"Actual" Audit Results Required?
#11
Andy, Ajit, Samsung and JaneB,
Thanks for the replies.
We are not yet at a point in our quest to have any good metrics on our audits, but it seemed to me that there should at least be some documentation in the management review as oppossed to just "results were discussed". I know that in our walk throughs that a few items have popped up more than two or three times.
We have a management review meeting this week and I am going to bring up the subject. We'll see what the QA manager and upper management think.
I liked the point about too much jargon, detail, etc. Just the concise facts.
Thanks.
Bill
Bill:
There may be a clue to the frequency of audits or management reviews here. Often audits are done too infrequently or reviews too frequently to assist management getting a 30,000 ft look at the system and its effectiveness.
I'd suggest that if you can't 'tell' if the processes are performing as planned, and are in compliance to the defined system, then one (audits) or other (reviews) - or both - might need to be looked at before you go much further. There's a 'sweet spot' to be hit here...
JaneB
#12
Sometimes it's quite enough to simply note that 'results were discussed' (assume results were good). Other times the 'documentation' may be quite clear in that an Action would (or should) be raised from the management review - delegated to someone to follow through, etc.
Audit trail.... if the meeting records make it clear which audits were discussed (name/number/whatever), and the audit reports themselves clearly report whether there were issues or not, then if there were any issues on those reports (internal or external audits) that need further action, I'd expect some kind of record of that in the MR minutes/actions/whatever. If the minutes just note 'discussed' without action for a problem, that's a symptom of ineffective review for a start.
And yes, if a few items have popped up a few times... that's a symptom of a recurring problem.
JaneB
#13
:topic:
I am sharing a template of MRM, which I had downloaded from the internet couple of months ago.
Ajit, I know some people like this kind of template. I loathe them, because they're structured and written around the exact clauses and terminology of the ISO 9001 Standard. I'd much, much rather see one that was clearly based on the client's own terminology, topics and order of business. And I argue you're much more likely to get really effective MR in such a case.
Ajit Basrur
#14
Thats true Jane but in the absence of one, many MRMs go off tangent. This is identical to use of audit checklists :)
W
winchm
#15
The Internal Audit Plan should include the elememts (or clauses) and processes on schedule to be included in the audit.
The internal auditor is responsible to execute the audit as assigned to her/him.
The internal auditor records the elements audited for the processes assigned and documents the non-conformances if required, reviews root cause analysis and CAPA submitted by auditee, verifies NC is closed within the specified time and does follow-up to confirm CAPA was effective.
There should be a matrix for the Internal Audit and record of the internal audit completion within the specified time in Audit Plan.
A summary report on the Status of the QMS should include any
1.) major deficiencies that may affect the System, Product or service.
2.) opportunities for improvement
3.) action items from audit reports
4.) status of Internal Audit completion as planned, the number of elements audited and a simple trend analysis of number of NCs per element and process (AKA Area)
The summary report is prepared by either the Internal Auditor, Lead Auditor, or ISO Management Rep. The ISO Management Rep should present the Summary report to top management at management review.
The summary report should be concise - if a registrar or customer audits Management Review process and has a question she/he can review the Internal Audit Process - or visa versa.
I have MS Office 2003 and prefer not to install software to open 2007 MS docx, pptx, etc. but I'm sure it reads like the standard. That's all folks, :agree:
JaneB
#16
Winchm, where are you getting all these 'shoulds' from? And the detailed prescriptions for what 'should' be contained in an audit report? Because they most certainly are not written in the Standard itself.
I presume you are describing how you do it in your particular system/organisation. But much of what you say is not necessarily something that 'should' be done in every organisation.
Much, much better to stick strictly with what the Standard itself says shall be when we attempt to talk about what 'should' be done by everyone'!
howste
Thaumaturge
#17
I agree with Jane. What you're describing can be good practices, and may be very effective if implemented well. Rather than stating they "should" be done, you can state that you prefer to do it that way, and then describe the reasons (benefits) for doing it that way.
W
winchm
#18
Whoa - I think the Post Title is misleading - it is about Management Review and recording of audit results for MR.
