95% reliability for calibration frequency
J Allen
We calibrate basic inspection tools (Micrometers, Calipers, Height Gages) in house using lab grade Gage blocks traceable to NIST as our calibration standard.
We just had a Customer audit that resulted in a finding that we were not verifying if our gages meet 95% reliability to extend/reduce calibration intervals.
Can someone help by explaining how to determine 95% reliability for the small number of calibrations that we perform.
Please use a 0 - 1" mic calibration as an example.
They say I should have a procedure or instruction.
normzone
I don't tell my auditors this, but I have never gotten beyond having some ninety-several percent of my gear in calibration.
There's always something that can't be found, something else that an employee left and took with them, etc. I just track it all and document when it can't be found - ON A DIFFERENT LIST SO I HAVE A LIST WITH 100% OF THE GEAR ON IT CALIBRATED.
dwperron
OK. What they are looking for here is that you have a program in place to evaluate the reliability of your calibration instruments. The target set by ASQR-01 is that >95% of your instruments are found to be in tolerance after each calibration event. They require that you have a method to adjust calibration intervals (shorter or longer) so that you calibrate your instruments often enough to meet the 95% reliability target.
They are looking for you to have a process where if you have an instrument that is found out of tolerance that you reduce its calibration interval. There are many ways of doing this. ASQR-01 states:"Supplier may reference ILAC-G24, OIML D 10 Guidelines for the determination of calibration intervals of measuring instruments and the NCSL RP-1: Establishment and Adjustment of Calibration Intervals as guidelines for determining their interval analysis methodology." You can also use this to justify extending calibration intervals on reliable instruments that stay in tolerance. You must create and implement an interval adjustment program.
Then you will need to analyze your calibration results and see what percentage are found to be in tolerance. If it is above 95% you are good to go. If it is lower it is time to replace unreliable instruments or further reduce intervals.
My experience in multiple labs over the years is that the 95% target is not hard to meet. You just need to document that you have a process in place to deal with the requirement.
sol49720
Lets say you have history for calibrations for the last 5 calibrations on a 1" micrometer and also on 9 more sets for a total of 10 separate micrometers with the last five calibrations performed. Now the requirements for all of them must be the same, lets say ±.0002". Of all the data used (50) calibrations, 49 were in the tolerance as received and 1 was not. So 49/50 x 100 = 98% reliability, if 48 were in tolerance you would have 96% reliability. We use grouping of identical measuring devices, but if you have enough calibration history on an individual gage, you could go that route, but then you would need to do them all that way.
Awais Forklift Reliability Analysis Manufacturing and Related Processes 6
M Reliability Testing - Weibull Analysis Help Reliability Analysis - Predictions, Testing and Standards 4
A Accelerated Reliability Demonstration Test Reliability Analysis - Predictions, Testing and Standards 4
L ISO 2859-2 LQL sampling plan linked to %confidence/%reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M How to Plan and Test the Reliability of Medical Devices Reliability Analysis - Predictions, Testing and Standards 1
L Reliability Block Diagrams (RBDs) helper for review. Reliability Analysis - Predictions, Testing and Standards 1
H Sample Size Calculation (Confidence Interval and Reliability) - Medical Devices Reliability Analysis - Predictions, Testing and Standards 9
K Taguchi Experiments for Factorial Design Analysis - Reliability of Minitab Results Using Minitab Software 1
J Calculating Reliability for Subsystems in Series Reliability Analysis - Predictions, Testing and Standards 15
N Reliability Testing of a Single-Use (Disposable) Medical Device Reliability Analysis - Predictions, Testing and Standards 4
R Regression for MTBF (Medical Device: Repairs vs Install Base) with Reliability Data Reliability Analysis - Predictions, Testing and Standards 16
A Demonstration Test Plan for Reliability of Big Equipment Reliability Analysis - Predictions, Testing and Standards 5
T Reliability calculation for repairable system Reliability Analysis - Predictions, Testing and Standards 14
T I want to calculate reliability at 750 hours Reliability Analysis - Predictions, Testing and Standards 8
G Metrology Laser Reliability General Measurement Device and Calibration Topics 2
S Reliability Software Recommendations Reliability Analysis - Predictions, Testing and Standards 4
D Cpk relation to Reliability Capability, Accuracy and Stability - Processes, Machines, etc. 4
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
M Defining Reliability and Confidence Levels Reliability Analysis - Predictions, Testing and Standards 8
R Standard for Reliability/Performance Test on a Electro Mechanical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T "Time of Demonstration" requirement for Reliability Test Reliability Analysis - Predictions, Testing and Standards 1
C Reliability Testing Protocol on a new Peristaltic Pump Reliability Analysis - Predictions, Testing and Standards 14
T Reliability Lifetime Requirement Demonstration Test Reliability Analysis - Predictions, Testing and Standards 3
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
A Repairable System Reliability Analysis: Uptime/Downtime Hours, Failure Modes Data Reliability Analysis - Predictions, Testing and Standards 2
D Reliability of an Attribute Inspection based on Historical Data Capability, Accuracy and Stability - Processes, Machines, etc. 8
S Reliability Calculation - MTBF/MTTF for Static Mounts of Rail Industry Reliability Analysis - Predictions, Testing and Standards 2
R Minitab - Reliability / Survival Distribution Analysis Using Minitab Software 1
C CRE (Certified Reliability Engineer) Exam 03/02/2013 Professional Certifications and Degrees 11
D Demonstration Reliability Test Formula with allowance for 'x' Failures Reliability Analysis - Predictions, Testing and Standards 6
R Military Land Vehicle Reliability with Only 1 vehicle & Only 1 Endurance Test Reliability Analysis - Predictions, Testing and Standards 5
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
J Relationship between Quality, Reliability, Price and Delivery Misc. Quality Assurance and Business Systems Related Topics 7
L Determining Cpk based on a given Sample Size, Confidence Level, & Reliability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
7 Is testing 99.7% reliable? Reliability Question Reliability Analysis - Predictions, Testing and Standards 3
J Reliability Centered Maintenance - Nowlan & Heap's AD-A066579 (1978) Reliability Analysis - Predictions, Testing and Standards 1
E Question on the Reliability of the Faroarm vs. Romer Arm Calibration and Metrology Software and Hardware 10
O Can anyone recommend appropriate standard for Reliability Testing of Cables Other Medical Device Related Standards 3
M ERTMS/ETCS RAM (Reliability, Availability & Maintainability) Requirements Specs. Various Other Specifications, Standards, and related Requirements 2
D Reliability Growth methodology (Duane, CrowAMSAA) - Test Planning Reliability Analysis - Predictions, Testing and Standards 5
F Reliability of a System - Estimation of R(t) having constant failure rate "Lambda" Reliability Analysis - Predictions, Testing and Standards 2
B Problem with Reliability and Availability Formula Reliability Analysis - Predictions, Testing and Standards 8
C Purpose of using different Distributions to solve Reliability Problems? Reliability Analysis - Predictions, Testing and Standards 2
C Reliability Calculation without Failure (Success Run) Reliability Analysis - Predictions, Testing and Standards 10
H What's the meaning of "a minimum 95% reliability target"? General Measurement Device and Calibration Topics 14
S Reliability Conference Suggestions Reliability Analysis - Predictions, Testing and Standards 5
Q Reliability of a Ferrite Inductor mounted on a PCBA Reliability Analysis - Predictions, Testing and Standards 1
S Aerospace Standard - What document defines reliability concept AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B Determining Statistical Confidence and Reliability Levels with Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Reliability Prediction - Predicting the Reliability of an Inductor (Semi-conductor) Reliability Analysis - Predictions, Testing and Standards 8
