Acceptable quantity levels/Sigma levels for reducing the frequency of quality tests.
PaulC333
Hello, I am currently a graduate engineer for a manufacturing company, we produce injection mould caps and blow mould bottles along with steel drums. We are currently looking to reduce the frequency of the injection mould physical quality checks we carry out from every 2 hours to every 4 hours.
I have information on the quality control parameters (Cycle time, filling time, shot volume, etc) for each part produced over the last year. The process is very stable with low variation. I was wondering if anyone knew of any standard sample sizes and sigma levels/AQL levels/Standard deviation/Variability which I can compare with the quality control data I have gathered to act us justification for the reduction in frequency of our quality checks (instead of just saying that we feel the variability is small and the sample size is adequate to say it is a low risk change).
Please let me know if you have any advice/information that can help me out.
Thank you very much!
welcome PaulC333!
First understand that sample size calculations and AQLs have nothing to do with frequency of taking samples.
The frequency of sampling is based on a couple things: What kind of sampling are you performing? how much bad product you are willing to make before you detect it? And when do the natural change points occur?
There are 2 basic types of sampling: Lot acceptance and in-process SPC or Change control. It sounds like you are doing in-process/change control or SPC type sampling. These do not have statistically calculated sample sizes. The sample size is typically quite small (SPC is and should be very small; 3-5 units is usual sufficient and for plastics a single sample is often sufficient). The purpose of in-process inspection is to sample when a natural change occurs (new material, new setup, process adjustments, startup, shutdown, etc.) If something goes wrong at these change points it only takes a few units to detect it. If the process is stable and you are confident that it will remain so then you can reduce the frequency of when you take samples.
Lot acceptance testing does use AQL/RQL sample size calculations and random sampling. The AQL/RQL choices shouldn’t Be based on historical, current or future defect rates but on the defect rate you do not want to ship to your Customer and so that should not change (contrary to some popular beliefs).
Does this help?
PaulC333
Thank you for the quick reply Bev D,
This does help me better understand the different quality sampling.
Our current sampling performed consists of a physical weight check of the injection mould cap, internal and external thread diameters, go/no go gauge, checking the cap fits a sample bottle and checking the regrind percentage.
The purpose of the testing is to make sure we do not send out any out of specification or defective parts to our customers. We currently do this every 2 hours but given that the test very rarely fails and the low variation between the injection mould quality control parameters (Cycle time, filling time, shot volume, etc) means we feel it would be beneficial to change this to every 4 hours to save time.
I was hoping to use questions like "how much bad product you are willing to make before you detect it" as you said but I have been asked to come up with a justification for reducing the frequency of our sampling using the variation of the quality control parameters (Cycle time, filling time, shot volume, etc) I have gathered.
I was wondering if anyone knew of any statistical thresholds (for example sigma level) and an adequate sample size which I can use to compare with the quality control data I have gathered to act us justification for the reduction in frequency of our sampling.
Hope this explanation clears up my enquiry, although it is quite long itself.
Thanks,
Paul
Paul
Sorry there are no statistical justifications for changing the frequency of sampling, which is what you are trying to do. Not to be rude, but did you actually read and understand what I posted? What is it about my response that your management cannot understand? If you are persisting to pursue an answer that doesn’t exist because your management is persisting then the answer is to explain the truth to them. Or just make something up. Because frankly if they can’t understand my response then they really don’t even understand statistics, so making something up won’t hurt.
To help clarify and simplify the answer: since there is no statistical reason for determining the frequency of sampling, there can be no statistical reason for reducing the frequency of sampling.
PaulC333
Thank you for the clear reply, I understand what you are saying. I just posed the question again to be absolutely sure that it is not possible, I should have just asked you to confirm that it was not possible but I was not 100% confident in my understanding of your first reply. I will make them aware of your answer, thanks again.
It really boils down to how much material are you willing to accept as "at risk"? When you sample every 2 hours, you have 2 hours of product "at risk". That will be 2 hours of product that you will either have to hold before further processing or track down and quarantine after additional value has been added. If you increase your time to 4 hours, you have doubled your population "at risk". That is why Bev said that you should coordinate your sampling with changes that are known to cause shifts in the process. That helps you minimize the population 'at risk".
Johnny Quality
Paul,
Welcome to the cove.
I was in injection moulding once and I was responsible for setting the type and frequency of the production quality checks. I went through years of data on production quality checks and customer complaints and I found the following conclusions:
  • Product was inspected hourly for common visual injection moulding defects, 2-4 dimensional checks, part weight. Sample size was 1 per cavity
  • The overwhelming majority of production and customer issues were common visual injection moulding defects; short shots, flash, burning, splay, etc. Very few were size related
  • Those that were size related were all from one customer, about 3-5 tools from around 200 live tools at any given time
Based on this we cut down process inspection for nearly all products over a 2 year period. Aside from a few problem jobs we eliminated dimensional inspection to first off, last off and start of shift only. I would have cut it down to just first/last off but I feared they would lose measurement competency if they only measured parts every few days. This, tied with the process improvements we made, reduced customer complaints and reduced shop floor issues, problems were identified sooner as the processes were better and we focused quality checks to what our data showed was likely to change.