I was responding to Willyboy, a new Internal Auditor who was questioning whether the Management Review input by the current Quality Manager was sufficient. Willy wanted to know if the internal audit results maintained by the Quality Manager in his own files and office should be included in Management Review – I, like others suggested an internal audit summary.
Others attached presentations which I couldn’t open, but I suspect they gave an example of how the Audit results are summarized. The following is an example of a Management Review Agenda that I had on file but is not verbatim. Clauses 5.6 Management Review, 5.6.1, General, 5.6.2 (inputs) and 5.6.3 (outputs)
• Continuing suitability, adequacy & effectiveness of Quality System
• Audit results (internal, customer and third party)
• Customer feedback (c-sat & loyalty results)
• Process performance and product conformity (including CoPQ)
• Status of corrective and preventive actions
• Changes that could impact the quality management system
• Recommendations for improvement (collaborate for best practices)
• Progress toward quality objectives (improvement plans)
• Follow-up on any actions assigned during previous management review
I could not answer Willy directly other than to give advice as what to look for in both the management review process and the internal audit process. I use the word should as this is what I would look for in MR and IA processes. I do not use the word Shall as I am not quoting or writing the standard – merely answering a newbie’s query on what he should look for when auditing management review and performing an internal audit.
:2cents:
JaneB
#19
This often happens (misleading titles) but then, I think it's to be expected a bit - it's often hard to think up the 'exact right' title when creating a new post.
Winchm, I think it's great that you're aiming to help and I encourage you to continue to get involved and do so!
And I'm not attacking you, but I am taking issue with perhaps the way you expressed what you said. I don't want to split hairs, but there's very little real difference in meaning between shall and should. And to me, when I see /hear someone saying 'this should happen and this should be like so' in a professional context, I think they're quoting some authority (standard, legislation, contractual, policy) etc that means 'it must be like this'. So to me, it didn't read so much as you offering advice 'here's how we do it, and this is why we do it', but just making blanket pronouncements 'it must be like this' without any reasoning given. I therefore return to the authority (the Standard), compare that with what you said, and disagreed.
You see, I know that lots of other people read along in threads - or may do so days, weeks, even months from now, so if I read something that I think is inaccurate or misleading, I query it or say a bit. (Sometimes more than a bit).
May I respectfully suggest, as Howste did, that it's much more helpful if you're offering advice / describing your own way of doing things to make that clearer, rather than using the 'it should be' form?
There's several good reasons for this. One is that if you keep saying 'should', you're very likely to encounter quite a few opinions to the contrary, such as mine for example ;)
But far more importantly, by offering reasons for why, you help improve understanding by others, as well as foster a spirit of sharing and healthy, open, professional debate. Which is strongly encouraged in the Cove.
Hope this clarifies for you.
that it
... imerely answering a newbie’s query on what he should look for when auditing management review and performing an internal audit.
This wasn't my understanding of what was asked by the OP (original poster).
