Add Safety Policies/LOTO/etc. to Controlled Documents?
jbdominguez
I am responsible for both our QMS and HR/Safety (among other things), and I would like to know if it is appropriate to include our Safety policies, LOTO procedures, Hazard Communication, etc. as part of our controlled documents. We are ISO 13485:2003 Certified, with discussions on becoming ISO 9001:2008 Certified.
RoxaneB
Let me ask this...why wouldn't you?
I suggest that for the purposes of a business culture, drop terms like "quality management system" and "safety management sytem". Instead, adopt "business management system" or "<company name>'s management system".
Where is the value in having some procedures follow your document control process while others are outside of the system?
Does your company believe in keeping employees safe and having them return home at the end of the day?
Does your company understand the value of the document control process?
If your answers to above three questions are "there is no value", "yes" and "yes", then perhaps you've answered the question in your original post. :)
jbdominguez
Makes sense. When I came into the organization, the safety policies were separate. I just wanted to make sure that I was on the right track by wanting to control them as we do our manufacturing procedures. Thanks!
Sidney Vianna
Post Responsibly
In my experience, the reason most organizations avoid adding non-quality related requirements (e.g. occupational safety or waste management) to documents such as procedures, has to do with the "unfounded fear" that, if they add such requirements to a quality related procedure, an external auditor could audit against those requirements as well, when conducting an audit against ISO 9001 or ISO 13485, for example.
We have had this discussion many times in the past and auditors must stick to the scope of an audit, irrespective of the fact that an enlightened organization might have added non-quality related issues to a document. In other words, if I am conducting a QMS audit, I must NOT delve into non-quality related issues. Section 0.4 of ISO 9001 makes that very clear.
ScottK
Not out of the crisis
While I agree with Roxane (as I usually do) I have to point out that there is no requirement to do so.
I've had this conversation in just about every company I've worked for and it always just makes more sense to have a single document control system for all your documentation.
Having OSHA or DEP required documents in the control system does not mean that they will be audited by registrars or internal auditors... that is usually the fear. But ISO 13485 and ISO9001 auditors audit to a standard that doesn't include EHS stuff.
Having multiple doc control systems is like spending extra to have a PC for gaming and a Mac for multimedia... wait... I do that...:frust:
RoxaneB
Smart man! :D
True, there is no requirement. There is also no requirement for me to brush my teeth and hair in the morning before coming into work...but I do both. Why? (see next quote)
ScottK said:
...just makes more sense
However, as you and Sidney reminded the Original Poster...Scope! Not the mouth-wash, but the parameters/boundaries of the audit that should keep auditors in line.
qusys
It is your choice and you could evaluate the risk of not doing so, as well as pro's and con's.
If you want to pursue also OHSAS certification and ISO 9001, this could be an advantage. ISO9001 foresees document control procedure and even if there is no requirment for controlling safety procedures, policies and so on, you could think to create an integrated system that encopass all documentation that you esteem necessary for the functioning ofyour mgmt systems ( ISO 9001, ISO 14001,OHSAS 18001, ISO 13845...).:bigwave:
kgott
Does your company understand the value of the document control process?. :)
I find that an interesting question RCBeyette. Just checking for something I may not know here but apart from:
- preventing waste caused by using out of date documents eg specs
- an orderly and structured way of creating, issuing, changing, re-issuing and storing documents
- reducing time to access required documents used day-to-day
- as an aid in reducing various risks
- as an aid in learning from previous mistakes
is there any other advantages in controlling documents I can relate to other staff and management?
thanks
RoxaneB
thanks
Your list is a nice starting point, kgott, but focuses heavily on the benefits to the documents themselves. Let's expand upon "an aid in reducing various risks"...how would explain that to people in your organization?
Consider the following:
  • A tool to promote standardized application of tools/methods within activities (i.e., everyone should be doing it the same way with the same stuff)
  • Facilitates a common language within the organization. Everyone uses the same tools, methods, documents so that in multi-department meetings we're all speaking the same language of the organization.
  • Standardized training material - everyone is trained on the same material and the appropriate/applicable personnel are trained when there is a revision.
  • Having a robust document control system supports the documentation of best practices which, in turn, should guide people on how to achieve the goals of their performance metrics. (i.e., If you have documented practices but no metrics, how do you know if your practices are correct? If you have metrics but no documented practices, how to ensure people can achieve their goals?)
This does go slightly off topic from the original poster's request, but it is important for an organization to understand the importance of document control and how it fits into the concept of routine management (i.e., standardization (tools, methods, documents), training, application, results, failure analysis and assessing).
kgott
  • Having a robust document control system supports the documentation of best practices which, in turn, should guide people on how to achieve the goals of their performance metrics. (i.e., If you have documented practices but no metrics, how do you know if your practices are correct? If you have metrics but no documented practices, how to ensure people can achieve their goals?).
