awilliam0815
This is my first posting on this forum.
I have a question for some of you more experienced Quality experts. What quality tool/discipline is used to address a situation where your supplier tells you that there is potentially defective product in your customer base? In this case, the root cause is know (because the supplier defines for you what the root cause is and warns you about it) so I am not sure that the 8D process is best. However, there are useful tools in the 8D process that would help us contain the end product from the customer (through recall procedures, or through endurance testing of defective component to determine impact on durability of the product). Is there a tool that is similar to the 8D which we should use which only addresses the containment aspect. If so, does this process involve a team similar to 8D process? Also, should we open an 8D and focus only on defining the root cause of why the defective assembly was not detected in our plant (as if that were a type of root cause in itself)?
This is a great forum and I look foward to viewing your comments!
Thanks!
Al
Thanks.
Thanks!
Al
Thanks.
