misc. Quality Assurance and Business Systems Related Topics 4
qualprod ISO 9001 Clause 9.1 - Monitoring measurement analysis and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 13485 8.2.5. Monitoring and measurement of quality management system processes ISO 13485:2016 - Medical Device Quality Management Systems 1
A Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
G IATF 9.1.1.1 Monitoring and Measurement of Manufacturing Processes IATF 16949 - Automotive Quality Systems Standard 13
G ISO 9001:2015 - Management Review 9.3.2 c) 5) - Monitoring and Measurement Results ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
armani Monitoring and Measurement Methods ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
H ISO 13485 - Monitoring and Measurement of Processes (Sections 8.2.5 / 8.2.6) ISO 13485:2016 - Medical Device Quality Management Systems 4
W MR Inputs (9.3.2) - "Monitoring and Measurement Results" vs. "Process Performance" Management Review Meetings and related Processes 15
E 8.2.3 Monitoring and measurement of processes - What is "Where applicable" IATF 16949 - Automotive Quality Systems Standard 20
M Quality Objectives and Monitoring & Measurement of Processes - Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D AS9100C Clause 8.2.4 Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
A FDA Blood Pressure Monitoring Equipment Measurement Requirements US Food and Drug Administration (FDA) 1
S ISO 9001:2008 Clause 8.2.3 Monitoring and Measurement of Processes Help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
H ISO 9001:2008 Clause 7.6 Control of Monitoring and Measurement (Computer Software) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W AS9100 Clause 8.2.3.C Monitoring and Measurement of Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
S Process Monitoring and Measurement - AS9100 Clause 8.2.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
I Hospital Product/Service Realization and Monitoring/Measurement (ISO 9001) Hospitals, Clinics & other Health Care Providers 4
E ISO 9001:2008 Clause 8.2.4 - Monitoring and Measurement of Product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
QMMike Color Measurement (Monitoring) during Processes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M TS 16949 Clause 8.2.4 Monitoring and Measurement of Product - Customer Scope? IATF 16949 - Automotive Quality Systems Standard 3
M 8.2.3 Monitoring & Measurement of Processes - Monitoring vs. Measurement IATF 16949 - Automotive Quality Systems Standard 10
G Monitoring and Measurement of Manufacturing Processes - TS 16949 Clause 8.2.3.1 IATF 16949 - Automotive Quality Systems Standard 2
M 8.2.4 Problems with Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Definition Significant Event definition - 8.2.3.1 - Monitoring & Measurement of MFG Processes Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
G 7.6 Control of Monitoring and Measuring Equipment vs. 7.6.1 Measurement Systems Analy IATF 16949 - Automotive Quality Systems Standard 15
L ISO/TS 16949 Cl 8.2.3.1 - Monitoring and Measurement of Manufacturing Processes IATF 16949 - Automotive Quality Systems Standard 3
B AS9100 Clause 8.2.3.C Monitoring and Measurement and 8.5.2 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
P Control of Monitoring and Measurement Devices - ISO 13485 Clause 7.6 says ... ISO 13485:2016 - Medical Device Quality Management Systems 3
R Control of Monitoring & Measurement Equipment - ISO 9001:2008, Clause 7.6 c) General Measurement Device and Calibration Topics 9
L Monitoring & Measurement of Product for Service Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Monitoring and Measurement of Product - ISO 9001 - 8.2.4 "Evidence of Conformity" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
A Monitoring and Measurement of Processes - ISO 9001 Service Industry Specific Topics 9
A Interpretation of 8.2.4 Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M "All threads Coated" - 8.2.4 Monitoring and Measurement of Product question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B Monitoring and Measurement of Product in a Shop Selling Frozen Meat ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G 4.5.1 Performance Measurement & Monitoring - relevant information and analysis? Occupational Health & Safety Management Standards 3
Q Which 'customer' in 8.2.4 Monitoring and Measurement of Product? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D How to differentiate between monitoring and measurement devices? General Measurement Device and Calibration Topics 23
A Explain the meaning of 8.2.4 Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
G Cl 8.2 Monitoring and measurement - articles & related reading material? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Monitoring and Measurement of Finished Goods with a Better Method IATF 16949 - Automotive Quality Systems Standard 2
A How to carry out 'Monitoring and measurement of processes' - Clause 8.2.3. Nonconformance and Corrective Action 12
M Maximum Permissible Error for Monitoring and Measurement Devices General Measurement Device and Calibration Topics 19
C Monitoring and measurement - 7.6 of ISO 13485 - Documented procedure required? ISO 13485:2016 - Medical Device Quality Management Systems 5
H How to understand "Monitoring the Process"? "Measurement" of the Process? IATF 16949 - Automotive Quality Systems Standard 14
A Including multimeters and network testers as monitoring and measurement devices ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Can I get clarification on performance measurement and monitoring for 18001? Various Other Specifications, Standards, and related Requirements 3
