Good Day All,
Earlier this week you may have had a Microsoft update/fix that affected your active X controls. Here is the solution we found.
Attached you will find a batch file made to fix the ActiveX problem. A user must shut down all MS Office applications then run the batch file and it will delete the 2 bad exd files. As far as I can tell Microsoft has still not sent out a fix.
Needless to say the batch file is very fast since it is just deleting 2 files.
Del %userprofile%\AppData\Local\Temp\VBE\MSForms.exd
Del %userprofile%\AppData\Local\Temp\Excel8.0\MSForms.exd
Gotta Love little Billy boy and his marry band of misfits.
Hope this helps,
Hope this helps,
