Q
Hi all
I was browsing in Elsmar looking an answer for my problem, I focused in cases in 2008, but I'm not convinced. I'm reviving an old issue which has caused lot of opinions. In fact I noticed that very different points of view came out from the users.
Some users considered a product, only when is completely finished, however some others consider a product everything which is used through all the process, to get the final product and in every step (raw material, components, parts, etc).
Definition, Product=?result of a set of interrelated or interacting atilvities which transforms inputs into outputs?.
I'd like to share my case, (similar to old threads)awaiting for your valuable comments, maybe the answers today may be different.
I'll explain.
In my case, I have a print shop. When I produce manuals, in production, there are some sub-processes acting, first, Printing, then cutting, folding, punching, counting, and finally the manual is finished.
Do I have to control the product (8.3) only at the end or in all the sub processes? , suppose that at the middle of the process, I have a raw material problem (dirty paper), how to consider this?, if it's material, just paper, is not the final product required by the client.
Should I have to apply 8.3?, raising an NCR, then, segregating the material, applying a disposition and so on?. or should I have to raise only a NCR but not applying disposition?
Applying 8.3, raising ncr's in every sub process is very time consuming, really I'm not sure how to handle this issue.
Can someone share experiencies regarding how to manage the nonconformities in a Print Shop?
Thanks to all for your help
I'll explain.
