usual its defined as...
< 10% acceptable gage
10-30 marginal
> 30 unacceptable;
since this is coming from engineering/automative industry, My assumption is that this is for simple direct measurements, such as dimensions check using screw gauge, verniers, or temperature, pressure check using appropriate gagues?
The question is,
does the same acceptance criteria apply for complex analysis (involving multiple steps); viz., analytical methods in pharmaceutical world involves each analysis for
standard :- weight - dilution - response of UV -
test :- weight - dilution - response of UV - comparison with Std response.
I was trying to discuss same on separate thread.....
http://elsmar.com/Forums/showthread.php?t=62417&page=2
thank you
10-30 marginal
> 30 unacceptable;
The question is,
thank you
