A Diagnostic Exercise to Fix Problems - An Article
W
wmarhel
I came across this article and thought I'd pass it along.........
Wayne
Author: Curtiss Quirin, The Stanley Works
Issue: 7/2007 Reliable Plant Magazine
In all manufacturing companies, it goes without saying that there are problems. The work of leadership should be to create an environment that enables and supports problem-solving at the lowest level of the organization. The job of managers is to solve big/systemic problems and to allow employees on the shop floor to solve many of the smaller problems that arise daily.
What you see in most companies, though, are managers working at least one level below their title, trying to solve problems that should be resolved at lower levels. Employees are allowed to push problems up to the next level for resolution. Human behavior shows that once someone has told you about a problem, they feel better and it then becomes your problem to solve.
This chart is an aid to help you define and solve plant problems.
One of the primary challenges is how to get your team to think - rather than just do their jobs - and more importantly, how to get them thinking about what you want them to think about (business problems).
The best way is to ask them questions, allow them to answer, and give them the resource and responsibility to implement the solution. That's easier said than done, but the positive result of this effort is at the heart of the Toyota Production System, where hundreds of problems are identified and solved each day by hundreds of people.
At most companies, there are limited resources to apply to problem-solving, both from the perspective of time that people have available to work on them and for the capital available to spend on fixing them. Therefore, problem identification becomes key. How do you know where the problem is? How do you know which is the right problem to be solved? How do you know which is the right tool or process to solve it?
The best way to start is to create a visual work environment that makes problems very easy to see. This requires: the creation of a standard, making it visible, and then auditing the standard on a regular basis. Being able to monitor what is good, what is bad, and what is an abnormal vs. normal condition is the key to improving them.
Sometimes, too many metrics are measured, but in a manufacturing company, the most important ones fall into four categories: quality, throughput, cost and your business model.
On this page is a chart that can help guide you to a problem and then identify where to look for potential causes and solutions. Beneath each major attribute is a key indicator (metric) that, if used correctly, should allow you to monitor the state of health in each aspect of your business performance. As you begin the diagnosis, it is best to start on the left side and move to the right. Once a problem is identified, the next step is to understand its boundaries and root cause. As Boss Kettering once said, "a problem well-defined is a problem half-solved."
Since quality is always your highest leverage point, this should be the place to begin. When you improve quality, you gain at least four benefits: customer satisfaction, productivity, cost and, in many cases, improved safety. The best metrics to monitor as quality indicators are: first-time quality, scrap dollars, and customer complaints or returns. If these indicators show poor results in the area of quality, the chart lists some of the best places to start looking to find your deficiencies.
Do you have a quality system? Is your process capable (cpk)? Are your people trained? Are you collecting and monitoring key input data and output attributes? Answers to these questions will usually lead you to tools such as control plans, error-proofing or one of the many problem-solving methodologies.
If you get on top of your operation's quality and you still are having problems, you need to move from left to right on the chart and begin to focus on throughput. The most common indicator for throughput is operational availability. Can the process deliver the output for which it was purchased? This is always directly related to the uptime of the process. If your equipment is not performing at rated levels, you need to begin looking at why it isn't running. Are there mechanical breakdowns? Does the process run out of material? Does the process run the right job at the right time? Do the operators use efficient work methods? Are there lengthy changeovers? Answers to these questions will lead you to tools such as Total Productive Maintenance, standard work for operators, pull systems and single-minute exchange of dies (SMED).
As you demonstrate operational excellence in quality and throughput, you should continue to move across the chart further to the right. At this point, if your manufacturing costs are still too high, there may be some underlying issues that need to be addressed. The simplest to fix would be excessive overhead expenses. Or, you may have to tackle more difficult issues like a wage and benefit package that is uncompetitive for your industry. Or, you may not have capacitized in increments that allow you to efficiently follow your customers' demand curve.
Another place to look is at the product design. It may be sacred and difficult to change for many reasons, but has it been engineered for manufacturability? Or, is there too much model proliferation at the beginning of the process?
