820.75 Process Validation including Suppliers
I
Ironcountry
I would like to know about medical device OEM's and suppliers recent experiences when audited by the FDA, specifically validations. For example, what FDA's stance is when a process is not validated? Does the presence of a comprehensive plan make a difference??
I share your interest in hearing stories of recent encounters with the FDA. I can tell you that a major OEM was here this week to help qualify (audit) us to build a more complex device, in a higher FDA Class, then the components we've been supplying them for years...
I give them credit... they were thorough, and seemed to agree amongst themselves of what it takes to get these process validations and equipment qualifications up to where they should be...
I gave Elsmar Cove credit during a post-audit debrief meeting we had yesterday; none of their observations were new to me, and really what I heard from them was consistent with the consensus opinions which develop over some of the threads here...
A "comprehensive plan" is very important; it should be through and specifically include processses which are planned for verification as opposed to validation, as well as present a program of formal monitoring and re-validation...
Statistical rationale is a hot topic as well, for sample sizing, as well as confidence levels of any conclusions drawn through capability studies... you've got to be covered as to justifying your inputs as well as justifying conclusions drawn from your outputs...
Following admonitions to include considerations of risk in designing these verifications & validations, a relatively simple approach of using the highest severity seemed to be received well... also, I really tried to follow the process validation guidance document (GHTF) closely point-to-point to ensure protocols were planned well enough... this was seemingly sufficient...
The question I came away with is: having never met FDA, are they typically expected to be exacting above and beyond the requirements of a big Customer? I feel like we got a pretty good workout this week, and hopefully we'll be in good shape in case FDA ever does drop in!
I
Ironcountry
My company recently sent engineers for validation training conducted by AAMI, from what they said about half of the audience were FDA inspectors. To answer your question regarding whether they would go above and beyond a big customer, I would say expect them to. Not all "big customers" are the same, I have heard some OEMs are extremely thorough while others are less so. I would expect in these times, the FDA would be very thorough.
Statistical Steven
Statistician
Can anyone else provide input?
Not sure I understand the question fully but let me share some experiences with you. The GHTF document section 3.1 has the flow diagram for the decision to validate or verify a process. Section 3.2 gives examples of processes expected to be validated and those that are special processes that do not require validation but should have verification and a control plan.
If you have a process that should be validated but is not currently validated, having a gap analysis with a plan is sufficient provided the plan is reasonable to the FDA auditors satisfaction.
Now to your initial question, if you have not addressed validation in your QMS you will usually see a minimum of a 483 and most likely a warning letter. Validation is critical and a simple search of the FDA Warning Letter database can show you the extent to which the agency requires validation.
Does that help?
MIREGMGR
I'm not quite sure where the question goes. FDA's expectations are pretty well documented in 21CFR 820 and the other rules and in their guidances. As noted, the Warning Letter history is very informative. The QSIT guide provides an exact list of the inspector's questions for a basic surveillance audit.
In my experience, their audits aren't qualitative, with the inspector just deciding that your system is "good enough". Rather, they want a range of technical and managerial systems in place and objectively operating, and either you have them or you don't.
Ronen E
Problem Solver
Moderator
I second the last 2 posts above.
Published warning letters from recent months show that process validation is a hot topic -- almost all companies cited for part 820 violations are found to have inadequate process validation(s), to some extent.
If you conduct a systematic review of such warning letters during, say, the last 12 months, I'm sure you can gain some useful insights re. FDA inspectors expectations in that regard.
Cheers,
Ronen.
MIREGMGR
Getting specific:
What's the timeline for your plan? When did you discover you had a problem?
Why don't you have the problem resolved already? Validation doesn't take long if you give it a high enough resource ($$, engineer time) priority.
What does your plan do about every unit of product you produced/marketed prior to the process being validated, that is still within its declared lifetime?
Having an unacceptable (or no) answer to that last question has been the basis for a number of Warning Letters in the past several years.
Ronen E
Problem Solver
Moderator
Sometimes it does, especially when the output of the process requires lengthy testing, e.g. post ageing tests (even accelerated ageing can be lengthy at times).
patilrahuld
Can someone name a few external process validation training resources? Our firm wants to send few engineers on a process validation public training.