I hope this helps.
R Using RPN to Confirm Risk Reduced to an Acceptable Level Risk Management Principles and Generic Guidelines 12
Eva lee Which is the range for the validated batch size(for example ±5%, 10%) is acceptable? Manufacturing and Related Processes 8
S Examples of FDA acceptable Software Design Specification (SDS) Medical Device and FDA Regulations and Standards News 6
Q Acceptable Tolerance - how to derive? Measurement Uncertainty (MU) 16
W Misinterpretation of requirement acceptable as root cause? Problem Solving, Root Cause Fault and Failure Analysis 19
M Are Fungal counts acceptable in class 1000 clean rooms? Other ISO and International Standards and European Regulations 2
T ISO 14971-2019 doubt - Evaluate if estimated risks are acceptable ISO 14971 - Medical Device Risk Management 9
samer Acceptable limits for Spills - Tracking Hydraulic Spills ISO 14001:2015 Specific Discussions 3
V Acceptable maximum RSD (relative standard deviation) for an sample size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Q Acceptable calibration accuracy of a 60" linear measuring device General Measurement Device and Calibration Topics 16
F It is acceptable moving remote locations staff to manufacturing plant for auditing? IATF 16949 - Automotive Quality Systems Standard 3
Q Is it acceptable to mix components from two different lots into an assembly? ISO 13485:2016 - Medical Device Quality Management Systems 1
C Acceptable NDC for %GR&R part inspection to Tolerance (%Tolerance) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Risk Register - have we considered enough and is the format acceptable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K Operator Checks - How to show that they were completed on a checklist as acceptable IATF 16949 - Automotive Quality Systems Standard 2
C Example Work Instruction/Procedure for AQL (Acceptable Quality Level) AQL - Acceptable Quality Level 4
S Dates on Labels acceptable to the USA - GS1 General Specification 3.4.4 Other US Medical Device Regulations 3
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
W Unattached (stand-alone) Forms acceptable for AS9100C? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
V Why Gauge R&R 10% is acceptable for variable instruments ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
X Acceptable methods to store and archive records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Is it acceptable to audit to the Nuclear Principles? Quality Manager and Management Related Issues 9
I Is it acceptable it is to list new products under an existing 510(k)? Other US Medical Device Regulations 14
S If this EN ISO 11137 certificate acceptable for Contract Sterilization? ISO 13485:2016 - Medical Device Quality Management Systems 2
D What is satisfactory & acceptable for Coliform - Staphylococcus - Hands and Surfaces Food Safety - ISO 22000, HACCP (21 CFR 120) 3
S Is a Dynamic Controlled Form acceptable per 21CFR820 Document Control Systems, Procedures, Forms and Templates 3
C Lowest Acceptable Grade for Master Gage Set Calibration and Metrology Software and Hardware 1
B Digital Signature Solutions acceptable to use in an FDA Medical Device Environment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J Is a ndc less than five is also acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T Technical regulations that determine the acceptable limits of cigarettes General Measurement Device and Calibration Topics 4
L IEC 60601-1 3rd edition Clause 9.2.2 Trapping Zone (Acceptable Gaps) IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
N Is it acceptable to sterilize products without claiming and labeling "sterile" ? ISO 13485:2016 - Medical Device Quality Management Systems 6
M Quality Objectives - Acceptable Levels and Functions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
C What is an acceptable bioburden level or count when working in cleanroom ISO class7 ISO 13485:2016 - Medical Device Quality Management Systems 1
D Is embedding documents within a Contract an acceptable practice ? Contract Review Process 9
B Non Acceptable % Tolerance Result - Decrease Sorting Limits Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
F ANSI ASQ Z1.4 - Is the following process acceptable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Maximum acceptable Tolerance - Uncertainty Ratio (TUR) General Measurement Device and Calibration Topics 2
S Is it acceptable to have an ASL for Critical suppliers alone? Supplier Quality Assurance and other Supplier Issues 4
S Is this Quality Policy acceptable in the context of ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 24
A Help with acceptable screw gage values per standard BS 919 for Go/ No Go gage General Measurement Device and Calibration Topics 4
S What are typical Acceptable Quality Levels (AQL) adopted in Food industry? Food Safety - ISO 22000, HACCP (21 CFR 120) 1
somashekar Who can provide a WHO GMP certificate in India acceptable to the CDSCO Other Medical Device Regulations World-Wide 6
D Root Cause and Corrective Action - Is our Practice Acceptable? ISO 13485:2016 - Medical Device Quality Management Systems 5
W Application of AQL (Acceptable Quality Level) Concept AQL - Acceptable Quality Level 15
H Acceptable Time to provide proof of CAR (Corrective Action Report) Nonconformance and Corrective Action 4
A Sample Size for Mathematical Model with acceptable Confidence Level Using Minitab Software 7