And lastly, we move to poor cash flow, which requires a fundamental look at your business model. This demands more of a commercial focus, which is different than the operational perspective used for the previous attributes. If your product and process are efficiently designed and operated, but your cash flow is negative, your problems are generally outside the factory.
You need to re-examine your company's basic value proposition as it relates to the market. What is the value of the product to your customer? Are you late to market? Have you overcapitalized your business and are being crushed by debt service every month? Do you have poor business practices as they relate to terms and conditions, billing and receivables? Should you make vs. buy? None of these problems are easy to solve, but if you follow the chart, you will move to your problem area through the process of elimination.
Having good metrics to monitor the state of health of your business is a key. Shop floor/operational issues should always be solved from the left to the right. Senior leadership/commercial issues should be solved from the right to the left.
It is easy for the senior leadership to cherry-pick at operational problems, but the challenge is to support a problem-solving environment, with many problem-solvers working on the right problems. This chart will help you figure out the identity of your problem(s).
Curtiss Quirin is the director of operations for The Stanley Works’ production plant in Indianapolis. You may contact him at [email protected].
The Reliability in Action department features case studies and articles submitted by our readers. E-mail your case study/article to [email protected] or mail it to Reliable Plant, P.O. Box 87, Fort Atkinson, WI 53538.
Watchcat ISO 13485 for IVD (In-vitro Diagnostic Device) Manufacturers? ISO 13485:2016 - Medical Device Quality Management Systems 9
K Diagnostic X-ray devices - Applicability of Biocompatibility Testing per ISO 10993-1 Manufacturing and Related Processes 5
R Expected life span of Medical devices - X-Ray based diagnostic medical devices ISO 13485:2016 - Medical Device Quality Management Systems 6
M Informational ANVISA – CONSULTA PÚBLICA Nº 734, DE 22 DE OUTUBRO DE 2019 – Registro de dispositivos médicos para diagnóstico in vitro (in vitro diagnostic medical m Medical Device and FDA Regulations and Standards News 0
M Informational EU – EMA revised guidance – Questions & Answers on Implementation of the Medical Devices and In Vitro Diagnostic Medical Devices Regulations ((EU) 201 Medical Device and FDA Regulations and Standards News 2
M Informational EU – Flyer – Call for expression of interest for expert panels on medical devices and in vitro diagnostic medical devices (2019/C 323/05) Medical Device and FDA Regulations and Standards News 0
M Informational EU – Some documents related to Call for expression of interest for expert panels on medical devices and in vitro diagnostic medical devices Medical Device and FDA Regulations and Standards News 0
M Informational EU – Call for expression of interest for expert panels on medical devices and in vitro diagnostic medical devices Medical Device and FDA Regulations and Standards News 1
Watchcat Office of In Vitro Diagnostic and Radiological Health (OIR) De novos 2018 Other US Medical Device Regulations 1
M Informational EU – MDCG 2019-7 Guidance on Article 15 of the Medical Device Regulation (MDR) and in vitro Diagnostic Device Regulation (IVDR) regarding a “person re Medical Device and FDA Regulations and Standards News 6
M Informational Draft standardisation request as regards medical devices in support of Regulation (EU) 2017/745 and in vitro diagnostic medical devices in support of Medical Device and FDA Regulations and Standards News 2
M Informational US FDA final guidance – Marketing Clearance of Diagnostic Ultrasound Systems and Transducers Medical Device and FDA Regulations and Standards News 0
M Informational European Commission expert panels on medical devices and in vitro diagnostic devices Medical Device and FDA Regulations and Standards News 0
S IEC 60601-1-2 Radiated Immunity Test - Diagnostic ECG device IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Informational USFDA Final Guidance – Medical Devices Containing Materials Derived from Animal Sources (Except for In Vitro Diagnostic Devices) Medical Device and FDA Regulations and Standards News 0
