Acceptable % on a Gage R
Danny Hoover
Good morning,
I have just started at a new company and one of my duties is to help get a SPC program in place. I have started running gage R studies(1x10) on all newpieces before we do a full r&r/cap study/layout. I have looked around for an answer, but here they accept a R study if it is <30%, which causes the r&r to typically fail. I have a new part that the r study is 19% on one dimension, when I copy and fill out the r&r with the R data it shows 29%. What is the standard accepted R% to pass and move on?
Thanks,
DH
Re: Acceptable % on a Gage R&R
Good morning,
Thanks,
DH
Welcome to the Cove. :bigwave:
I'm not sure what the point is of doing an "R" as a prelim to R&R, nor have I ever worked anywhere where such a thing was done. The numbers and pass/fail criteria in traditional GR&R studies are tainted by a fair amount of voodoo math and shouldn't be considered the only criterion in evaluating a measurement system. You should be looking at the numbers in order to find out what they're telling you regardless of the R&R percent results.
In the absence of specific customer requirements, whether or not a measurement system is considered acceptable should not be determined by the R&R percentages alone. You need to consider the application and its attendant risks in making decisions.
Danny Hoover
Thanks Jim,
We measure by hand thin plastic parts and we need to get the measurements to repeat. The R study shows if the part could be measured by one person and repeat. The time saver is if it fails an R study, we do not run a full r&r/capability/layout study, but we ask the engineer and customer for input on tolerance relief, gaging needed, etc. These are automotive parts with customer required spc points if that helps.
Thanks,
DH
Ninja
Looking for Reality
I'll typically do an "R" study myself as well with new equipment, but not as a formal thing, and not for determining acceptance...just for a reality check before I invest the labor to do the full GRR.
As Jim notes, the % result isn't very valuable from this 'reality check' kind of study...but the reality check part is. If I measure 5 parts twice each (2x5) and my EV% is 30% of my tolerance, I need to look at how I'm using the tool before I get two other people involved. If the Equipment variation is even approaching 10% of tolerance for me, why would I think it would be better for anyone else (or more to the point everybody else).
There's a value to a quick test in that I can revise the test protocol before using the labor to do the 'official' test...but I don't see a value in defining acceptance criteria for the quick test. Look at your results and see if the current test method has a chance at being acceptable though full testing.
Danny Hoover
Thanks Ninja,
You use the test exactly as I am thinking. I was just wondering if a common
"stop" % existed. I typically get the r&r to come in around 2x the R alone.
I am required to conserve as much inspection time as possible, and I hate having to run the studies over after addition people are involved.
:agree:
DH
Thanks Ninja,
:agree:
DH
I'm sure there's no such number. I can see doing a little informal trial when there's a novel situation--something unusual in the parts or the device, or both, but for everyday purposes I think that people should be generally aware of the parts and the devices and the competency of operators to the extent that such a thing shouldn't be necessary.
JAltmann
If i had to give a number 10% comes to mind. But when i do the gage R study i am looking for the sources of error. Is that error attributed to the operator? The gage, combination?
If it is all in one area i would try to correct the issue before proceeding to a full GR&R.
Danny Hoover
Thanks James,
I am looking to save time without having to do a complete study. The flimsy nature of some parts often make it impossible for the lab to get the parts to repeat. After they pass in the lab, we have the criteria and method for floor inspectors to do the checks, whether gages,non-contact, or hand tools are used. We can tweak the process if the floor has any trouble doing the inspections.
Thanks,
DH
I
ivijaya
A P/T ratio less than 0.1 indicates that the measurement system can reliably determine whether any given part meets the tolerance specification. A P/T ratio greater than 0.3 suggests that unacceptable parts will be measured as acceptable (or vice-versa) by the measurement system, making the system inappropriate for the process for which it is being used
sitapaty
I want a clarification from you.Are you calculating R&R as % of DRG. TOLERANCE or % of PROCESS VARIATION observed in your trial.?
Theoritically if the R&R value is <10% of process variation the gauge is acceptable.But for practical purposes if R&R is <10% of drg.tolerance it is ideal.In special cases <30% is accepted.
