Accurately measuring Full Thread Length
Hello All,
I am currently in a discussion with one of my supplier's in regards to measuring Full Thread Length on an external Thread. The Supplier is currently placing the Thread Gauge onto the external thread, and once it bottoms out, they are measuring from the bottom of the gauge to the top/bottom of the external thread.
I disagreed and stated that to measure the Length of the Full Thread, you have to begin at the "Peak" of the first full thread and measure to the "Peak" of the last full thead to get the accurate length.
My question is. Am I 100% accurate? Or is my supplier? I cannot find any tools/diagrams online to depict where to begin/end when measuring Thread Length. Any insight or help will be greatly appreciated.
Thank you.
What caused the question to come up? What is the exact specification?
Hi Jim,
There is a min thread length callout of 8.5mm on the drawing. Our Supplier is stating their results are 9.2~9.5
From my measurements I am seeing 8.2~8.5 So some are undersized, or just at min.
And of course, measurement method is playing a role in this scenario. I just want the measurements to be accurate and go from there.
Tidge
My reference copy of ASME B1.3 (I'm not sure if you are referring to screw threads or not) reads:
5(b) The gaging system used to inspect/evaluate the screw thread of a threaded product shall be as specified in the product standard, procurement drawing, or purchase inquiry and order. In the absence of a specified gaging system on the purchase order, product drawing, or other applicable documentation, the supplier and customer must agree uopn a suitable gaging system. There is no implied default gaging system.
I found the following in my reference copy of the Machinery's Handbook (under structural bolts, I didn't dig any deeper... it would help if you described the application or some standard terminology... you could be thinking about pipe threads!)
Basic thread length, LT, is a reference dimension, intended for calculation purposes only, which
represents the distance from the extreme end of the bolt to the last complete (full form) thread.
Currently we are measuring using an Optical Comparator, First Full Thread Peak to last Full Thread Peak.
Application is Automotive. External Mounting Thread. With a min Thread Length of 8.5mm.
normzone
What really matters the most is what the end use of this piece is, and how it's mating components dimensions are called out and toleranced.
If everything will go together just fine regardless of small differences in measurement technique, then we're just splitting hairs for purposes of training and discussion.
If the assembly actually may or may not function due to potential interface issues, THEN this is not a drill, this is the real thing. Good engineers design their assemblies such that minor deviations from print won't affect the ability of the assembly to reliably go together and function reliably. But they don't always have that luxury when they work in confined spaces or with thin materials.
Do you have the luxury of knowing how this part gets used, and how much this matters? Or is it just a deliverable, and meeting print is all you have to work to?
Tidge
I'm never going to argue against the concept that parts should have specifications that meet their intended use, but we shouldn't pretend that their aren't century-old standards. The customer and the supplier may have to co-educate each other and come to an agreement on many things; I highly recommend that they agree on an established standard rather than develop their own.
According to my copy of the Machinery's Handbook, ASME B1.7-1984 (R2001) includes the following definitions:
Length of Complete Thread: The axial length of a thread section having full form at both crest and root but also including a maximum of two pitches at the start of the thread which may have a chamfer or incomplete crests.
Length of Thread Engagement: The length of thread engagement of two mating threads which may have a chamfer or incomplete crests.
In the case described, it sounds like the area of disagreement may be with the start of the thread with incomplete crests.
Although it's unlikely that the quoted bits have changed, the current version of ASME B1.7 is 2006. If the ASME standard (or any other published standard) calls for more than is necessary, it's best that it gets settled between the two parties in the most convenient manner.
Ninja
Looking for Reality
There's the point. Who is 100% right or wrong has little value. Clarifying what is needed, and whether the supplied parts meet that need needs to be the main and only point.
What method was intended to be used when the spec was written in the first place?
