A2LA vs. NADCAP - Could someone explain the differences?
dbulak
A lab switched from being A2LA certified to being NADCAP certified. They say it basically the same type of certification. Could someone explain the differences if any? This is uncharted territory for me.
D.Scott
In my understanding, they are both certifications to the same standard. It would be the equivilent of choosing a registrar for certification to ISO 9001:2000 or any other standard. Both lab certifications would be to ISO 17025.
Dave
F
Fatboy
NADCAP are you sure?
I am under the impression that you mean NAVLAP. NADCAP is for cerification for special processes mandated by the Aerospace industry.
Hershal
Metrologist-Auditor
NADCAP is the 2nd party audit organization that is one of the ones sanctioned by AIAG. They are closely related with PRI, now a NACLA-signatory accrediting body.
A2LA, like PRI, IAS, and NVLAP, is an accrediting body.
Wesley Richardson
Wes R
To expand on Hershal's comments:
A2LA is American Association for Laboratory Accreditation. They provide Accreditation of testing and calibration laboratories to ISO/IEC 17025.
NVLAP is National Voluntary Laboratory Accreditation Program. They are part of NIST. They provide Accreditation of testing and calibration laboratories to ISO/IEC 17025.
NADCAP was National Association of Defense Contractors Accreditation Program. It was administered by Performance Review Institute (PRI). NADCAP was originally formed as a result of GE Aircraft Engines and others to shift aerospace primes from auditing suppliers, to having the suppliers and testing laboratories pay PRI to have audits. The original standard for laboratories was based on GE S400. There was also a GE S1000 document. Special processes required additional audit criteria and checklists. There are SAE documents, I think AS 7101 for laboratories, and others which are now the standards that the audits do done to.
Nadcap has evolved to performing ISO 9001 audits as well, and has gained acceptance from other aerospace primes. Nadcap maintains a Qualified Manufacturers List (QML) for those companies that are able to supply specific components for aerospace. They also keep a listing of testing laboratories and the scope of the testing they can perform for aerospace related items.
Wes R.
Hershal
Metrologist-Auditor
Good expansion Wesley, and thanks.
Only reminder, A2LA is one - but not the only one - of the accrediting bodies that provide accreditation to ISO/IEC 17025 for both test and cal labs.
Hershal
Wesley Richardson
Wes R
Accreditation agencies
Hershal didn't wish to self promote, but here are some of the agencies that provide Accreditation of testing and calibration laboratories in the U.S.:
IAS, International Accreditation Service, Inc., http://www.iasonline.org
(previously ICBO Evaluation Service).
A2LA, The American Association for Laboratory Accreditation, http://www.a2la.org
NVLAP, National Voluntary Laboratory Accreditation Program, http://ts.nist.gov/ts/htdocs/210/214/214.htm
LAB or L-A-B, Laboratory Accreditation Bureau, http://www.l-a-b.com
ACLASS, Assured Calibration and Laboratory Accreditation Select Services, http://www.aclasscorp.com
NQA, National Quality Assurance Limited, http://www.nqa.com
ASCLD, American Society of Crime Laboratory Directors, http://www.ascld.org
I am sure there are more. This is not an endorsement of any of these organizations. I will leave it up to the potential client to make the determination as to which of these has the reputation and services that they need.
Wes R.
David Johnson
A2LA would conduct a Laboratory quality management system audit to ISO 17025, which is NOT specific to the aerospace industry.
