Acceptance Criteria - ISO 9001:2008 Clause 8.2.4 - Questionable Audit Finding?
#22
There's an issue here which is being lost - what's the point of doing the check? If it is to give confidence that the item meets spec, it was measured and a value derived, then write it down! If it was gauged, the result is in the calibration records, so we're speaking to variables now.
If there's no purpose in recording it for analysis and action, then there's no point in making the measurement - just go ahead and make the part! However, if the operator needs to know 'where' the part lays in terms of the spec, then record it.
BTW - Wes, the 'tech' of the place doesn't matter if you don't know the capability of the machines to hold a feature. I worked in such a 'hi-tech' shop - it didn't mean we were clever at using data! I'm also very familiar with the terminology and purpose. Doesn't make any difference when it comes to recording data...
Big Jim
#23
Although you have a point here Andy, you, as was the auditor, are going beyond the requirements of the standard.
For that matter, even beyond both standards. What the auditor wrote doesn't fly with AS9100C either.
The aerospace enhancement on this point is 8.2.4c and is as follows "required records of the measurement results (at a minimum, indication of acceptance or rejection)"
A sign off is a record of acceptance, pure and simple.
The only need for recording the actual numerical results is for first article (in aerospace), if a customer requires it, or if you as a shop have determined that you need to do so.
To the OP. The auditor was wrong unless you did not have some criteria present to check to. If you did, you should protest this finding. It has no substance.
#24
So, what happened to one of the 8 principles? Factual approach to decision making? http://www.iso.org/iso/iso_catalogu...ip_standards/quality_management/qmp/qmp-7.htm
Jen Kirley
Quality and Auditing Expert
#25
My understanding of First Piece is that it's the first in a process following a setup, tool change etc. As such, of course an inspection should take place and it makes sense to record its actual results - that is, if you want to know anything besides good/bad.
Inspection is so often treated like an accept/reject chore that it becomes hard to understand the point of taking down the data. Maybe you don't ever go back to learn something from the data. Maybe the customer doesn't ever ask for it. But the standard is written in such a way to allow for the potential of either or both occurring at some point (maybe we want to more tightly control our processes or eliminate causes when investigating a string of rejects) and our setting up a robust enough system to provide us the information to use as a tool if and when we want it.
It may help to consider the standard was written for industry, in which so many different manufacturing organizations would use it; the principle is to do the robust right thing, not just basing our process controls on what the customer asks for.
Big Jim
#27
Please remember that first piece is not a requirement of ISO 9001:2008 or for that matter AS9100C. Don't confuse first piece with first article.
AS9100C does require a first article inspection (7.5.1.1) on a representative sample of the first production run and any time something changes that invalidates the original first article. ISO 9001:2008 does not have that requirement.
Customers can, of course, require first article inspection even if the standard doesn't. They can even require the stricter use of AS9102 which has more requirements for first article than AS9100C.
Jen Kirley
#28
Yes thank you, that's why I described "first piece" the way I did. No it's not specifically required - but it's being done anyway, perhaps as a good practice or a simple step to avoid making a bunch of scrap after a tool change.
And, since the inspection is being performed and the first piece accepted (as a part of the informal sampling plan) it does qualify to be an inspection, monitoring the process as per 8.2.3, "demonstrating the process's ability to achieve planned results." If that wasn't the intended purpose of the inspection, I'd like to be corrected but if I was auditing I would then ask how 8.2.3 is being done, if not through inspection.
So, since it is an inspection I would expect it to adhere to 8.2.4.
I think the center of our discussion is the defense of doing only what the standard/customer requires, versus the kind of good practices that can actually help us keep tight control of our processes and improve our bottom line. The standard is designed to provide a framework for a management system to do that, not just provide a set of requirements to be met.
#29
Excellent question. Irrelevant to what is at hand. Simply a red herring.
Now show me where it is in ISO 9001:2008 or AS9100C.
So, Jim. As a Certification Body auditor, the fundamental principles on which ISO 9001 is built are a "red herring" and "irrelevant"? You, as an auditor, never let them enter into the thought process of evaluating a QMS for effectiveness?
I wonder, then, if so deemed irrelevant to a question about ISO 9001, why did the folks at TC 176 write the 8 Principles? Do you know more than they do?:popcorn:
Big Jim
#30
Perhaps you would like to tell us, and while you are at it, explain why they left it out of the standard. I have not found any material on the topic. If you have some, please share it, but open another thread to do so.
My comment on irrelevance only applies to the discussion at hand. You have broadened it far beyond there. A discussion of the eight principles don't belong in a discussion about requirements of the standard when they are not addressed in the standard. That's what made it a red herring. Attempting to amplify the red herring does not remove it. It is nothing more than a continued attempted of a smoke screen. Creating a bigger diversion is just that, amplifying the diversion.
