8.7 Control of Nonconforming Outputs
Rocket27
Good morning! Any help on the below issues is greatly appreciated.
2 concerns:
1. Regarding 8.7 of the Standard, there is some back and forth discussion at my company that when an NCR is dispositioned as re-work, that there must be some form of step-by-step rework instructions and that Engineering should be documenting the rework instructions onto the NCR, with an instruction sheet.
The other side of the discussion is that to be compliant with the standard, all that needs to be inputted onto the NCR is:
The disposition of rework & a comment describing the rework to be done, (ex: “holes to be opened up within tolerance and rework will be performed IAW new job order/traveler generated.”). **To note, all dispositions are made by MRB authority.
Will this be enough or is a step-by-step rework instruction needed?
2. In 8.7.2 b: “describes the action taken;” There is no field on our NCR form for describing the action taken, there is just disposition (checked off) & rework instructions (*f necessary). With those two fields on the form, will that be sufficient enough to comply or does ‘action taken’ need be added onto the form?
To note, the form is generated IAW our non-conforming procedure that specifies each disposition. So, let’s say the disposition was Use as Is, the operator would be working IAW with our procedure that has a statement along the lines of:
“Use as Is (UAI): (Definition here). When parts are dispositioned UAI, the NCR will be updated to reflect the disposition status and closed. A copy of the NCR is to be moved with the parts. Parts can be returned to general inspection area and processed IAW Inspection Procedure XXX.. will this do or is "action taken" a must on the form?
Thank you!!!
Mike S.
Happy to be Alive
On item 1, IMO there is no AS requirement for "step-by-step rework instructions" unless your company considers them necessary for the rework to be done properly.
On item 2, IMO actions taken may be (as needed/appropriate to the situation) containment, disposition, corrective actions, contacting the customer, etc.
Rocket27
Thank you!
Z AS9100 Control of Nonconforming Outputs - Rework Dispositions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
S ISO 9001:2015 Clause 8.7 Control of Nonconforming Outputs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
J AS9100 Cl. 8.7 - Control of Nonconforming Outputs - Counterfeit Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Control of Nonconforming Material AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
Sravan Manchikanti How to interpret '8.3 Control of nonconforming product' for SaMD device while implementing ISO 13485 & MDSAP ISO 13485:2016 - Medical Device Quality Management Systems 7
J Control of nonconforming product issue (AS91000) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Control of Nonconforming Product Output (Components Parts) IATF 16949 - Automotive Quality Systems Standard 3
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
L Containment and Control of Nonconforming Product(s) IATF 16949 - Automotive Quality Systems Standard 3
T Quarantine Zone - Control of Nonconforming Product Manufacturing and Related Processes 17
D Control of Nonconforming product (5.10 API Q1) Oil and Gas Industry Standards and Regulations 3
Q Do cut-in ECOs trigger "control of nonconforming product" procedure? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P ISO9001 in Quality Control Department - Control of Nonconforming Product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
somashekar Can Process Deviation be handled under control of Nonconforming Product? ISO 13485:2016 - Medical Device Quality Management Systems 2
F Nonconforming Product Procedure vs. Control of Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M 8.3 Control of Nonconforming Product - Request for clarification IATF 16949 - Automotive Quality Systems Standard 10
M How to Control Nonconforming Product? TS 16949 Clause 8.3 IATF 16949 - Automotive Quality Systems Standard 2
N Boundary of Clause 8.3 - Control of Nonconforming Product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
Q AS9100 Clause 8.3 - Control of Nonconforming Product Process for Approving Personnel AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J Procedure for Control of Nonconforming Materials and Products - Example wanted Nonconformance and Corrective Action 6
N Nonconforming Material (NCM) Control in very Small Manufacturing Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P Control of Nonconforming Products - AS91000 Clause 8.3 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S AS9100 Clause 8.3 - Control of Nonconforming Product Q AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
Q AS9100 Clause 8.3 Control of Nonconforming Product - Clarification wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
N Control of Nonconforming Product in a Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Documented Procedure for Control of Nonconforming Product - Electricity Generation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Excluding Control of Nonconforming Product? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Nonconforming Material Control - Gap in the Control of Non-Conforming Materials 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
L Control of Nonconforming Product in a Tool Shop - Scrap Dies Nonconformance and Corrective Action 5
R ISO 17025 section 4.9 - Control of Nonconforming Testing and Calibration Work ISO 17025 related Discussions 6
L AS9100 8.3 Control of Nonconforming Product - Responsibilities AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
E Medical Device Software - Control of Nonconforming Product and Rework ISO 13485:2016 - Medical Device Quality Management Systems 4
D Control of nonconforming services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D 8.3 Control of nonconforming product Nonconformance and Corrective Action 5
K Procedure for Control of Nonconforming Software Services Document Control Systems, Procedures, Forms and Templates 3
K Scrap Material Areas - How to control nonconforming material ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R Control of Nonconforming Product - Customer and/or Regulatory Approval ISO 13485:2016 - Medical Device Quality Management Systems 4
F Control of Nonconforming Items In Lean Environment Lean in Manufacturing and Service Industries 10
S Defect Control Record - How to track nonconforming product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Nonconforming Services - Procedure for Control of Non Conforming Products Document Control Systems, Procedures, Forms and Templates 14
A Positive Control of in-process nonconforming parts until rendered physically unusable Nonconformance and Corrective Action 3
T Control Of Nonconforming Material / Product - Feedback on my Procedure Please Document Control Systems, Procedures, Forms and Templates 10
S Control of Nonconforming Product - Seeking Information and Example Procedure Document Control Systems, Procedures, Forms and Templates 6
Douglas E. Purdy Sampling Plans & Control of Nonconforming Product Inspection, Prints (Drawings), Testing, Sampling and Related Topics 21
M Control of Nonconforming product, Clause 8.3 - Audit finding - No Procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
K How would one draw a turtle diagram for 'Control of nonconforming products' Process Maps, Process Mapping and Turtle Diagrams 2
K Define control of nonconforming service in public service such as government Service Industry Specific Topics 7
Douglas E. Purdy How AQL Inspection & Test corresponds to Control of Nonconforming Product AQL - Acceptable Quality Level 11
M Control of nonconforming product - Software Company - ISO 9001, Clause 8.3 Nonconformance and Corrective Action 9
Douglas E. Purdy 4.9 Control of Nonconforming Testing - Work General Measurement Device and Calibration Topics 4