Nadcap is much deeper and more prescriptive and is specific to the aerospace industry. For instance, Nadcap requires ISO 17025 is the prerequisit QMS and then adds any of the following specifications that apply to your Lab: (SEE LISTING BELOW). To contact me, see my profile. Sincerely, David Johnson
Materials Testing
AC7006 Rev F - Audit Criteria for Accreditation to ISO/IEC 17025
AC7101/1 Rev D - Nadcap Audit Criteria for Materials Testing Laboratories - (General Requirements for All Laboratories)
AC7101/2 Rev B - Nadcap Audit Criteria for Materials Test Laboratories - (Chemical Testing)
AC7101/3 Rev B - Nadcap Audit Criteria for Materials Test Laboratories - (Mechanical Testing)
AC7101/4 Rev C - Nadcap Audit Criteria for Materials Testing Laboratories - (Metallography and Microhardness)
AC7101/5 Rev B - Nadcap Audit Criteria for Materials Testing Laboratories - (Hardness)
AC7101/6 Rev B - Nadcap Audit Criteria for Materials Testing Laboratories - (Corrosion)
AC7101/7 Rev B - Nadcap Audit Criteria for Materials Testing Laboratories - (Mechanical Testing Specimen Preparation)
AC7101/8 Rev A - Nadcap Audit Criteria for Materials Test Laboratories - (Differential Thermal Analysis)
AC7101/8 Rev B - Nadcap Audit Criteria for Materials Test Laboratories - Differential Thermal Analysis [to be used on audits ON or AFTER 2-Aug-09]
AC7101/9 Rev A - Nadcap Audit Criteria for Materials Test Laboratories - (Heat Treating)
AC7101/11 Rev A - Nadcap Audit Criteria for Materials Test Laboratories - (Fastener Testing)
Non-Metallic Materials Testing (NMMT)
AC7122 - Nadcap Audit Criteria for Non-Metallic Materials Testing Laboratories
AC7122/1 - Nadcap Audit Criteria for Non-Metallic Materials Testing Laboratories - (Class A: Composites)
Non-Destructive Testing (NDT)
AC7114 Rev C - Nadcap NonDestructive Testing (NDT) Suppliers Accreditation Program Audit Criteria
AC7114/1 Rev C - Nadcap Audit Criteria for Non-Destructive Testing Facility Penetrant Survey
AC7114/2 Rev C - Nadcap Audit Criteria for Non-Destructive Testing Magnetic Particle Survey
AC7114/3 Rev D - Nadcap Audit Criteria for Non-Destructive Testing Facility Ultrasonic Survey
AC7114/4 Rev C - Nadcap Audit Criteria for Non-Destructive Testing Facility Film Radiography Survey
AC7114 S Rev D - Supplemental Audit Criteria for Nadcap Non-Destructive (NDT) Suppliers Accreditation Program Audit Criteria
AC7114/1S Rev D - Supplemental Audit Criteria for Nadcap Audit Criteria for Non-Destructive Testing Facility Penetrant Survey
AC7114/2S Rev D - Supplemental Audit Criteria for Nadcap Audit Criteria for Non-Destructive Testing Magnetic Particle Survey
AC7114/3S Rev D - Supplemental Audit Criteria for Nadcap Audit Criteria for Non-Destructive Testing Facility Ultrasonic Survey
AC7114/4S Rev D - Supplemental Audit Criteria for Nadcap Audit Criteria for Non-Destructive Testing Facility Film Radiography Survey
EDIT NOTE: David Johnson's Company and Contact Information can be found in his Profile.