-SITAPATY
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
C Lowest Acceptable Grade for Master Gage Set Calibration and Metrology Software and Hardware 1
A Help with acceptable screw gage values per standard BS 919 for Go/ No Go gage General Measurement Device and Calibration Topics 4
G Ford - Type 1 Gage Study MSA (Measurement Systems Analysis) acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Gage Block Repair - What type of stone is acceptable for removing burrs General Measurement Device and Calibration Topics 5
A Acceptable Criteria for Variable Gage R&R according to the MSA Manual 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Is this GR&R (Gage R&R) acceptable on the surface Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 36
S What are Acceptable Limits for Gage R&R Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Acceptable Gage R&R - What is acceptable %error for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Acceptable Gage R&R Output Results - EV, AV, R&R, PV, and TV Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J What is an acceptable Gage R&R (Repeatability and Reproducability) system? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
W Misinterpretation of requirement acceptable as root cause? Problem Solving, Root Cause Fault and Failure Analysis 19
M Are Fungal counts acceptable in class 1000 clean rooms? Other ISO and International Standards and European Regulations 2
T ISO 14971-2019 doubt - Evaluate if estimated risks are acceptable ISO 14971 - Medical Device Risk Management 9
samer Acceptable limits for Spills - Tracking Hydraulic Spills ISO 14001:2015 Specific Discussions 3
V Acceptable maximum RSD (relative standard deviation) for an sample size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q Acceptable calibration accuracy of a 60" linear measuring device General Measurement Device and Calibration Topics 16
F It is acceptable moving remote locations staff to manufacturing plant for auditing? IATF 16949 - Automotive Quality Systems Standard 3
Q Is it acceptable to mix components from two different lots into an assembly? ISO 13485:2016 - Medical Device Quality Management Systems 1
C Acceptable NDC for %GR&R part inspection to Tolerance (%Tolerance) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Risk Register - have we considered enough and is the format acceptable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K Operator Checks - How to show that they were completed on a checklist as acceptable IATF 16949 - Automotive Quality Systems Standard 2
C Example Work Instruction/Procedure for AQL (Acceptable Quality Level) AQL - Acceptable Quality Level 4
S Dates on Labels acceptable to the USA - GS1 General Specification 3.4.4 Other US Medical Device Regulations 3
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
W Unattached (stand-alone) Forms acceptable for AS9100C? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
V Why Gauge R&R 10% is acceptable for variable instruments ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
X Acceptable methods to store and archive records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Is it acceptable to audit to the Nuclear Principles? Quality Manager and Management Related Issues 9
I Is it acceptable it is to list new products under an existing 510(k)? Other US Medical Device Regulations 14
S If this EN ISO 11137 certificate acceptable for Contract Sterilization? ISO 13485:2016 - Medical Device Quality Management Systems 2
D What is satisfactory & acceptable for Coliform - Staphylococcus - Hands and Surfaces Food Safety - ISO 22000, HACCP (21 CFR 120) 3
S Is a Dynamic Controlled Form acceptable per 21CFR820 Document Control Systems, Procedures, Forms and Templates 3
B Digital Signature Solutions acceptable to use in an FDA Medical Device Environment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J Is a ndc less than five is also acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T Technical regulations that determine the acceptable limits of cigarettes General Measurement Device and Calibration Topics 4
L IEC 60601-1 3rd edition Clause 9.2.2 Trapping Zone (Acceptable Gaps) IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
N Is it acceptable to sterilize products without claiming and labeling "sterile" ? ISO 13485:2016 - Medical Device Quality Management Systems 6
M Quality Objectives - Acceptable Levels and Functions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
C What is an acceptable bioburden level or count when working in cleanroom ISO class7 ISO 13485:2016 - Medical Device Quality Management Systems 1
D Is embedding documents within a Contract an acceptable practice ? Contract Review Process 9
B Non Acceptable % Tolerance Result - Decrease Sorting Limits Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
F ANSI ASQ Z1.4 - Is the following process acceptable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Maximum acceptable Tolerance - Uncertainty Ratio (TUR) General Measurement Device and Calibration Topics 2
S Is it acceptable to have an ASL for Critical suppliers alone? Supplier Quality Assurance and other Supplier Issues 4
S Is this Quality Policy acceptable in the context of ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 24
S What are typical Acceptable Quality Levels (AQL) adopted in Food industry? Food Safety - ISO 22000, HACCP (21 CFR 120) 1
somashekar Who can provide a WHO GMP certificate in India acceptable to the CDSCO Other Medical Device Regulations World-Wide 6
