There is a filter to be connected to a suction system for the obvious reason, to protect the suction system from microbial contamination. The vacuum system works without the filter too. So, if we consider "protecting the system from contamination" as "Augmenting its performance" according to the screenshot from this guidance, can we consider it as an accessory!
If it is an accessory then in normal cases it shall be classified together with the parent device! But I couldn't find it in the following definition. Or it is just a component as the user shall keep replacing it frequently!
Whether it is an accessory or just a component, can it be sold in the US just by following registration listing option without its parent device which is also a 510k exempt class II device!
