A Registration Certificate...
jmech
#21
What makes you believe the supplier would know you were the entity complaining to the CB?
How would sending the CB a complaint about a supplier cost you if the supplier's performance is bad enough to complain about it?
It is possible that the supplier would not be able to figure out that we had submitted the complaint, but very likely that they will figure it out if we have already made a good faith effort to first notify the supplier about the issue and/or if the investigation is focused on the issue that we reported.
The paid employee time to prepare the complaint with supporting evidence is the most obvious cost.
Sidney Vianna
Post Responsibly
#22
I would greatly appreciate improved CBs and greater accountability of CBs for their certification decisions. Engaging with suppliers' CBs seems like a good idea, especially if other organizations would do it (and I wasn't the supplier involved), but it's not likely to become common in the real world.
How could CB's be accountable if the users of the certificates refuse to engage with them? as clearly described in
The only option is to send the CB a complaint (which will damage or destroy my relationship with my supplier) and involves the costs and risks I previously described but only a remote chance of any benefit. Why should I incur these costs and risks when the benefit that I can receive is so small and remote?
It should go without saying that engaging with a supplier CB should only happen after you've exhausted the direct communication with the supplier themselves. That being the case, I would think the relationship is already strained. Imagine your business represents a small percentage of the supplier sales; you have little leverage with that supplier. Their CB, on the other hand, should have leverage to make them change, if indeed, they are in the wrong and their system does not comply with the standard they are certified to.
CB's will NEVER be accountable if the users of their certification services give them an easy pass. It is that simple. https://www.iso.org/files/live/sites/isoorg/files/store/en/PUB100304.pdf pages 12 through 14.....
What to do if things go wrong? In the event that you are not happy with specific products or services you receive, you should first of all bring this to your supplier’s attention. You will typically do this via the normal technical and/or commercial communication channels that have been established. Your supplier is obliged to investigate your complaint and should take appropriate actions to avoid or reduce the chances of it happening again. If, however, you are dissatisfied with the overall performance of your supplier (if for example they continue to provide non-conforming products and services, do not address your complaints, or are not taking appropriate corrective action), then this is an indication of problems in their quality management system.
Depending on the responses you receive, you should be aware that you can escalate your complaint via the steps described below.
1. If your supplier has a QMS that meets ISO 9001 requirements, they are required to have established communication channels for monitoring customer satisfaction, obtaining customer feedback and dealing with complaints. You should make a formal complaint using these channels.
2. If you are still not satisfied with the response from your supplier, and if they are certified by an independent (third-party) certification body (registrar), you should bring the matter to the certification body’s attention. You can find the certification body’s name by looking at your supplier’s certificate. The certification body will investigate the problems during their surveillance audits of your supplier’s QMS, or, in critical cases, may decide to carry out an additional specific investigation.
3.If you do not receive a satisfactory response from the certification body, and if it is accredited (see Figure 1), you should complain to the relevant accreditation body. Details of any such accreditation will appear on your supplier’s ISO 9001 certificate. If you have difficulty in getting this information, you can consult the list of accreditation bodies that are members of the International Accreditation Forum on the IAF Website (www.iaf.nu).
4. If you feel that you have not received a satisfactory response from the accreditation body, and if it is a member of the International Accreditation Forum (see Figure 1), you can complain to the IAF (www.iaf.nu).
Yes, I know that would be time consuming and, likely, frustrating. Unfortunately, my recommendations for what is now known as the IAF Certsearch database to emulate the IAQG OASIS database were dismissed. Meanwhile the downward spiral, in terms of confidence in management system certificates speeds up.
jmech
#23
Would you want to continue to use a supplier if they've refused to fix an issue and you've had to get a CB to force them to fix it? Would the customer want to deal with you? There's a good chance the answer to both of these questions is "no".
CBs have shown that they have no interest in being accountable and ABs and the IAF also refuse to hold them accountable, as [He Who Shall Not Be Named] has clearly demonstrated over many years. Users of certificates (customers of certified organizations) have no contractual relationship with their supplier's CB and have no leverage to force a CB to take any substantive actions in response to a complaint. As you yourself admit about going the complaint route:
An ISO 9001 version of the IAQG OASIS database may be what is needed. Realistically, I don't think there is enough unified demand for it ever to happen.
