Adding 1% error to data in a column in Minitab
Z
zak9000
Hi Guys
I am new to using minitab. At the moment i am trying to do perform a simple exercise. I column with 1000 voltage values. I know that the error associated with the voltages is 1%. Now I want to create another voltage column with the voltage+-1% voltage error.
so I went to calc and attempt to create an expression. I first began with:
voltage+(1/100*voltage)
but in this case i will always have the error added. Instead i am looking for something like:
voltage+rand(1,-1)*(1/100*voltage)
the rand function will generate a random number between 1 and -1. However unfortunately this function does not exist within the minitab calculator. Do you guys know of a simple way to create this function in minitab
reynald
You can compress this answer in 1 long formula but I will answer step by step so that it will be easier to follow.
1. Create a column that will contain your random numbers. Then to calc-->random data-->uniform
2. Then on the other column modify your formula to have an if condition:
if( random < 0.5, voltage+(1/100*voltage), voltage-(1/100*voltage))
Note: I don't have mintiab in my laptop now so I can't verify the syntax of the formula. But somehow that is the concept.
The beauty of this approach is that you can control the % (-) and the %(+). Just change this value:
reynald
As for this:
"rand function will generate a random number between 1 and -1",
use this transformation
-1 + random*2
or in generic form
min_value + random*range
U Adding another Subcontractor EU Medical Device Regulations 3
N Adding unclassified product to the medical device registration US Food and Drug Administration (FDA) 1
S Complexity Rating - CB adding another audit day for "high complexity" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
E Adding models to an approved Russian Registration Certificate Other Medical Device Regulations World-Wide 1
gunnyshore Adding a new facility - do I need to submit an amendment to the MDL or MDEL, or both? Canada Medical Device Regulations 3
D Adding a Class I to a sample box Canada Medical Device Regulations 5
K Adding the Notified Body Number CE Marking (Conformité Européene) / CB Scheme 2
O Adding ISO 13485 to an AS9100 QMS ISO 13485:2016 - Medical Device Quality Management Systems 13
P Adding "new" medical device to existing CER - under MDD CE Marking (Conformité Européene) / CB Scheme 1
F Adding a medical device in another medical device package EU Medical Device Regulations 2
K Relabeling or Not Relabeling - Adding our internal Part Number barcode label 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Adding Remote Site to Current IATF 16949 Certification IATF 16949 - Automotive Quality Systems Standard 2
S Adding Value prior to signing EASA Form 1 EASA and JAA Aviation Standards and Requirements 5
D Adding a new site to 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 4
S Adding claims on medical device labelling 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Adding a UDI Compliant Label to previously manufactured devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
P Adding an additional distributor to a current Mexico Medical Device Registration Other Medical Device Regulations World-Wide 0
4 Adding a new Company - ISO 9001 Design Exclusion Design and Development of Products and Processes 1
L IATF 16949: Adding a Remote Location between certifications IATF 16949 - Automotive Quality Systems Standard 2
T Adding an adapter to a Torque Meter to change the Range Capability, Accuracy and Stability - Processes, Machines, etc. 6
R Coexisting Investigational Use and CE-Mark - Adding a new Indication EU Medical Device Regulations 4
K Adding a New Site to Our ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 9
C Adding information to Labels - Class II Medical Devices US Food and Drug Administration (FDA) 1
K Medical device procedure tray - Adding products in Custom packs Other Medical Device and Orthopedic Related Topics 3
D Adding an extra Label on an Ethylene Oxide Sterilized Box ISO 13485:2016 - Medical Device Quality Management Systems 3
E Adding a "Scope Statement " to my Quality Policy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
W Quality for value adding or certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
somashekar Adding an other process into the system - Authorised Economic Operator (AEO) Scheme ISO 13485:2016 - Medical Device Quality Management Systems 4
M Is 510k Required for Adding a section on use of Disinfectants to Product Manual? US Food and Drug Administration (FDA) 3
D Adding PPAP forms to the ISO procedures Document Control Systems, Procedures, Forms and Templates 2
S FDA CDRH Premarket Review Submission Cover Sheet - adding more products 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B What to do when adding new Proprietary name under same 510(k) Other US Medical Device Regulations 2
M PPAP requirements when adding Part Transfer Robots between Machines APQP and PPAP 1
M Adding AS9100C Lead Auditor Certification to an IRCA ISO 9001 LA Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Need help in adding second location to FDA Registration Other US Medical Device Regulations 4
K Adding a Disclaimer on an FMEA FMEA and Control Plans 4
M Adding Bizminer's Industry Financial data to my Peer Company Comparison Manufacturing and Related Processes 0
D Rounding Numbers - Adding numbers in Excel - I want the average Excel .xls Spreadsheet Templates and Tools 3
F Implementing ISO 11135 - Facilities Conditions - Adding ETO Sterilization Other Medical Device Related Standards 4
Q Adding to our A2LA Scope of Accreditation General Measurement Device and Calibration Topics 2
A ISO 9001 company now adding Welding to the Scope - What needs to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
marmotte Adding a Funct. Earth. to a class II / BF device...retest needed? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Document Changes not affecting the process - Adding Logos, etc. Document Control Systems, Procedures, Forms and Templates 8
V Option for adding date-time to the copies printed from Adobe Acrobat (pdf) Quality Assurance and Compliance Software Tools and Solutions 1
V What are the Value Adding Quality Assurance Processes and how to measure them? Quality Tools, Improvement and Analysis 3
P Can 'adding a new service' be a Quality Objective? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K Quality System Manual question - Adding Satellite Facility ISO 13485:2016 - Medical Device Quality Management Systems 2
Q Adding Malicious Operator to FMEA? Quality Manager and Management Related Issues 12
F Adding a New Office Location to an ISO 9001 Certificate (Scope of Registration) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q Adding ISO13485 to existing AS9100 QMS - Summary of the differences ISO 13485:2016 - Medical Device Quality Management Systems 9
