Accuracy class for gauges - Class 1,0 gauges - NS-5504 (Norwegian Standard)
G
Gandi
I have a lot of Class 1,0 gauges. According to NS-5504 (Norwegian Standard) the maximum deviation during calibration is 0,8% F.S. But, what do you do if you have a gauge that, during calibration, is only 1,2% F.S. Which will give it Class 1,6. Do you recommend the customer to throw it away? Or do you give the customer a certificate stating the class and results without saying more to the customer? Or do you put a sticker on the gauge, stating its new class?
Regards,
Anders
jfgunn
This is a great question.
The ISO 17025 standard would have you report the measurments with uncertainties. The decision to pass or fail would be completely up to the customer.
In the real world, customers want to know if a gage passes or fails. Another issue is how you take measurement of uncertainty into account when making the Pass/Fail decision.
We take these situations on a customer by customer basis. We give the customers the following options:
1.) Pass / Fail based upon readings only while ignoring uncertainty.
2.) Readings and uncertainties only with no pass/fail statement.
3.) Pass/Fail based upon readings where the pass window has been expanded by a value equal to the uncertainty.
4.) Limited Calirbation where a gage is said to meet a different class and this new class is indicated on the calibration certificate. When choosing this option for plugs and rings customer need to let us know if we can change a gage from a Master (Bi-lateral tolerance) to a GO or NOGo as needed. You need to know what is more important. Would they rater have a Class X Master or a Class XX GO?
Whatever you do, you should spell out the options to the customer and let him/her decide. Just get your options and their response in writing.
You could also specify what your standard practice would be when quoting the customer.
Hope this helps.
G
Gandi
My "problem" is that the customer is inhouse..... I'm running the calibration lab in our company, and calibrate a lot of gauges for another department. The gauges are mounted on equipment which is sent offshore. I'm sure none of the guys offshore look at the certificate. So, if a gauge had an accuracy of 5% instead of 0,8%, they wouldn't know....... So my option is to either throw the gauges in the thrash, or change the class by putting a sticker on the gauge notifying the users of the new class. I'll ask the person in charge.
But, is it an accepted practice to change the class of a gauge to a poorer one? I.e. from class 1,0 to class 1,6?
Thanks,
Anders
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
D ISO/TS 16949 Compliant Surface Plate Class and Accuracy IATF 16949 - Automotive Quality Systems Standard 2
D How to Compute the Accuracy Class for a Weighing Scale? General Measurement Device and Calibration Topics 4
R Primary Weighing Stone - M1 Accuracy Class - Clarification required General Measurement Device and Calibration Topics 7
J Setting accuracy limit for a read out General Measurement Device and Calibration Topics 4
R Clinical accuracy and repeatability of IR(infrared) thermometer, no maximum error criteria is recommended in ISO Other Medical Device Related Standards 11
R SAT (System Accuracy Test) temperature according to AMS2750E AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
shimonv IEC 60601-1 Essential Performance - Is the signal accuracy specification an essential requirement? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
G Posting Measuring Equipment Accuracy for User Information General Measurement Device and Calibration Topics 4
S Gagemaker MT-3000 accuracy for calibration Calibration and Metrology Software and Hardware 2
J CMM Accuracy Formula General Measurement Device and Calibration Topics 3
L Calibration Accuracy In Relation To Reporting General Measurement Device and Calibration Topics 1
Q Acceptable calibration accuracy of a 60" linear measuring device General Measurement Device and Calibration Topics 16
M Calibration certificates avowing accuracy beyond the uncertainty limits? Measurement Uncertainty (MU) 7
S Jewelry vs. Normal Laboratory Balances - Accuracy and calibration General Measurement Device and Calibration Topics 2
T Tape Measure, the right device for 2 or 3 decimals accuracy on prints General Measurement Device and Calibration Topics 8
W Equipment for Oven Calibration, Uniformity and System Accuracy Tests AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Opinions on the "Best" CMM for High Accuracy Machining General Measurement Device and Calibration Topics 9
Q AMS 2750E System Accuracy Test (SAT) Frequency AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Process to Validate the Accuracy of Test Reports (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 38
D AMS 2750E - Digital Instrument Calibration Accuracy Requirements General Measurement Device and Calibration Topics 1
shimonv Soldering Station Accuracy out of specification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Help trying to explain accuracy procedure General Measurement Device and Calibration Topics 1
D Long length measurement of 18" up to 100" with an accuracy of .005 min General Measurement Device and Calibration Topics 8
N Cry for help - FDA calibration requirement for accuracy & precision General Measurement Device and Calibration Topics 2
C Accuracy Equation - Linear gage with a stated accuracy of (1.5+L/50) ?m L= mm General Measurement Device and Calibration Topics 5
I UUT Accuracy as part of Uncertainty Budget Measurement Uncertainty (MU) 6
A Uncertainty Measurement - What this accuracy specification "1% + 10^5": means? General Measurement Device and Calibration Topics 2
L Inspection Equipment Accuracy - Measuring the diameters of small holes Measurement Uncertainty (MU) 5
E How does Non-Linear UUT affect TAR (Test Accuracy Ratio) Calculation? Measurement Uncertainty (MU) 3
G Digital Autoclave Accuracy Requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
S AMS 2750E Heat Treat Furnace System Accuracy Test SAT Report question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Accuracy for electrosurgical analyzer General Measurement Device and Calibration Topics 2
A Calculating Accuracy for a Multimeter General Measurement Device and Calibration Topics 1
D Verification of weighing scale 150kg capacity 0.05g accuracy General Measurement Device and Calibration Topics 9
A Accuracy Calculation of Leakage Current for an Electrical Safety Analyzer General Measurement Device and Calibration Topics 5
G Laser Precision Linear Measurement - Inherrent Accuracy of 10 -6 - Nice PDF Paper General Measurement Device and Calibration Topics 1
S Stated Accuracy of Portable CMM Arm and Real World Use Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
A Intrinsic Uncertainty and Accuracy of a Medical Electrical Safety Analyzer General Measurement Device and Calibration Topics 1
V CMM plane construction method types and accuracy differences for measuring Pos Tol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Weighing Balance Accuracy for Plastic Moulded Parts variation study Manufacturing and Related Processes 3
G Best X-Y Microscope Stage for Submicron Accuracy Capability, Accuracy and Stability - Processes, Machines, etc. 2
K Wilson Hardness Tester Model 525 Accuracy/Repeatability issues help General Measurement Device and Calibration Topics 4
P Measurement Uncertainty and Equipment Accuracy Measurement Uncertainty (MU) 2
C Basic Internal Calibration Procedure to check the Accuracy of a Balance Calibration Frequency (Interval) 6
C Accuracy Problem on the Calibrator - Two Labs with different Results General Measurement Device and Calibration Topics 7
R How do I extend Correction factor of Calibration cert to compute instrument accuracy Measurement Uncertainty (MU) 1