J Linear measuring device that can accurately measure 0.00001 or better - Suggestions? General Measurement Device and Calibration Topics 10
V How to accurately measure Internal Thread Pitch Capability, Accuracy and Stability - Processes, Machines, etc. 8
Y Accurately applying a specific clause to a Non Conformance Internal Auditing 10
C Gage pin calibration procedure for accurately calibrating gage pins General Measurement Device and Calibration Topics 18
D Micrometer that will read accurately to .00001 inch - Seeking General Measurement Device and Calibration Topics 11
J Register of the monitoring and measuring equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B Risk analysis for defective measuring or measuring equipment out of calibration General Measurement Device and Calibration Topics 2
R Tools used for measuring (New to metrology) General Measurement Device and Calibration Topics 9
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
R ULM Measuring Pressures General Measurement Device and Calibration Topics 1
M Missing measuring equipment General Measurement Device and Calibration Topics 6
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
K Measuring Function MEDDEV 2.1/5 relation with MDD 93/42/EEC CE Marking (Conformité Européene) / CB Scheme 2
M Measuring FIM (TIR) - Two inside diameters - Conflicting readings between inspectors Manufacturing and Related Processes 1
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D ASTM C1064 Temperature Measuring Device General Measurement Device and Calibration Topics 2
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
V Ammeter calibration - Measuring head (on pic.) problem General Measurement Device and Calibration Topics 1
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A CE mark - Measuring Instruments Directive confusion! CE Marking (Conformité Européene) / CB Scheme 0
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
E ISO 13485 7.6 Control of monitoring and measuring equipment - Assess the Validity ISO 13485:2016 - Medical Device Quality Management Systems 4
D Measuring fine tubing (< 0.100") "Wall by weight" General Measurement Device and Calibration Topics 11
G Posting Measuring Equipment Accuracy for User Information General Measurement Device and Calibration Topics 4
S ISO 9001 7.1.5.2 - Actions Taken When Measuring Equipment is Found to be Unfit for Use General Measurement Device and Calibration Topics 13
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
S Calibration - Isolated current meter - Measuring patient auxiliary leakage current Calibration and Metrology Software and Hardware 4
G Measuring customer parts on a CMM - How many decimals to report to the customer? ISO 17025 related Discussions 28
qualprod Complying with ISO 9001:2015 - 9.1.1 b - Monitoring, measuring, analyzing and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Tagin Measuring supplier quality with small quantities Statistical Analysis Tools, Techniques and SPC 10
G Uncertainty of staging a short line scale standard on longer measuring machine? Measurement Uncertainty (MU) 4
U Measuring a Golf Club Face/Grip/Shaft Rotation General Measurement Device and Calibration Topics 7
Q Acceptable calibration accuracy of a 60" linear measuring device General Measurement Device and Calibration Topics 16
H Measuring Design Process Design and Development of Products and Processes 4
C AS9100D 7.1.5.2 / Calibration of Employee Owned Measuring Equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Effectiveness Measuring and Efficiency Measuring In ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
johnny johnson New measuring equipment selection (Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Cleanrooms - Particle Measuring - ISO 14644 Other Medical Device and Orthopedic Related Topics 3
S IOQ protocol for a Micro-Vu measuring system - Is a PQ required? Qualification and Validation (including 21 CFR Part 11) 2
K ISO 13485:2016 Cl. 4.2.3 - Determine QMS Processes, Monitoring, Measuring, etc. ISO 13485:2016 - Medical Device Quality Management Systems 4
L Radius Measuring Tools General Measurement Device and Calibration Topics 4
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J IATF 16949 Cl. 7.1.5.2.1 - Gauges (Measuring Jigs) Calibration/Verification Records IATF 16949 - Automotive Quality Systems Standard 6
Claes Gefvenberg Worst measuring equipment ever? Coffee Break and Water Cooler Discussions 6
J Measuring an Untrue Radius - Metal Stamped and Formed Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
A Calibration Interval - AS9100 - Control of Monitoring and Measuring Equipment Calibration Frequency (Interval) 8
