Acceptance Procedure for Receiving Calibrated Equipment & Tools
Q
QualityDeb
I've been instructed to create a procedure for the inspection and approval of calibration certificates received from outside cal labs. About to start my normal google search but thought I'd start here first. I don't know if other companies I have worked for had one or not. Since there is not much to it other than verifying info and acceptance, it should not be too difficult. Maybe it should roll into an encumbersome procedure to include the process of monitoring calibration records, sending out equipment and tools, etc... but Boss always says K.I.S.S. ... any thoughts?
Q
QualityDeb
Re: Procedure for receiving Calibrated Equip & Tools
How about just a checklist of what is to be checked/verified?
A checklist would certainly work to make sure everything coming back from cal lab is checked and verified but there should be a procedure that includes filling out the checklist. Right now we have added that a signature and date of acceptance is required on the cert as it s rec'd and the certs are in a book to show proof. But still, a procedure is needed. Anyone have one out there that I could see as an example?
Howard Atkins
Forum Administrator
The checklist is a work instruction in itself:agree1:
Why do you need a procedure to explain how to complete a form!:bonk:
What you do need though is to ensure that you have acceptance criteria. ISO 17025 labs do not say OK/NOT OK unless you define for them the acceptance criteria. I have seen many companies accepting certificates as OK without checking the readings.
Q
QualityDeb
We might be one of those companies, We are new to ISO and I'm finding a lot of gaps. I have only been with the company for a short time and I just inherited the whole calibration responsibility. I've never been involved with Calibration beyond checking for equip due, so I'm learning on the fly.
The certs state accuaracy either as a +/- measurement or MFR spec along with data sheet showing nominal-as found-as left-min-max and a check mark to show "in tolerance". Is this the acceptance criteria you speak of?
Auditors ask "Where's your procedure that tells you how to do that?" So "I've been trained to do so" is most always acceptable? Then you have to show evidence of training? Training record? I seem to get caught up in the procedure vs. training part of ISO.
So... anyone have any sample Cal. acceptance checklists out there that may give me a clear idea of what to create and include?
I appreciate all help I receive from everyone on Elsmar..... and Lord knows, I need all the help I can get.
BradM
Actually, I believe you have made a good observation on this.
I have discovered that "Review" means different things to different people. for some, it means just making sure a date, signature, and no blank spaces and such are on the form. Others, they check procedure, proper training level, legible values, etc.
I check all the above, plus applicable standards and procedures, assure printed data aligns with as found/as left statements from vendor, uncertainty/standards used information, etc.
This is just my opinion, and we all know what they're worth.:D I think it's worth having a procedure for standards. That one procedure addresses who do you send it to (approved vendors), how it should be packaged (very important for standard instrumentation), marking instrument out for calibration, checking equipment in, reviewing documentation, assessing out of tolerance condition, and returning to active service. The procedure can be very short, but at least you have a guidance document where everyone is doing it the same.
Then, you could (if you chose) have a checklist, router, etc. for the instrument when it is returned.
Whether you have a procedure or checklist is totally up to you, but assure that everyone is doing it consistently, and that the calibration certificates are being verified for the information essential to assess fitness for use, and potential non-conformity impact.:)
Q
QualityDeb
Thanks Brad M for your opinion... it kind of goes back to my original post, a procedure that includes all aspects of Calibration process but keep it short and sweet... a short little training class to go over the procedure and BAM done.... Back to searching for exsisting procedures to get ideas of what mine should say.... :tg:
zac2944
Did you ever find an example or come up with a procedure?
I'm in the same boat. I got a NADCAP finding because of a calibration cert error that should have been caught at Quality Approval, but certs are being signed and accepted without a complete review. Part of my corrective action is to write a procedure and train on how to review certs.
Q
QualityDeb
I did get one from one of our other facilities.... I'm not sure how to post it here??? I can do that after I remove names and logos... and figure out how to do it...