R GM Layered Process Audit - Seeking the actual General Motors requirements Process Audits and Layered Process Audits 36
D From the date of your audit, how long did it take to get the actual certificate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
J Is Device Tracking Card an actual requirement under FDA regulation? Other US Medical Device Regulations 0
K Legal manufacturer vs Actual manufacturer EU Medical Device Regulations 4
R Regulatory Affairs Certification (RAC) prep - Practice test versus actual exam Professional Certifications and Degrees 1
J Supporting functions with no actual activity started IATF 16949 - Automotive Quality Systems Standard 2
P Large data sets of continuous individual data - Estimated or actual deviation Capability, Accuracy and Stability - Processes, Machines, etc. 2
H In-house device calibration record - Actual values obtained required? General Measurement Device and Calibration Topics 9
J How to verify the actual capacity of suppliers Supplier Quality Assurance and other Supplier Issues 3
I Class I Medical Device Accessory with Actual Risk EU Medical Device Regulations 7
D Referencing Standards in Procedures - Current version or actual? Document Control Systems, Procedures, Forms and Templates 6
D Actual Definition of Non-Contact for ISO 10993 Other Medical Device Related Standards 1
B Does an ?Rx Only? medical device require an actual medical license from the buyer? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 16
P Is it a rule to fill in all the 5 why in order to get the actual root cause? Quality Tools, Improvement and Analysis 5
L How to represent the ?real? or ?actual? players in organizational chart? Misc. Quality Assurance and Business Systems Related Topics 3
R [Minitab] DOE Output vs. Actual Data Using Minitab Software 6
D Can I use the % Tolerance to determine the actual process tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Q Is an actual document for Roles and Responsibilities necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B KPI = 0 - Accidents (Actual accident is 150 case/year) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
J Need help calculating actual Ppk - Result of % GR&R=11.8% when conducting MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
I Cpk < 1.33 - How do I estimate actual defects? Statistical Analysis Tools, Techniques and SPC 7
C Actual Standard Test Method for Alloy Chemical Analysis? Other Medical Device and Orthopedic Related Topics 3
V How to Calculate the Actual Productivity for Projects? Software Quality Assurance 2
S CQM/OE Certification - May 2010 - Exam preparation tips and actual exam experience Professional Certifications and Degrees 6
Buckyb AS9100 7.5.3 Identification and Traceability - Difference between actual and agreed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Actual Call Centre Conversations Coffee Break and Water Cooler Discussions 3
M Gage pin calibration - Actual calibration readings required on the calibration cert General Measurement Device and Calibration Topics 3
A Actual probability of TYPE I error for 3 sigma P-chart Statistical Analysis Tools, Techniques and SPC 10
N No Actual Field Failures (5 years) - Still need Analysis of Potential Field Failures? IATF 16949 - Automotive Quality Systems Standard 6
B Good Documentation Practice (GDP) - Actual Results (can they be typed)? US Food and Drug Administration (FDA) 2
C Control Plan - Links to Customer Documents (e.g. Print) or the Actual Specifications? FMEA and Control Plans 22
O Standard for the Content of Actual "Certificates"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Production schedule that adds actual value and makes sense? Manufacturing and Related Processes 2
W Actual examples of FMEA (DFMEA, PFMEA) for Car Assembly Process IATF 16949 - Automotive Quality Systems Standard 5
T How much actual documentation is required on Shop Traveler and Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Trying to find the actual ISO 17025:2005 standard requirements ISO 17025 related Discussions 6
A Internal Thread Inspection reference - Actual data vs. Thread Gage Various Other Specifications, Standards, and related Requirements 1
P Plug Gage Calibration Report does not include actual data - ISO 9001:2000 section 7.6 General Measurement Device and Calibration Topics 3
C Reporting As Found data - Actual before values or test points necessary? General Measurement Device and Calibration Topics 2
C Test records shall show actual test results data - 8.2.4.1 Inspection documentation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
P Analysis of actual and potential field failures - Clarification on clause 5.6.2.1 IATF 16949 - Automotive Quality Systems Standard 4
F Nonconformance dilemma - "Actual" nonconformance vs. "Indicated" nonconformance Nonconformance and Corrective Action 19
J What are the actual requirements for QSB? IATF 16949 - Automotive Quality Systems Standard 21
A Experimental research vs. Actual design of product - ISO 9001 Clause 7.3 Design and Development of Products and Processes 9
L Revision of procedure - Can't update the procedure before the actual process change Document Control Systems, Procedures, Forms and Templates 13
R Altering the Actual Date of the Management Review Meeting Minutes Management Review Meetings and related Processes 69
C Electronic Nonconformance and CAR signatures - Are actual signatures required? Document Control Systems, Procedures, Forms and Templates 2
D Micrometer Calibration - Seeking actual Calibration Procedure for 0-1" Micrometer General Measurement Device and Calibration Topics 19
C Turtle Diagrams - Seeking Examples with actual processes such as Contract Review Process Maps, Process Mapping and Turtle Diagrams 6
D TS 16949 5.6.2.1 - Input to Management Review shall include an analysis of actual... Management Review Meetings and related Processes 6