T "Special Process" Validation Requirements (21 CFR Part 820) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
S 21 CFR 820.75 Process Validation for Medical Device Software 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Watchcat Does 820.30 include the manufacturing process? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Does a process map satisfy 21 CFR 820.20(d) (Quality Plan)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R Calibration of processing equipment - 21 CFR 820.70 Production and process controls 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Interpreting Process Controls - 21 CFR Part 820.70(a) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
D 21 CFR 820.80 In-Process Acceptance Criteria requirements for IVDs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S Suggested process to show compliance for this 820.120(a) for Label Integrity 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
E When to Validate a Process - 21 CFR Part 820.75.(a) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A TUV Audits - 21 CFR 820 General Auditing Discussions 6
S Records - Do's and don't' of record entries (FDA - 21 CFR 820) Records and Data - Quality, Legal and Other Evidence 13
T 21 CFR 820.20 - Quality Planning Requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M 21 CFR 820 vs 21CFR820 vs 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
A 21 CFR 820 - Risk Management - Looking for some guidance US Food and Drug Administration (FDA) 3
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
D ISO 13485, FDA 21 CFR 820 and Auditing the Accounting Department ISO 13485:2016 - Medical Device Quality Management Systems 5
Ed Panek 21 CFR Part 820 - FDA Label Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
B Per 21CFR 820.198 (b) - Justification for no investigation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 22
K 820.200 Servicing Procedure - Our system (because there is an API involved) is classified as Class 3 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
V Determining FDA 820 (registration) vs ISO 13485 - Supplier gives us the kit ISO 13485:2016 - Medical Device Quality Management Systems 1
R Addressing training requirements - 21 CFR Part 820.25 (1) & (2) Other US Medical Device Regulations 4
R How to improve a Validation program and procedures to FDA (21 CFR part 820) & ISO13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Marc Problem with 21 CFR Part 820 - US FDA Quality System Regulations (QSR) sub-forum link - 2 May 2019 Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
R 21 CFR Part 820 Contract Manufacturer of Medical Device Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Q Any good Checklists for ensuring SOPs cover ISO 13485:2016 and 21CFR 820? ISO 13485:2016 - Medical Device Quality Management Systems 3
B Classes/ Online Training on ISO 13485:2016 and FDA QSR Part 820 ISO 13485:2016 - Medical Device Quality Management Systems 5
C ISO 13485 certified as precursor to regulatory compliance to 21 CRF Part 820? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
N Change Control - Compliance with FDA 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
D 21 CFR Part 820 (Subpart A) - Question about "Authority" 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R RUO audits - CFR 820.22 and ISO 13485 8.2.4 Internal Auditing 3
A Training as well as certifications for ISO 13485:2016, 21 CFR 820... Training - Internal, External, Online and Distance Learning 5
K Production Unit Labeling - 21 CFR 820.184.e 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
R 21 CFR Part 820.186 - Types of Quality System Records Document Control Systems, Procedures, Forms and Templates 1
M Does the Scope of 21 CFR Part 820.72 (Equipment) apply to Design? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
V 21 CFR 820 Compliant way to use Kaizen to address Nonconformances Nonconformance and Corrective Action 9
C 21 CFR Part 820.184 - Label Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
shimonv 21 CFR 820.20(d) says: Each manufacturer shall establish a Quality Plan 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
V Upgrading Systems from CFR 211 to CFR 820 (drug+device combination) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
S Looking for a checklist comparing ISO 13485:2016 and 21 CFR Part 820 ISO 13485:2016 - Medical Device Quality Management Systems 14
Q Internal Audit of Product Quality Complaint System (21 CFR Part 820) Customer Complaints 9
D 820.120 UDI (Unique Device Identification) Labeling Verification Requirements Other US Medical Device Regulations 11
R Managing Employee Training Files - 21 CFR Part 820.25 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M Release authorization before or after packaging per 21 CFR 820.80(d)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Need advice in streamlining antiquated 21 CFR 820 compliant QMS Quality Manager and Management Related Issues 2
J Minimum staff per 21 CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Issues with UDI additions to 21 CFR 820 requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Mapping of IEC 62304 artefacts (SRS, SAD, etc) to the 820.30 phases IEC 62304 - Medical Device Software Life Cycle Processes 5
S How others have defined "reaudits"? 21 CFR Part 820.22 Internal Auditing 1
M FDA 21 CFR 820.250 - Does "valid statistical" always mean math? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
