It is true that the guidance was published in 2017, but this is still how FDA expects you to assess a change. The previous version of that guidance was published in 1997 and it was certainly active until the new revision was released. FDA just doesn't update guidances very much because the
regulation doesn't change. The "risk based assessment" methodology that they recommend is pretty timeless and could be applied to any technology.
I don't know all the details of your device but based on what you've already stated, the specific aspects that make me concerned about your scenario are:
1) introducing an app 2) change in the control mechanism as well as usability/user interface 3) adding compatibility with a different component/device 4) introducing new hazards (notably cybersecurity). These issues aren't related to Bluetooth as a technology, they are just fundamentally outside of the appropriate changes that you can document in a Letter to File.
1)
Use of an App is my biggest issue with this whole thing. If the app is being used to control a medical device, it is also then a medical device. This device will then have its own hazards/risk profile and its own unique regulatory concerns. You can absolutely introduce new devices via a letter to file, but in this situation I don't think there's a reasonable way to justify that adding a new software app is within the boundaries of your cleared device.
Significant risk is considered when it can affect safety but if the risk is mitigated, then it should not be considered a significant risk.
If the change adds a new hazard/hazardous situation/risk that didn't exist previously, risk mitigation does not change whether you have to submit a
510k or not.
You cannot justify that there is a new, significant risk but you've mitigated it appropriately and therefore no 510k. The only way to rationalize a change in risk profile is if the pre-mitigation risk level is negligible. Keep in mind that you need to assess the risk using ISO 14971 risk management processes, not a general assessment of the technology.
I use Bluetooth every day and I agree that, in general, it's a safe and normal technology and by itself it's low risk. But me and you agreeing on this doesn't actually mean that it's low risk in context of use in a device.
You can do whatever you want with your own device, but keep in mind that if you are MDSAP certified this will almost certainly come up in your next audit because they'll ask for a list of your changes/product launches and will go through your change assessment process and they will definitely be looking closely at how you determined if the change required a 510k or not.