Let's stay on topic.
A Risk Acceptance Criteria in ISO 14971 ISO 14971 - Medical Device Risk Management 19
Q How to meet Clause 7.1.2 Acceptance Criteria in ISO TS 16949 IATF 16949 - Automotive Quality Systems Standard 7
Q Sampling Plan Acceptance Criteria - ISO TS 16949 Clause 7.1.2 IATF 16949 - Automotive Quality Systems Standard 8
I ISO/TS-16949 Technical specification - What is the International Acceptance Criteria IATF 16949 - Automotive Quality Systems Standard 2
M ISO 9001:2000 quality objective vs acceptance criteria ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D What are the acceptance criteria/requirements for Stability Study? General Measurement Device and Calibration Topics 7
O GR&R Acceptance Criteria Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Shore A hardness Tester Acceptance Criteria Standard Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
lanley liao Purchase Acceptance Criteria - Tensile testing Oil and Gas Industry Standards and Regulations 2
R Procedure, Frequency and Acceptance Criteria for Replicate, Recalibration, Before-After and Intermediate Checks ISO 17025 related Discussions 8
S Acceptance criteria for gauges General Measurement Device and Calibration Topics 8
M Characterization Testing - NO acceptance criteria, no minimum performance requirement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J AIAG PPAP: 2.2.11.3 Acceptance Criteria for Initial Study (page 9, 4th edition) APQP and PPAP 1
C FDA on changing acceptance criteria re: analytical method validation US Food and Drug Administration (FDA) 1
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
P Medical Device Validation Protocols and Reports - Acceptance Criteria Other Medical Device and Orthopedic Related Topics 3
C Software Unit Acceptance Criteria (5.5.4) IEC 62304 - Medical Device Software Life Cycle Processes 3
J Acceptance Criteria in 8.1.1 e) of IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
O Acceptance criteria bacterial endotoxins immunosera for human use Manufacturing and Related Processes 3
I As a part of validation, should i include the acceptance criteria of CPk index >1.33? Qualification and Validation (including 21 CFR Part 11) 4
V Acceptance Criteria Gage R&R - Simple vs Complex Techniques Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
A 5.5.3 - Software Unit Acceptance Criteria (Risk Control Measures) IEC 62304 - Medical Device Software Life Cycle Processes 3
M Establishment of Acceptance Criteria for a Weigh Balance General Measurement Device and Calibration Topics 3
X How to define Calibration Acceptance Criteria General Measurement Device and Calibration Topics 3
P Gage R (no reproducibility) - Acceptance Criteria Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
V Validation Test and Acceptance Criteria for Compressed Air Qualification and Validation (including 21 CFR Part 11) 3
I Dual Acceptance Criteria: Cpk and Individual Values Statistical Analysis Tools, Techniques and SPC 3
L Acceptance Criteria for External Calibrated Standards IATF 16949 - Automotive Quality Systems Standard 1
G Acceptance Criteria when Verifying a Gauge General Measurement Device and Calibration Topics 2
D Renault Painting Defect Acceptance Criteria Manufacturing and Related Processes 4
B Surface Roughness Tester Acceptance Criteria Calibration Frequency (Interval) 4
H Package Integrity Testing Acceptance Criteria ISO 13485:2016 - Medical Device Quality Management Systems 3
D 21 CFR 820.80 In-Process Acceptance Criteria requirements for IVDs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S Acceptance Criteria for Scratches on Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 3
JoCam Nadcap AC7120 (Audit Criteria for Circuit Card Assemblies) - Acceptance Criteria AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J IPC-A-610 E Thermal Plane Acceptance Criteria for D-Pak Component Other ISO and International Standards and European Regulations 2
S Acceptance Criteria at Design Verification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P Labels - ASTM D3330/D3330M Acceptance Criteria for Adhesion 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
optomist1 Tensile Test Crimped Electrical Terminal Acceptance Criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
V The approach/criteria of setting Acceptance Limits Method Validation Parameters Statistical Analysis Tools, Techniques and SPC 1
6 Acceptance Criteria For pH Meters and other Laboratory Equipment Measurement Uncertainty (MU) 16
V How to define Risk Acceptance Criteria? ISO 13485:2016 - Medical Device Quality Management Systems 3
Rameshwar25 Acceptance Criteria for Attribute MSA Study Effectiveness Summary Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D What are API Equipment Cleaning Requirements and Acceptance Criteria? US Food and Drug Administration (FDA) 3
V How are the Acceptance Criteria for Content Uniformity & Dissolution Superior? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
1 Acceptance criteria and related standard for 1 micron Lever Type dial Indicator General Measurement Device and Calibration Topics 5
M Acceptance Criteria for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Acceptance Criteria for Calibration by an External Calibration Laboratory General Measurement Device and Calibration Topics 9