R Do I need A2LA Accreditation? General Measurement Device and Calibration Topics 2
C Environmental Temperature Chamber Testing & A2LA requirements IATF 16949 - Automotive Quality Systems Standard 4
D A2LA Certification and moving to a new Facility General Measurement Device and Calibration Topics 6
Q Adding to our A2LA Scope of Accreditation General Measurement Device and Calibration Topics 2
G A2LA's ISO/IEC 17025 and Accreditation Training - Opinions from previous attendees ISO 17025 related Discussions 2
QMMike TS 16949 - A2LA or ISO/IEC 17025 required for material testing? ISO 17025 related Discussions 6
S A2LA requirements for Electrical Uncertainty Budgets - Measurements with a slope Measurement Uncertainty (MU) 3
A ILAC explanation - IEC60601-1 testing certified by an A2LA laboratory IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S Calibration of equipment in an A2LA accredited testing laboratory General Measurement Device and Calibration Topics 7
E A2LA Proficiency Test Requirement help needed General Measurement Device and Calibration Topics 5
O When do we need to be A2LA/ISO 17025 certified? ISO 17025 related Discussions 6
E A2LA Laboratory Management Requirements or Qualifications General Measurement Device and Calibration Topics 10
M When can you be "accredited" and not be "accredited" with A2LA? General Measurement Device and Calibration Topics 7
S A2LA Calibration Program Requirements, September 2005 II. Section 2.1.3.b.3 General Measurement Device and Calibration Topics 2
gard2372 A2LA & ISO/IEC 17025:1999 vs. European Requirements ISO 17025 related Discussions 7
R AS7101 for Materials Testing - Is this similar to 17025 or A2LA? ISO 17025 related Discussions 4
J A2LA vs. other accreditors General Measurement Device and Calibration Topics 7
T Field Decay Test - Can any one recommend few independent and A2lA accredited labs? Reliability Analysis - Predictions, Testing and Standards 4
T Providing A2LA w/ Proficiency Test results General Measurement Device and Calibration Topics 5
S Looking for company to calibrate cutting dies with A2LA, IAS, or NVLAP accreditation General Measurement Device and Calibration Topics 1
J A2LA here, my boss wants to open China office now General Measurement Device and Calibration Topics 6
Hershal A2LA has completely terminated involvement in NACLA General Measurement Device and Calibration Topics 0
W ISO 17025 or A2LA, what?s this?? ISO 17025 related Discussions 4
D If you are TS16949 certified, it also covers A2LA certification? IATF 16949 - Automotive Quality Systems Standard 5
S Labels identifying accredited standards - Considering making labels with A2LA Logo General Measurement Device and Calibration Topics 4
S Maintaining and tracking laboratory voltage standards - A2LA audit General Measurement Device and Calibration Topics 3
V Is A2LA the US National equivalent to ISO 17025? ISO 17025 related Discussions 9
Q Seeking: A2LA to ISO 17025 Audit Template ISO 17025 related Discussions 2
F Which NAVLAP or A2LA Laboratory Accreditation Body? General Measurement Device and Calibration Topics 7
C Differences and similarities between ISO 17025 and A2LA certification? ISO 17025 related Discussions 2
K A2LA laboratory requirements General Measurement Device and Calibration Topics 6
R 17025, guide 25, A2LA (cal.,meas.,antest) ISO 17025 related Discussions 2
L A2LA - Sending testing to a non-accredited lab if customer doesn't require A2LA? General Measurement Device and Calibration Topics 2
Marc A2LA has a Traceability Policy that was issued 08/2000 General Measurement Device and Calibration Topics 0
D A2LA/ISO GUIDE 25 QUALIFIED LABS WITH FLOW CALIBRATION IN THIER SCOPE General Measurement Device and Calibration Topics 1
Marc APLAC - A2LA - ISO/IEC Guide 43-1 (1997) - 17025 - Laboratory Proficiency Testing ISO 17025 related Discussions 0
Marc NVLAP and A2LA Guide 25 Interpretations General Measurement Device and Calibration Topics 0
Marc NVLAP vs. A2LA - NVLAP policy on acceptance of calibration laboratories General Measurement Device and Calibration Topics 0
Marc A2LA Contact and Guide 25 Comment - NOTE: Guide 25 is long since dead and buried General Measurement Device and Calibration Topics 4
N Nadcap AC7101/2 Rev. E Section 3.2 - Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
blackholequasar Looking into Nadcap for the first time AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
A Nadcap Accreditation Fee AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M NADCAP mentoring program AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S NADCAP approval for Conventional Machining and Chemical processes - need assistance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
DuncanGibbons How does AS 9100D correlate or differ from NADCAP accreditation? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B AS9100 - Are special process suppliers required to be NADCAP accredited? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
N Responding to NADCAP nonconformance - Control of External Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q NADCAP NDT (specifically RT) - Calibration of eye loupe reticle & optical comparator AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J NADCAP - Supplier Special Processes Certifications Manufacturing and Related Processes 1
Q NADCAP NDT (specifically RT) - Checklist AC7114 Rev. K, section 8.1.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