R Procedure, Frequency and Acceptance Criteria for Replicate, Recalibration, Before-After and Intermediate Checks ISO 17025 related Discussions 8
S Lot Acceptance Procedure - Material Acceptance Procedure for the supply department Supplier Quality Assurance and other Supplier Issues 3
P New Tooling Approval Process Acceptance Procedure - Injection Molding - Thermoforming Manufacturing and Related Processes 4
R Procedure for "Customer Acceptance of a design or process change" Design and Development of Products and Processes 12
L Definition ATP (Acceptance Test Procedure) vs. QTP (Qualification Test Procedure) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
U Zero Acceptance number procedure for Attribute Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D What is the acceptance criteria/requirement for Stability Study? General Measurement Device and Calibration Topics 3
K How can Acceptance Number and Reject Number be larger than Sample Size on Z1.4 Table? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
O GR&R Acceptance Criteria Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Shore A hardness Tester Acceptance Criteria Standard Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
lanley liao Purchase Acceptance Criteria - Tensile testing Oil and Gas Industry Standards and Regulations 2
M Informational US FDA Final Guidance – Acceptance Review for De Novo Classification Requests Medical Device and FDA Regulations and Standards News 1
S Boeing D6-51991 Product Acceptance Software certificate and Artefact? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
W Customer Signature / Acceptance Service Reports Service Industry Specific Topics 2
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
S Acceptance criteria for gauges General Measurement Device and Calibration Topics 8
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
M Characterization Testing - NO acceptance criteria, no minimum performance requirement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J AIAG PPAP: 2.2.11.3 Acceptance Criteria for Initial Study (page 9, 4th edition) APQP and PPAP 1
C FDA on changing acceptance criteria re: analytical method validation US Food and Drug Administration (FDA) 1
M Informational USFDA Final Rule – Human Subject Protection; Acceptance of Data From Clinical Investigations for Medical Devices Medical Device and FDA Regulations and Standards News 0
M Informational USFDA Guidance – Acceptance and Filing Reviews for Premarket Approval Applications (PMAs) Medical Device and FDA Regulations and Standards News 0
C Acceptance-Support Testing? Quality Tools, Improvement and Analysis 4
K Defining Acceptance Quality Level, I need clarity on AQL 1.5, 2.5, 4.0 AQL - Acceptable Quality Level 5
M Acceptance of remote auditing techniques - Can you help me with my research? General Auditing Discussions 0
K Guard-banding and relaxed acceptance for dimensional gauges General Measurement Device and Calibration Topics 1
E IPC/WHMA-A-620C: Requirements and Acceptance for Cable and Wire Harness Assemblies Other ISO and International Standards and European Regulations 2
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
P Medical Device Validation Protocols and Reports - Acceptance Criteria Other Medical Device and Orthopedic Related Topics 3
J ISO 9001:2015 Cl. 8.7.1 d) Obtaining Authorization for Acceptance under Concession ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
P Setting Acceptance Quality Limits (AQL) for New Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
C Software Unit Acceptance Criteria (5.5.4) IEC 62304 - Medical Device Software Life Cycle Processes 3
J Acceptance Criteria in 8.1.1 e) of IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
O Acceptance criteria bacterial endotoxins immunosera for human use Manufacturing and Related Processes 3
I As a part of validation, should i include the acceptance criteria of CPk index >1.33? Qualification and Validation (including 21 CFR Part 11) 4
V Application and differences of OC Curve and Acceptance Sampling Statistical Analysis Tools, Techniques and SPC 2
V Acceptance Criteria Gage R&R - Simple vs Complex Techniques Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
bio_subbu USFDA issues draft Guidance on the Acceptance of Medical Device Clinical Data Other US Medical Device Regulations 1
A 5.5.3 - Software Unit Acceptance Criteria (Risk Control Measures) IEC 62304 - Medical Device Software Life Cycle Processes 3
M A Question on EASA's "Release and Acceptance of Components" EASA and JAA Aviation Standards and Requirements 2
M Establishment of Acceptance Criteria for a Weigh Balance General Measurement Device and Calibration Topics 3
L Choosing the correct Distribution for Acceptance Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
X How to define Calibration Acceptance Criteria General Measurement Device and Calibration Topics 3
T Scoring 8Ds for Acceptance/Rejection Nonconformance and Corrective Action 6
G Need help on Device Description in the Acceptance Checklist for Traditional 510(k) Other US Medical Device Regulations 2
P Gage R (no reproducibility) - Acceptance Criteria Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
