Accuracy Problem on the Calibrator - Two Labs with different Results
Calsun
Hi all,
I?m new guy for working with calibration laboratory. Now I have a question to enquiry expert to solve my problem.
The question is that, we have a calibrator for external calibration in each of year. It?s calibrated by Manufacturer (Lab A). Now, due to the cost problem, we have selected another Lab B for doing calibration on this year. After calibration from Lab B, they points out some of test point were out of manufacturer?s stated 1-year relative accuracy limits. However, Lab A was no problem in the past.
Does anyone know what the problem here is? Both lab A and B are accreditation laboratory. Why their result has such as big difference? How can we judge which lab has problem?
Thanks.
Jerry Eldred
There is not a definitive easy answer. It could have been out of tolerance the second year. If it is a certain high quality brand name calibrator - okay, I'll go ahead and say it - if it is a Fluke calibrator and you sent it to their standards lab, I have great trust in them. If it is a high quality OEM (Original Equipment Manufacturer) lab in the first attempt at calibrating your calibrator, I would call into question the second lab's assessment. If Lab A was a lesser quality OEM calibration standards lab, that may call them into question.
There is always also the possibility that your calibrator went out of tolerance.
If you don't feel comfortable putting actual details on the forum, that is understandable. If you wish, you may send me a PM with actual manufacturer and lab names, along with what was out of tolerance, and I can give a more detailed opinion.
BradM
Just a few thoughts in addition to the ones from my esteemed colleague from Texas. :bigwave:
Jerry is right; the instrument might have just been out of tolerance. But your situation is one I have seen before. Consider...
1. Two labs may have different uncertainty calculations. The Lab B may have a larger uncertainty than the mfg. and thus, may have more error contributing to the measurement.
2. Unless two labs use the identical procedure for calibration, it may be that the error was detected using a different method/ test points than was used at the mfg.
I have seen some 3rd party calibrations that I had more confidence in than the mfg. However, some mfg. have a pretty decent metrology program, with many of them being accredited under ISO 17025.
All that said, it would be difficult (I think) to say the Lab B calibration is suspect just because they found the instrument out of tolerance. I would be more interested in determining if Lab B is competent.
Murphys Law
How much is it out of calibration by? If marginally over, it maybe within measurement uncertainty.
Jerry Eldred
Good point Murphy's Law. Depending on how far out of tolerance the calibrator is, this may not even be an issue (although the normal requirements for how you deal with an out of tolerance measurement standard is its own issue - potential implications to instruments calibrated by it - another topic).
Calsun
Thanks for all.
I have uploaded the error comparison table for both Lab. Please see attachment.
I have missing one point to mention that the Lab A was calibrated and do with adjustment for each time and Lab B haven’t done for this issue due to have not software for doing that. And then, checked the report, the uncertainty of Lab B is smaller than Lab A.
Question:
1) Does anyone know how to determine the problem? What kind of method can I to do?
2) Could the uncertainty larger than error?
3) How can i ensure the history of stability is not broken when the calibrator was adjusted and calibrated at each time?
And the last, since I’m new guy for touching the DMM calibration, does any expert have some reference book to recommend for me?
Thank you very much for all.
P.S. The attachment file of the Uncertainty for Lab A have some thing wrong. the correct value is 2.6ppm + 1.4uV for 100mV to 200mV range and 200V to 1000V is 3.3ppm.
Jerry Eldred
The amount of errors does not strongly point to either lab being bad. One good way to establish which one is bad - if either - would be to re-send the calibrator back to lab A and have them re test the measurands in question. Or find a third lab to send to and have it re-tested. You need to have confidence that were ever you are sending your calibrator, you are getting legitimate readings. If you are strongly concerned about a quality issue with one or both of the labs, you could communicate your concern with either or both of them.
There is a definite possibility that neither lab is bad. Something could have happened during the year that shifted the output of the calibrator.
Also, if it is one of the Fluke series multifunction meter calibrators, there is a zero adjust done after warm up that could possibly cause a shift. I don't know if that would indeed be the issue, but one of the possibilities.
I guess I would like to know the names and locations of the two labs, and models of the calibrators. It is understandable if you don't want to publicly post those names - and I wouldn't post the names either. But I could take a look at their accreditation information and maybe have some more ideas. I would not share any information publicly.
