8.5.1.1 Control of Equipment, Tools, and Software Programs - Questions about the extent of control of NC programs
CanadianQA
Hi Everyone,
My company is AS9100 certified. Part of our operation is a small machine shop. I have questions about what software needs to be controlled and validated, to what extent and what constitutes validation of NC programs that are input into our 5 axis CNC milling machine.
As far as I understand, the machinist either gets a CAD or Inventor drawing and re-draws the part as a feature cam file. Alternately, he will get a STEP file that is then translated into a feature cam file. The feature cam file is what is actually fed into the machine to control the machining process. According to the production team, the machinist will make tweaks to the feature cam file. This will include feed rates, different cutters, cutter path, etc... The end result is the same, it just takes a bit of time to get the file set up so that it makes the part in the most efficient way.
Ok, so now for the questions:
1. How much and what type of control is required for STEP or feature cam files? Should the machinist be tweaking these files as he goes?
2. What constitutes verification of these files? Up until now, we have been using the inspection of the product to verify the output of the software. If the product passes inspection, then the file is verified. What records should we be keeping to show evidence of verification of these feature cam files?
3. Does the feature cam file need to be re-verified every time that the machinist makes a tweak?
Any thoughts would be appreciated. Thank you.
Kronos147
One way to validate the program is to have the first part inspected.
It gets more complex if you desire to have each operation verified. In this case, there needs to be agreement as to what was established in each op (what should be inspected). If you leave a feature 'big' as it will get 'smaller' in another operation, is an example of this scenario. Our shop, we also realize at times things are slightly lower than spec, to allow for paint. We put those requirements in the work order\traveler.
In terms of the file control, that's a tough one to advise. What do you do now? How effective is it?
Recently, we had a machinist make something bigger because he 'thought' there was another process that made it smaller later. We do, but on a like part, not on that one. We had to remind him to check the traveler.
It was discovered during the first piece inspection, so, the program was 'unmodified' and run again with a new setup piece. Then, another inspection.
CanadianQA
Yes, we do "First Off" inspections that validate the program changes, however they are not recorded anywhere. This is somewhat part of the art of machining. I don't see that AS9100 requires that we record this... At this point we have no requirement to control the machining process down to each machining operation.
What we currently have in place is that our engineering dept. controls and verifies our STEP / CAD / Inventor files. These files are then passed to the machinist who then creates the feature cam file based on the file from engineering. CAD / Inventor files are usually just very simple parts. The machinist will manually "draw" the part in feature cam. STEP files are for the more complex parts and the feature cam program just takes the file, does it's magic and converts it. The machinist keeps these files on our server marked with the part number of the part and revision level of the drawing so that it can be used again for the same drawing rev. This has been the way the system has worked for the last 10 years and we have had no issues that I am aware of.
CanadianQA
It is EXPLICITLY required in 8.5.1.3 - The organization shall retain documented information on the results of production process verification. Could not be clearer.
Yes, agreed. Sorry, my last comment was specific to validating changes to the feature cam files, not the production process as a whole. These files can be changed several times during one production run until the best balance of quality / cost is obtained, so it seems that it is not practical to keep records of validation of each change.
Big Jim
Perhaps it is time to talk about the difference between verification and validation. Verification records are required. Does that include validation records? Maybe it is not so clear.
L Control of Production Equipment, Tools and NC Programs: 7.5.1.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A Control of Production Equipment,Tools and Numerical Control (N.C.) Machine Programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D Infrastructure: Equipment, Work Environment and Contamination Control ISO 13485:2016 - Medical Device Quality Management Systems 4
E ISO 13485 7.6 Control of monitoring and measuring equipment - Assess the Validity ISO 13485:2016 - Medical Device Quality Management Systems 4
M FDA News USFDA Draft Guidance – Clarification of Radiation Control Regulations for Manufacturers of Diagnostic X-Ray Equipment Medical Device and FDA Regulations and Standards News 0
P Do we need equipment stock control for security company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Can Scope of Equipment Control be Tied to Risk? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A ISO 9001 Control of Production Equipment - CNC Machines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Control of R&D (Research and Development) Parts and Equipment ISO 13485:2016 - Medical Device Quality Management Systems 3
A Calibration Interval - AS9100 - Control of Monitoring and Measuring Equipment Calibration Frequency (Interval) 8
D Does 7.6 Control of Monitoring and Measuring Equipment align with ISO 17025 ISO 17025 related Discussions 4
G Control of Monitoring and Measuring Equipment for Servicing Photocopiers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Control of equipment instruction manuals ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
S ISO9001 Exclusion 7.6 Control of Monitoring and Measuring Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
H Measurement System in Control if the Equipment requires Daily Calibration? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Control of the Content in the Master Calibration Equipment form Document Control Systems, Procedures, Forms and Templates 2
M 7.6 Control of Monitoring and Measuring Equipment - Monitoring vs. Measuring IATF 16949 - Automotive Quality Systems Standard 2
G 7.6 Control of Monitoring and Measuring Equipment vs. 7.6.1 Measurement Systems Analy IATF 16949 - Automotive Quality Systems Standard 15
T Control of Production Equipment - Seventh Procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Medical Diagnostic Equipment Control Computer Repair Other US Medical Device Regulations 3
D MSA Requirements for Equipment Referenced on Control Plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
QMMike Control of Measurement Equipment on your Shop Floor Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
Q MSA Studies on each Equipment, each Measurement System or Family in Control Plan? IATF 16949 - Automotive Quality Systems Standard 35
R Control of Monitoring & Measurement Equipment - ISO 9001:2008, Clause 7.6 c) General Measurement Device and Calibration Topics 9
A Equipment List - Control or not to Control (Controlled Documents) Document Control Systems, Procedures, Forms and Templates 8
C Control of Equipment Manuals - ISO 17025 Clause 4.3.1 ISO 17025 related Discussions 6
N Control of Measuring and test Equipment - Flowchart wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Equipment Parameters in Control Plan? IATF 16949 - Automotive Quality Systems Standard 4
D Control of monitoring and measuring equipment - infrared thermometer for cross-check ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
W Computer Software - ISO 9001 Clause 7.6 Control of Monitoring and Measuring equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Difference between control & audit - Cleaning manufacturing equipment Internal Auditing 5
hogheavenfarm Extending control of measuring equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Control of Equipment General Measurement Device and Calibration Topics 1
E Control Charts for OEE (Overall Equipment Efficiency) Statistical Analysis Tools, Techniques and SPC 19
Q Proprietary Information and Control Plans - Equipment, Materials, Specifications FMEA and Control Plans 3
R Control plans for attribute hydraulic/electronic test equipment FMEA and Control Plans 1
M 4.11 Control of Inspection Measurement and Test Equipment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Prototype control plan FMEA and Control Plans 2
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
W FMEA - Current control and occurrence rating FMEA and Control Plans 3
S Which department should prepare the control plan? could you show me a standard regarding to this matter. APQP and PPAP 16
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
N What are the software audit and control steps Reliability Analysis - Predictions, Testing and Standards 2
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Monitoring and Control Instruments RoHS, REACH, ELV, IMDS and Restricted Substances 3
M ISO14971:2019 - Verification of implementation and effectiveness of risk control ISO 14971 - Medical Device Risk Management 3
T Risks arising from control measures vs. ineffective control measures ISO 14971 - Medical Device Risk Management 11
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
P IQ, OQ, PQ protocol, and report templates for Distributed Control Systems in Pharmaceutical Manufacturing Systems. Qualification and Validation (including 21 CFR Part 11) 0
