About PMA IP Infringement
We are a CAAC-approved PMA manufacturer and a MRO in China. Apart from through licensing, we design and produce PMA by such methods as decompiling, disassembling, decoding, reproducing, redesigning, reverse engineering.
So here’s the problem. On the airworthiness side, our PMA are official approved and absolutely “clean”. But on the IP side, we may infringe OEMs IP rights.
As we know, there are four situations when FAA approve an PMA, which are:
1. License
2. Test and Computation
3. Identicality
4. Supplemental Type Certificate (STC)
How can a PMA manufacturer know if it is infringing IP rights when it is manufacturing PMA through Test and Computation and Identicality or the methods I mentioned above? Dou you guys have similar cases about PMA IP rights infringement which does not arise from breach of License Agreement?
Lutheus - Did you ever come to a final determination on this?? If you truly obtained PMA approval thru the processes described, there should be no concerns. However, if you are in possession of the OEM drawings and used those to develop your designs, well then there certainly could be IP infringement.
S For Parts Manufacturer Approval (PMA) Is 100% Inspection Required? Federal Aviation Administration (FAA) Standards and Requirements 2
K PMA vs 510(k) for Mammography Machine US Food and Drug Administration (FDA) 2
B PMA Supplement Required? US Food and Drug Administration (FDA) 3
A PMA Modifications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
L PMA and Non-PMA parts in same finished goods area? Federal Aviation Administration (FAA) Standards and Requirements 1
S Regulatory Medical Device PMA Plans US Food and Drug Administration (FDA) 2
DuncanGibbons FAA approval of articles (PMA, TSO) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
J Dr Training Records - Training doctors to use a PMA approved medical device Other US Medical Device Regulations 2
A Examples of Pre-Sub, SRD, PMA Shells and Templates Other US Medical Device Regulations 3
S IPO/POA arrangement with PMA holder EASA and JAA Aviation Standards and Requirements 1
J FAA Maintenance Requirements - DER Repair to a PMA Part Federal Aviation Administration (FAA) Standards and Requirements 1
J PMA Device - Lot # change in New ERP Software - What are the FDA Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
D PMA A&P Document (i.e. Promotional Brochures, Flyers) Retention Requirements Other US Medical Device Regulations 10
B Looking for a Premarket Approval (PMA) Template or checklist Other US Medical Device Regulations 4
Q FDA Consensus Standard for PMA (Pre-Market Approval) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
P Basic questions about earning TSOA (Technical Standard Order Authorization) and PMA Federal Aviation Administration (FAA) Standards and Requirements 2
H FDA/PMA/Medical Device/Before submission/Manufacturing facility change US Food and Drug Administration (FDA) 1
P Acquisition of a company that manufactures a PMA device-FDA notification requriements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S What are the differences between Traditional 510(k) and a PMA to meet 21 CFR 814.20 ? Other US Medical Device Regulations 3
T Support of our customer?s PMA submission to the FDA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
H Amending Test and Computation PMA (Parts Manufacturing Approval) Federal Aviation Administration (FAA) Standards and Requirements 2
S US FDA PMA (Pre-Market Approval) Process Flow Chart Example Other US Medical Device Regulations 1
T Requirements for Private Labeling a Class III (PMA) Medical Device in the US 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
bio_subbu US FDA issues Draft Guidance on Premarket Approval (PMA) Acceptability Other US Medical Device Regulations 0
G Changing the Name of a PMA Product Under Review Other US Medical Device Regulations 1
C FAA/PMA Part Marking Requirements Federal Aviation Administration (FAA) Standards and Requirements 2
T PMA (Parts Manufacturing Approval) vs IP (Intellectual Property) Federal Aviation Administration (FAA) Standards and Requirements 11
bio_subbu FDA issues draft PMA (Pre-Market Approval) Clinical Study Guidance 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
I Medical Device Exclusivity Period if granted a PMA (Parts Manufacturing Approval) Other US Medical Device Regulations 2
S PMA Submission Software Hazard Analysis Document vs. Product Hazard Analysis doc ISO 14971 - Medical Device Risk Management 5
A TSO (Technical Standard Order) and PMA (Parts Manufacturer Approval) - Differences Federal Aviation Administration (FAA) Standards and Requirements 5
R PMA (Parts Manufacturing Approval) Supplement - Labeling Software Change 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B Class 1 Diagnostic Kits - PMA (Parts Manufacturing Approval) Required? ISO 13485:2016 - Medical Device Quality Management Systems 1
Q Marking Parts Manufacturing Approval (PMA) Parts with a 8130-3 Tag Federal Aviation Administration (FAA) Standards and Requirements 9
T Change Control Decision Tree - When medical devices that are approved with a PMA Document Control Systems, Procedures, Forms and Templates 9
J FDA Response to PMA Submission: Help 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P PMA called for a class III-510(k)..what next? US Food and Drug Administration (FDA) 4
J FMEA for PMA Data Application Package - APU (Auxiliary Power Unit) parts Federal Aviation Administration (FAA) Standards and Requirements 3
J PMA Test and Computation Question - FAA order 8110.42C Chapter 2 section 6 b Federal Aviation Administration (FAA) Standards and Requirements 3
A PMA (Parts Manufacturer Approvals) parts in Europe Federal Aviation Administration (FAA) Standards and Requirements 1
J PMA (Premarket Approval) - Will inspection of Component Manufacturers occur? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T PMA (PreMarket Approval) Check List example wanted for Class III Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
C Protocol Agreement - PMA application for Class III Medical devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
C Does every PMA part have to have an 8130 form? Or compliance with part 21.303? Federal Aviation Administration (FAA) Standards and Requirements 4
J PMA Approval Based on Test & Computation OEM Requirements Federal Aviation Administration (FAA) Standards and Requirements 2
J FAA Los Angeles ACO Manager for PMA Submittals Federal Aviation Administration (FAA) Standards and Requirements 2
J PMA (Parts Manufacture Approval) Dimensional Inspections Federal Aviation Administration (FAA) Standards and Requirements 7
J Requirements for PMA parts for domestic use and 8130-3 Tags Federal Aviation Administration (FAA) Standards and Requirements 2
J PMA (Parts Manufacturer Approval) FAA Submittal Federal Aviation Administration (FAA) Standards and Requirements 7
A FDA site database search - Where to find listing for PMA and 510(k) ISO 13485:2016 - Medical Device Quality Management Systems 5