J Setting accuracy limit for a read out General Measurement Device and Calibration Topics 4
R Clinical accuracy and repeatability of IR(infrared) thermometer, no maximum error criteria is recommended in ISO Other Medical Device Related Standards 11
R SAT (System Accuracy Test) temperature according to AMS2750E AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
H Analog Pressure Gauge with no EN837 accuracy class information General Measurement Device and Calibration Topics 5
shimonv IEC 60601-1 Essential Performance - Is the signal accuracy specification an essential requirement? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
G Posting Measuring Equipment Accuracy for User Information General Measurement Device and Calibration Topics 4
S Gagemaker MT-3000 accuracy for calibration Calibration and Metrology Software and Hardware 2
J CMM Accuracy Formula General Measurement Device and Calibration Topics 3
L Calibration Accuracy In Relation To Reporting General Measurement Device and Calibration Topics 1
Q Acceptable calibration accuracy of a 60" linear measuring device General Measurement Device and Calibration Topics 16
M Calibration certificates avowing accuracy beyond the uncertainty limits? Measurement Uncertainty (MU) 7
S Jewelry vs. Normal Laboratory Balances - Accuracy and calibration General Measurement Device and Calibration Topics 2
T Tape Measure, the right device for 2 or 3 decimals accuracy on prints General Measurement Device and Calibration Topics 8
W Equipment for Oven Calibration, Uniformity and System Accuracy Tests AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Opinions on the "Best" CMM for High Accuracy Machining General Measurement Device and Calibration Topics 9
Q AMS 2750E System Accuracy Test (SAT) Frequency AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Process to Validate the Accuracy of Test Reports (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 38
D AMS 2750E - Digital Instrument Calibration Accuracy Requirements General Measurement Device and Calibration Topics 1
shimonv Soldering Station Accuracy out of specification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Help trying to explain accuracy procedure General Measurement Device and Calibration Topics 1
D Long length measurement of 18" up to 100" with an accuracy of .005 min General Measurement Device and Calibration Topics 8
N Cry for help - FDA calibration requirement for accuracy & precision General Measurement Device and Calibration Topics 2
C Accuracy Equation - Linear gage with a stated accuracy of (1.5+L/50) ?m L= mm General Measurement Device and Calibration Topics 5
I UUT Accuracy as part of Uncertainty Budget Measurement Uncertainty (MU) 6
A Uncertainty Measurement - What this accuracy specification "1% + 10^5": means? General Measurement Device and Calibration Topics 2
L Inspection Equipment Accuracy - Measuring the diameters of small holes Measurement Uncertainty (MU) 5
E How does Non-Linear UUT affect TAR (Test Accuracy Ratio) Calculation? Measurement Uncertainty (MU) 3
G Digital Autoclave Accuracy Requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
S AMS 2750E Heat Treat Furnace System Accuracy Test SAT Report question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Accuracy for electrosurgical analyzer General Measurement Device and Calibration Topics 2
A Calculating Accuracy for a Multimeter General Measurement Device and Calibration Topics 1
D Verification of weighing scale 150kg capacity 0.05g accuracy General Measurement Device and Calibration Topics 9
A Accuracy Calculation of Leakage Current for an Electrical Safety Analyzer General Measurement Device and Calibration Topics 5
G Laser Precision Linear Measurement - Inherrent Accuracy of 10 -6 - Nice PDF Paper General Measurement Device and Calibration Topics 1
S Stated Accuracy of Portable CMM Arm and Real World Use Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
A Intrinsic Uncertainty and Accuracy of a Medical Electrical Safety Analyzer General Measurement Device and Calibration Topics 1
V CMM plane construction method types and accuracy differences for measuring Pos Tol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Weighing Balance Accuracy for Plastic Moulded Parts variation study Manufacturing and Related Processes 3
G Best X-Y Microscope Stage for Submicron Accuracy Capability, Accuracy and Stability - Processes, Machines, etc. 2
K Wilson Hardness Tester Model 525 Accuracy/Repeatability issues help General Measurement Device and Calibration Topics 4
P Measurement Uncertainty and Equipment Accuracy Measurement Uncertainty (MU) 2
C Basic Internal Calibration Procedure to check the Accuracy of a Balance Calibration Frequency (Interval) 6
R How do I extend Correction factor of Calibration cert to compute instrument accuracy Measurement Uncertainty (MU) 1
P Measurement Equipment - 10:1, 4:1 - Is it resolution or accuracy General Measurement Device and Calibration Topics 1
S Accuracy of a Measurement Device Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Simpson 260 Series 8 Equipment Accuracy General Measurement Device and Calibration Topics 5
H Accuracy and Precision of Test Equipment required? General Measurement Device and Calibration Topics 2