B MDSAP for OEM products in Canada for in vitro diagnostic test kit to include lancing device Other Medical Device Related Standards 0
S IEC 60601-1-2 immunity to proximity fields Test setup - Diagnostic ECG device IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S IEC 60601-1-2 - RF Conducted Immunity Test Setup - Diagnostic ECG device IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S IEC 60601-1-2 Radiated E-Field Emission Testing - Diagnostic ECG device IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Medical Device News EU – Medical Devices Regulation (MDR) and In Vitro Diagnostic Medical Devices Regulation (IVDR) – infographics Medical Device and FDA Regulations and Standards News 0
M Medical Device News EU – Transition Timelines from the Directives to the Regulations – Medical Devices and in vitro Diagnostic Medical Devices Medical Device and FDA Regulations and Standards News 13
M FDA News USFDA Draft Guidance – Clarification of Radiation Control Regulations for Manufacturers of Diagnostic X-Ray Equipment Medical Device and FDA Regulations and Standards News 0
T RISK: Selling Diagnostic Devices on Amazon Manufacturing and Related Processes 0
S ISO13485 2016 - What the upshot is of failing to upgrade on a medical diagnostic device ISO 13485:2016 - Medical Device Quality Management Systems 1
M ISO 14971 and Stand-Alone Diagnostic Software ISO 14971 - Medical Device Risk Management 4
T Question: Do we consider 60601-1-2 (4th ed) EMC testing a mode for a diagnostic port? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R Re-Use of Diagnostic Reagent Solution Labels - Buffer Solutions for Internal Use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
E EN 13640:2002 or EN23640:2013 For stability testing of in vitro diagnostic reagents ISO 13485:2016 - Medical Device Quality Management Systems 2
M IVD (in vitro diagnostic) Registration in Argentina Registrars and Notified Bodies 1
E IVD Diagnostic Kit Product Registration in Turkey - IVD Diagnostic Kits EU Medical Device Regulations 1
Q RUO (Research Use Only) vs. IVD (In Vitro Diagnostic) - Differences EU Medical Device Regulations 2
X Is in vitro diagnostic instruments not needed to be registered in India ? Other Medical Device Regulations World-Wide 5
X Morocco In Vitro Diagnostic Medical Device Registration Other Medical Device Regulations World-Wide 3
X In Vitro Diagnostic Medical Device in Palestine Registration and Importation Other Medical Device Regulations World-Wide 8
X In Vitro Diagnostic Medical Device in Turkey Registration Other Medical Device Regulations World-Wide 4
T What is Medical Device Classification for diagnostic equipment in ASEAN ? Other Medical Device Regulations World-Wide 2
Bev D Probability question - Components of Variation study on a single use diagnostic test Statistical Analysis Tools, Techniques and SPC 1
P Risk Management Files for IVD (Invitro Diagnostic Reagent) Kits ISO 14971 - Medical Device Risk Management 3
P IEC 60601-2-25:2011 Comparison Table (ECG, Diagnostic) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
V Test Lab for JIS T 1501 (Performance of Ultrasonic Pulse-Echo Diagnostic Equipment) Japan Medical Device Regulations 1
L Hospital Laboratory IVD (In Vitro Diagnostic) Transportation Classification in Brazil Other Medical Device Regulations World-Wide 2
I IVD (in vitro diagnostic) Checklist for ISO 14971:2009 Annex H ISO 14971 - Medical Device Risk Management 3
S Veterinary Diagnostic Kits Regulations in South East Asia Other Medical Device Regulations World-Wide 8
N Importing Diagnostic kit from US, UK Other Medical Device Regulations World-Wide 5
M Diagnostic Guidelines, Clause 7.3.3.1 - Need to some examples IATF 16949 - Automotive Quality Systems Standard 2
N Industrial MRI Diagnostic System - Which IEC standard should I use when testing? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Pharma Code for Prescription Diagnostic Test IVD Other US Medical Device Regulations 1
M Manufacturing Address - Section 5.3 of EN 591 - In Vitro Diagnostic IFU EU Medical Device Regulations 4
W Insulation Grade for In Vitro Diagnostic (IVD) Device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B Definition Diagnostic - Is "diagnostic" defined in the EU Medical Device Standards? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
