Acceptable Tolerance - how to derive?
QCJS
U can't change a person but u can change yourself
This is the info I saw on the calibration cert of a Dial Test Indicator.
Range = 0 to 0.2mm
Graduation = 0.002mm
Allowable error=0.004mm
Measured value = 0.0010mm
Expanded uncertainty for measured value = 0.0007mm
Can I derive the equipment's Acceptable Tolerance with this info?
Pls help. Thanks,
QCJS
Jen Kirley
Quality and Auditing Expert
I have most often seen tolerance set at plus or minus one graduation on the gage. When calibrating, I would check at different parts of the range as error tends to be more often present at low and/or high end of the range.
QCJS
Hi Jen,
I ask this is because my MSA tutor mentioned I need to calculate the acceptance tolerance after every calibration. I'm suppose to include this in my calibration masterlist. If not, it will not be complete.
So from your last statement, can I say that I can find my acceptable tolerance by:
(Max error - Min error) / 2?
From the above example, is it Acceptable tolerance = (allowable error - expanded uncertainty)/2 = (0.004-0.0007)/2 = ±0.0017mm?
Jen Kirley
Hello QCJS,
I don't have the MSA Manual in front of me, but I do have NIST Handbook 44 - 2015. It says (page 6)
Tolerances are performance requirements. They fix the limit of allowable error or departure from true performance or value.
In other words, acceptable distance from zero. If I understand your tutor's math correctly, the tolerance would expand if the instrument was found to have greater error during calibration. Why would we want that?
Can you tell us your indicator's make and model? They might make recommendations in a manual.
dwperron
Range = 0 to 0.2mm
Pls help. Thanks,
QCJS
This string has confused me for several days now.
I'm not sure what you mean by "Acceptable Tolerance", and what Acceptable Tolerance is used for in your application.
For instance, in your Dial Test example it would seem logical me that the Allowable error is what the manufacturer has determined to be the Tolerance of the device. I am not sure how to make the leap to what is an "Acceptable" tolerance.
QCJS
Hi dwperron,
I may have confuse Allowable error with Acceptable tolerance too. It's because I couldn't find anything on the Internet or the Forum that defines Acceptable tolerance. And my cal cert only shows me this info.
If I say that Acceptable tolerance is Allowable error, and "Allowable error is what the manufacturer has determined to be the Tolerance of the device", why is there a need to send my Dial Indicator for yearly calibration? There must be something on the cert that determines Acceptable tolerance of a device. Maybe I need to compare a value (I don't know which) on the cert with the Allowable error, if the value is less than Allowable error, then the Allowable error becomes my Acceptable tolerance? I'm not sure too. I'm totally clueless at this.
I hope someone can help me clear this doubt because I'm the only one in charge of the equipment's calibration
QCJS
Hi Jen,
Mine's a Mitutoyo Dial Indicator. Model: 513-405-10E, 0 to 0.2mm graduation
dwperron
Hi Jen,
OK, now I'm really confused!
Here is what Mitutoyo gives for their Indication Accuracy Specifications:
From this chart comes this interpretation:
The Indication Accuracy (Tolerance) from 0 to ±20µm (0 to ±10 divisions) is ±1 division (± 2µm)
From 20 to 200 µm the Indication Accuracy is ± 2 divisions (± 4µm)
On top of these linearity specifications there is also a specification for hysteresis (± 3µm or ± 1.5 divisions)
There is a repeatability specification of ± 1µm (± 0.5 division)
These are what you are calling the "Allowable tolerance". These will not change with calibration - these are what the manufacturer claims as the accuracy they built into the tool.
These are the tolerances you would be verifying with your calibrations. These are the accuracies you can expect when you make measurements.
You need to get your indicator calibrated at regular intervals because there is the chance, however small, that something could be damaged in the mechanism and the results you get may be out of tolerance.
Ninja
Looking for Reality
Hope I don't derail a good discussion...but I'm getting confused by terminology here...
I can't see that being a good path...
I heartily agree with what Jen said...in the book quote: "Tolerances are performance requirements. "
Allowable tolerance, assuming this means "Pass" criteria for calibrating the gage, should be based on what the parts being measured require.
If I used the above gage in question to measure something with a +/- 15mm tolerance, why would I care at all what the gage manufacturer claims?
Am I just lost in the terminology?
dwperron
I think we are all muddling through terminology on this, maybe with some language issues to boot.
I was basing my response on this statement:
"There must be something on the cert that determines Acceptable tolerance of a device. "
Looking at the example of the calibration cert data in the original post I left totally confused as to what the actual tolerance was.
When he produced the model number of the indicator I was able to get the actual specs from Mitutoyo.
Even those were really fuzzy on how they were intended to be interpreted - not good for a spec sheet and very odd for Mitutoyo.