If someone wants to complain to a CB, go for it, but you should understand why many people don't bother.
E Adding models to an approved Russian Registration Certificate Other Medical Device Regulations World-Wide 1
R List of countries that require only CE Mark certificate for product registration Other ISO and International Standards and European Regulations 2
Y Is it possible to check the authenticity of a CFDA registration certificate? China Medical Device Regulations 7
B Registration Certificate Dual Accreditation Marks (UKAS and ANAB) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Scope on ISO 9001 Registration Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Company Split and Name Change - Name on Registration Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S CFG Certificate for Medical Device Registration in India Other Medical Device Regulations World-Wide 4
Z CB Certificate and IEC 60601-1 Test Report requirements - Korea Product Registration Other Medical Device Regulations World-Wide 6
D Registration of Class IV Device -Clinical Data and ISO Certificate Canada Medical Device Regulations 3
K ISO 13485 Registration Certificate Life-Time (Validity Period) ISO 13485:2016 - Medical Device Quality Management Systems 21
F Adding a New Office Location to an ISO 9001 Certificate (Scope of Registration) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
ScottK The Importance of the Date Format on your Registration Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Registration Certificate - What do you make of this? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
G 90 days after TS 16949 Registration/Certification Audit to receive certificate? Registrars and Notified Bodies 30
Q 1 QMS and ISO 9001 registration certificate covering 2 plants ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
RoxaneB Clarification Requested on Certificate Wording-Conformance/Certification/Registration Registrars and Notified Bodies 3
T Should copies of the ISO 9001 registration certificate be controlled ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Douglas E. Purdy Certificate of Registration - No expiration indicator on the certificate - Why? Registrars and Notified Bodies 14
R After the registration audit - Hey we got our certificate, that's all that matters Other ISO and International Standards and European Regulations 5
B Registration of a CE-marked medical device in Japan -Will they accept conformity with GSPRs? Japan Medical Device Regulations 0
M EUDAMED Registration tracker EU Medical Device Regulations 4
C Medical Device registration CE Marking (Conformité Européene) / CB Scheme 3
B Product registration CE Marking (Conformité Européene) / CB Scheme 1
Q Corrective Action Notification - Registration Audit ISO 13485:2016 - Medical Device Quality Management Systems 12
Ed Panek ANNUAL FDA Registration - What 510(k) number to use? US Food and Drug Administration (FDA) 1
T Medical Device Registration in Saudi Arabia Other Medical Device Regulations World-Wide 1
C Issues with UDI-DI and LAA/LUA registration in Eudamed EU Medical Device Regulations 1
L Did anyone hear business registration ontario? General Information Resources 1
J Japan registration need manual without temperature reading Japan Medical Device Regulations 0
D South Korea biocide registration Service Industry Specific Topics 0
DanBOS Registration and Listing Timing Other US Medical Device Regulations 2
A Outsourcing registration to a local company China Medical Device Regulations 0
B Establishment and Product Registration Procedure - UK & EU UK Medical Device Regulations 0
C CBD based products registration in EU and UK EU Medical Device Regulations 4
K UKRP Registration with MHRA UK Medical Device Regulations 0
S Third party accessory registration and labelling Other US Medical Device Regulations 4
J Device notification / registration with competent authority EU Medical Device Regulations 2
A Anxiety - ISO Re-registration Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 69
C Does a medical device active (zinc oxide) needs BPR registration in EU? Other ISO and International Standards and European Regulations 5
C European Technical File for registration in Australia CE Marking (Conformité Européene) / CB Scheme 5
W MDD Distributor Registration Requirements Other Medical Device Regulations World-Wide 0
N Actor registration EUDAMED restricted: got no Email to complete the registration EU Medical Device Regulations 6
K FDA Registration and listing weird situation Medical Device and FDA Regulations and Standards News 4
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 1
H Medical device Product Registration Registrars and Notified Bodies 2
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 1
B Health Canada - Blood Glucose Meter Registration Canada Medical Device Regulations 0
L Medical device registration in Iran Other Medical Device Regulations World-Wide 0
Q Is Establishment Registration Necessary? Other US Medical Device Regulations 1
F IVD registration in EU - Northern Ireland based company EU Medical Device Regulations 0
