Action on Quality Records - Approve, Update and Carry Out Revision Control
alvisan
“For implementing ISO9001:2000, we must approve, update and carry out revision control on all quality records. It is because record is a type of documents”. Right? Wrong?
Colin
Re: Action on Quality records
Firstly, the term 'quality record' is old terminology. It was used in previous versions of ISO 9001 but is now referred to simply as 'records'. Is that important? well, I think it is as people tended to think only of records of inspection and the like whereas it should be any records generated by the QMS.
Next, there is often confusion between records and documents. I talk about records being 'dead', they are 'past tense' whereas documents are 'live' and often need keeping 'alive' by applying document control to them.
Records can be very important to the organisation and therefore have to be looked after by filing, protecting and defining retention periods for them. However, they do not require document control in the same way as documents do.
RoxaneB
Change Agent and Data Storyteller
To add on to Colpart's response, if you're are talking about records - that is forms which have information on them - then what he said is great. If, by record, you are talking about the blank form, you should:
  • Understand the difference between a form and a record
  • Control forms like work instructions, procedures, etc., to ensure that everyone is working on the same revision.
Wes Bucey
Prophet of Profit
Actually there may be a simpler way to keep terminology accurate:
Documents can be be divided into two main categories:
  1. Active documents which usually describe an action to be taken in the future (one second or one century in the future)
  2. Static documents (records) which describe an action already taken in the past (one second or one century in the past)
Since the action documents describe something in the future, they can be changed or revised according to an organization's own procedures. A part of "control" for active documents is keeping the revisions straight and not mixing them up.
Since the static documents describe something in the past (history), they should not be changed. Sometimes, though, the history may be amended by adding new information from time to time (a production log?)
Forms versus documents versus records
Most organizations follow this usage:
"document" is the generic term for active documents, static records, and blank forms used as a template to complete either an active or a static document.
"Form" is a blank template, waiting for data to be filled in either for activity to take place in the future or as a history record of activity that has already taken place.
To add to the mix, "document" does not mean ONLY PAPER documents. Documents may exist only in electronic form, but they are still "documents" - this post is document, even though it exists only in electronic form [unless you print out a copy!]
Colin
And of course (just to confuse things further) a document (e.g. a form) becomes a record when is is filled in with data!:confused:
RoxaneB
:) Wes, I was attempting to keep my answer short and to-the-point as my gut says that our Original Poster's first language is not english. And I didn't wish to repeat what Colpart had already said (aligned with your response)...merely add on to it. :)
curryassassin
I thought the same thing when I read Wes's contribution.
I teach that a record is created when we have to write down or capture electronically, information or data. This includes completed forms, reports, spreadsheets, databases.
Usually a document (policy/process/SOP/work instruction) tells us to record the info/data.
RoxaneB
I am, by no means, lessening the value of Wes's contribution. It is full of valuable information to the Original Poster. Perhaps I'm just in more of a to-the-point mood today. ;)
But sometimes they should be changed in order to correct errors. This is why some level of control of records is important. That control can be accomplished in the form of explicitly defining when such changes are permissible, how they are to be carried out (so as to leave a trail), and by whom. How customers are to be notified when changes are made should also be explicitly defined.
Wes Bucey
Prophet of Profit
It may sound like Abbott and Costello doing "Who's on First?" but this is absolutely right if it is data of an activity that has been performed. It may be only a document if it is data filed in on a form for an activity yet to take place (like filling in an Engineering Change Order Request.):lmao: Isn't this nit picking about terminology frustrating?:frust:
A Corrective Action for lost project quality records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C I need your help to find the action plan for these quality objectives Misc. Quality Assurance and Business Systems Related Topics 23
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
qualprod Is a Corrective Action Expected if a Quality Objective is not in compliance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
T Corrective Action for Quality Objectives which are not Measureable Nonconformance and Corrective Action 7
N Statistical Quality Improvement Action for Small Batch Production Statistical Analysis Tools, Techniques and SPC 17
J Quality Meeting With Employees as a Recommended Action FMEA and Control Plans 3
J Corrective/Preventative Action External - Corporate Supplier Quality Responsibility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Corrective Action Importance Level - Cost and Quality - The Johari window Nonconformance and Corrective Action 4
P Corrective Action Plan in Molding Company (Quality Assurance) Nonconformance and Corrective Action 6
ScottK Quality Manual Replacement Action Plan from EU Pressure Equipment Directive Compliant Quality Management System (QMS) Manuals 4
A Quality Objectives ISO 9001:2000 - Is an action plan required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K Corrective Action (CA) Form that non-quality folks can understand Document Control Systems, Procedures, Forms and Templates 6
D Quality Management Book On Capa (Corrective Action Preventive Action) Book, Video, Blog and Web Site Reviews and Recommendations 4
Marc Quality Systems Supervisor given a Nonconformance and Request for Corrctive Action Nonconformance and Corrective Action 36
P Setting Cleanroom Alert and Action Limits Manufacturing and Related Processes 0
A Preventive action tool Preventive Action and Continuous Improvement 7
L Principles of operation vs Mode of action EU Medical Device Regulations 6
Y Is preventive action required for each CAPA initiated? ISO 13485:2016 - Medical Device Quality Management Systems 24
M Root Cause and Corrective Action for CAPA's lacking validation/verification ISO 13485:2016 - Medical Device Quality Management Systems 19
A What activities are included in the action of marketing you medical device in U.S.? Medical Device and FDA Regulations and Standards News 1
G Kpi doesn't show action plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
G During internal audit - finding poor action plans ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
H Ever given an Operations Manager an internal Corrective Action Request? Nonconformance and Corrective Action 5
B Human error corrective action 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
S Record of Disciplinary Action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
G Use of Supplier's Corrective Action Form vs. Corporate Form Supplier Quality Assurance and other Supplier Issues 4
M Corrective action for a defect from customer's mistaken Nonconformance and Corrective Action 1
Q Corrective action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
H Streamlining audit response and corrective action processes ISO 13485:2016 - Medical Device Quality Management Systems 9
Q Corrective Action Notification - Registration Audit ISO 13485:2016 - Medical Device Quality Management Systems 12
S I need help in corrective action plan Nonconformance and Corrective Action 15
B VDA 6.3 Action needed score 8? VDA Standards - Germany's Automotive Standards 2
B NADCAP Rejection Response to Root Cause Analysis and Corrective Action. Nonconformance and Corrective Action 1
S Maintenence related action in Control plan FMEA and Control Plans 3
T Continual Improvement as Result of Corrective Action? Preventive Action and Continuous Improvement 32
3 Non-conformance Register vs Corrective Action Register ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A Corrective Action Training ISO 13485:2016 - Medical Device Quality Management Systems 1
R Not every INCIDENT report will lead to a corrective action EU Medical Device Regulations 7
V ISO 10360-5: 2020 Gap analysis and Action plan Excel .xls Spreadsheet Templates and Tools 1
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
I Setting action completion dates Nonconformance and Corrective Action 3
A Medical device Mode Of Action CE Marking (Conformité Européene) / CB Scheme 2
D Corrective Action Timing - IATF CB Deadline IATF 16949 - Automotive Quality Systems Standard 2
R AS 9100D - Containment and Corrective action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