As for your use example, yes, you can certainly derate the specs from the manufacturer's, as long as you identify the indicator as having a Limited Calibration, or somehow assuring that it was only used on that one measurement,
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
C Acceptable NDC for %GR&R part inspection to Tolerance (%Tolerance) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Non Acceptable % Tolerance Result - Decrease Sorting Limits Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Maximum acceptable Tolerance - Uncertainty Ratio (TUR) General Measurement Device and Calibration Topics 2
J Acceptable Tolerance Range for Freezer - Writing an IQ/OQ for a Freezer US Food and Drug Administration (FDA) 2
I What does 25% of the acceptable tolerance in ANSI Z540 mean? Measurement Uncertainty (MU) 12
D Interesting Discussion Is "rounding" acceptable when measuring parts? Tolerance Limits - What is acceptable? Quality Tools, Improvement and Analysis 72
J LTPD (Lot Tolerance Percent Defective) vs. AQL (Acceptable Quality Level) Definitions AQL - Acceptable Quality Level 5
L AQL (Acceptable Quality Level) vs. LTPD (Lot Tolerance Percent Defective) AQL - Acceptable Quality Level 12
Eva lee Which is the range for the validated batch size(for example ±5%, 10%) is acceptable? Manufacturing and Related Processes 8
S Examples of FDA acceptable Software Design Specification (SDS) Medical Device and FDA Regulations and Standards News 6
W Misinterpretation of requirement acceptable as root cause? Problem Solving, Root Cause Fault and Failure Analysis 19
M Are Fungal counts acceptable in class 1000 clean rooms? Other ISO and International Standards and European Regulations 2
T ISO 14971-2019 doubt - Evaluate if estimated risks are acceptable ISO 14971 - Medical Device Risk Management 9
samer Acceptable limits for Spills - Tracking Hydraulic Spills ISO 14001:2015 Specific Discussions 3
V Acceptable maximum RSD (relative standard deviation) for an sample size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q Acceptable calibration accuracy of a 60" linear measuring device General Measurement Device and Calibration Topics 16
F It is acceptable moving remote locations staff to manufacturing plant for auditing? IATF 16949 - Automotive Quality Systems Standard 3
Q Is it acceptable to mix components from two different lots into an assembly? ISO 13485:2016 - Medical Device Quality Management Systems 1
D Risk Register - have we considered enough and is the format acceptable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K Operator Checks - How to show that they were completed on a checklist as acceptable IATF 16949 - Automotive Quality Systems Standard 2
C Example Work Instruction/Procedure for AQL (Acceptable Quality Level) AQL - Acceptable Quality Level 4
S Dates on Labels acceptable to the USA - GS1 General Specification 3.4.4 Other US Medical Device Regulations 3
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
W Unattached (stand-alone) Forms acceptable for AS9100C? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
V Why Gauge R&R 10% is acceptable for variable instruments ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
X Acceptable methods to store and archive records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Is it acceptable to audit to the Nuclear Principles? Quality Manager and Management Related Issues 9
I Is it acceptable it is to list new products under an existing 510(k)? Other US Medical Device Regulations 14
S If this EN ISO 11137 certificate acceptable for Contract Sterilization? ISO 13485:2016 - Medical Device Quality Management Systems 2
D What is satisfactory & acceptable for Coliform - Staphylococcus - Hands and Surfaces Food Safety - ISO 22000, HACCP (21 CFR 120) 3
S Is a Dynamic Controlled Form acceptable per 21CFR820 Document Control Systems, Procedures, Forms and Templates 3
C Lowest Acceptable Grade for Master Gage Set Calibration and Metrology Software and Hardware 1
B Digital Signature Solutions acceptable to use in an FDA Medical Device Environment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J Is a ndc less than five is also acceptable? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T Technical regulations that determine the acceptable limits of cigarettes General Measurement Device and Calibration Topics 4
L IEC 60601-1 3rd edition Clause 9.2.2 Trapping Zone (Acceptable Gaps) IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
N Is it acceptable to sterilize products without claiming and labeling "sterile" ? ISO 13485:2016 - Medical Device Quality Management Systems 6
M Quality Objectives - Acceptable Levels and Functions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
C What is an acceptable bioburden level or count when working in cleanroom ISO class7 ISO 13485:2016 - Medical Device Quality Management Systems 1
D Is embedding documents within a Contract an acceptable practice ? Contract Review Process 9
F ANSI ASQ Z1.4 - Is the following process acceptable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Is it acceptable to have an ASL for Critical suppliers alone? Supplier Quality Assurance and other Supplier Issues 4
S Is this Quality Policy acceptable in the context of ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 24
A Help with acceptable screw gage values per standard BS 919 for Go/ No Go gage General Measurement Device and Calibration Topics 4
S What are typical Acceptable Quality Levels (AQL) adopted in Food industry? Food Safety - ISO 22000, HACCP (21 CFR 120) 1
somashekar Who can provide a WHO GMP certificate in India acceptable to the CDSCO Other Medical Device Regulations World-Wide 6
D Root Cause and Corrective Action - Is our Practice Acceptable? ISO 13485:2016 - Medical Device Quality Management Systems 5