Thank you for adding to my knowledge store RCBeyette, much appreciated.
S Anyone Familiar with "SPC for Excel" add-in? Lean in Manufacturing and Service Industries 4
F How do you add accuracies for tools with different measurement devices? General Measurement Device and Calibration Topics 1
Q Add new action plans in CA, while waiting effectiveness - Same problem reappears ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M IATF 16949 - 8.5.6.1.1 Providing a list of process controls: Does this requirement add value to QMS? IATF 16949 - Automotive Quality Systems Standard 4
D FDA filing guidance to add sterilization step for approved drug Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
V How to Add Annual Revalidation requirements to Control Plan? FMEA and Control Plans 5
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
J What to add to our QMS for Clause 4 Context of the Organization AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
Q Really do they add value (Vision, Mission, Values)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Document Dame How to add AS9145 requirements to my existing AS9100 QMS? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 10
P Recommendations on SPC Software or Excel SPC add-in(s) Quality Assurance and Compliance Software Tools and Solutions 6
J Add API Q1 & Q2 to Quality Management System Standards Oil and Gas Industry Standards and Regulations 1
V Do I need to add everything on print to control plan? FMEA and Control Plans 1
T Holocene Epoch or add a new Anthropocene Epoch? Coffee Break and Water Cooler Discussions 7
smryan Seeking good 2D barcode add-in for Excel Excel .xls Spreadsheet Templates and Tools 6
S How to Add Water to a MDS Tree Structure RoHS, REACH, ELV, IMDS and Restricted Substances 4
P How to add Voip features (ring group, virtual receptionist) into Cisco SIP PBX in C#? Medical Information Technology, Medical Software and Health Informatics 1
J Exporting Add-On for Medical Devices to the US - FDA Requirements Other Medical Device Related Standards 3
R Regulation Process for Add on Accessory to an Existing Medical Device Other US Medical Device Regulations 1
L How to add a New Factory under a Prior 510K Establishment US Food and Drug Administration (FDA) 2
P Is a new 510k needed if modifying to add bluetooth for data transmission? Other US Medical Device Regulations 13
M Minitab macro to add reference line to graph Using Minitab Software 1
R How to calculate the value add time? Lean in Manufacturing and Service Industries 2
V Where to add SOP of writing a Technical File in ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 1
W Is a new 510(k) needed? Add Non Medical Device into a Medical Device App Other US Medical Device Regulations 13
M Why do I have to rev change my ASL everytime I add or remove a supplier? Quality Manager and Management Related Issues 6
T Distributor Value Add work to an AS9102 FAI part - Lubrication AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
D If a control operator add a photo as a visual aid, can you improve Occurrence? FMEA and Control Plans 12
S Annual Stock Check - Where to add it into our Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L 21 CFR Part 11 Requirements - Microsoft Excel Add-on Functions 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
H Need to add a concentrate (only) to an already approved IMDS Submission RoHS, REACH, ELV, IMDS and Restricted Substances 4
Z How to make documents have value or add value? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Chennaiite Value Engineering - Does Value Engineering really add value? Preventive Action and Continuous Improvement 3
CalRich Requirement from the PPAP Manual or from GM to add a PPAP Report with Shipment? Customer and Company Specific Requirements 1
somashekar Inspection vs. Inspectors - Inspection is essential but Inspectors do not add Value Manufacturing and Related Processes 14
S Value Add Time Calculation in Value Stream Mapping (VSM) Lean in Manufacturing and Service Industries 8
M Two situations where it is appropriate to add further Hazard Audits to Internal Audit Occupational Health & Safety Management Standards 8
T Updating to ISO 9001:2008 - I need to add section 7.3 Design and Development ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
A Learning Excel - Web Site, Book, and Add-in Recommendations Excel .xls Spreadsheet Templates and Tools 6
Stijloor Airlines add fees on top of fees!!! Travel - Hotels, Motels, Planes and Trains 0
Claes Gefvenberg Firefox Add-ons After Work and Weekend Discussion Topics 8
S COPQ (Cost of Poor Quality) - Can we add Premium Freight? Misc. Quality Assurance and Business Systems Related Topics 6
kedarg6500 Unit Conversion Add-in for Excel Excel .xls Spreadsheet Templates and Tools 7
G How do I add in the company we purchased and their products? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
V What are all the documents and records to be add for the management review meeting? Management Review Meetings and related Processes 6
M Keep current ISO 13485 registrar AND add new for CMDCAS ISO 13485:2016 - Medical Device Quality Management Systems 13
I Short SOPs (Standard Operating Procedures) or Add to Quality Manual? Quality Management System (QMS) Manuals 10
V When to add contents to Quality Manual amendment table? Quality Management System (QMS) Manuals 3
B When to add Special Characteristics to your drawing/print? FMEA and Control Plans 4
P Supermarket Evaluation Check list - Please add-on! Lean in Manufacturing and Service Industries 4
