Adding a new site to 13485 Certification
Dobby1979
Hello all.
I was wondering if anyone had experience of adding a new site to their 13485 certification and in a short summery, what is required and a realistic timeline.
Example being; We currently hold 13485 certification and are looking to open a manufacturing plant in the US so our scope would need to change to incorporate them. Is it the same practice as gaining the original certification, e.g. Stage 1 and Stage 2 audits? Would 6 - 9 months be a realistic timescale for this?
Thanks in advance
L
lxuejing
Hi Dobby
Are all the machinaries in place and validated? How about the new clean rooms? likely onsite audit will be reqired. Try to talk to your NB and set up a schedule is important. We have recently added a new production isite n our lSO 13485 and It took more than a year via two on site audits.
Hope it is useful.
somashekar
Hello all.
Thanks in advance
Hi Dobby.
About the methodology for audit to certification., you have to discuss it with your CB.
Adding a new site is pretty straight forward. You have to have one QMS and common Management responsibility.
You have to determine which will be your lead site and which will be your other site / sites. The Lead site is usually where the major portion of the QMS activities will be performed. You have to determine how the activities of the clauses 6,7,8 will be deployed at each of the sites, describe them in the top level document, and begin to establish (Document, Implement and Maintain)
When you are ready with confidence and records of your internal audit and management review to backup, you can ask for the audit dates. Realistic timeline depends upon the size and structure of your organization, but within 12 months is good enough for most. Structuring the QMS and building the understanding across lead site and sites forms the key to success.
John C. Abnet
Teacher, sensei, kennari
Good day lxuejing. Has any consideration been given to simply gaining a new/separate certification specific to the new site instead of "scoping" it in with a location in a different country?
L
lxuejing
Hi John, l think it depends on the function of sites and the product range the sites are covering.ln our case, several manufacturer sites share the same design facility and produce the same type of the products, it makes sense to add the new manufacturer facility in current lSO 13485 certificate.
K Adding a New Site to Our ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 9
A Adding Remote Site to Current IATF 16949 Certification IATF 16949 - Automotive Quality Systems Standard 2
S Adding an additional site to our current TS 16949 registration scope IATF 16949 - Automotive Quality Systems Standard 5
U Adding another Subcontractor EU Medical Device Regulations 3
N Adding unclassified product to the medical device registration US Food and Drug Administration (FDA) 1
S Complexity Rating - CB adding another audit day for "high complexity" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
E Adding models to an approved Russian Registration Certificate Other Medical Device Regulations World-Wide 1
gunnyshore Adding a new facility - do I need to submit an amendment to the MDL or MDEL, or both? Canada Medical Device Regulations 3
D Adding a Class I to a sample box Canada Medical Device Regulations 5
K Adding the Notified Body Number CE Marking (Conformité Européene) / CB Scheme 2
O Adding ISO 13485 to an AS9100 QMS ISO 13485:2016 - Medical Device Quality Management Systems 13
P Adding "new" medical device to existing CER - under MDD CE Marking (Conformité Européene) / CB Scheme 1
F Adding a medical device in another medical device package EU Medical Device Regulations 2
K Relabeling or Not Relabeling - Adding our internal Part Number barcode label 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Adding Value prior to signing EASA Form 1 EASA and JAA Aviation Standards and Requirements 5
S Adding claims on medical device labelling 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Adding a UDI Compliant Label to previously manufactured devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
P Adding an additional distributor to a current Mexico Medical Device Registration Other Medical Device Regulations World-Wide 0
4 Adding a new Company - ISO 9001 Design Exclusion Design and Development of Products and Processes 1
L IATF 16949: Adding a Remote Location between certifications IATF 16949 - Automotive Quality Systems Standard 2
T Adding an adapter to a Torque Meter to change the Range Capability, Accuracy and Stability - Processes, Machines, etc. 6
R Coexisting Investigational Use and CE-Mark - Adding a new Indication EU Medical Device Regulations 4
C Adding information to Labels - Class II Medical Devices US Food and Drug Administration (FDA) 1
K Medical device procedure tray - Adding products in Custom packs Other Medical Device and Orthopedic Related Topics 3
D Adding an extra Label on an Ethylene Oxide Sterilized Box ISO 13485:2016 - Medical Device Quality Management Systems 3
E Adding a "Scope Statement " to my Quality Policy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
W Quality for value adding or certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
somashekar Adding an other process into the system - Authorised Economic Operator (AEO) Scheme ISO 13485:2016 - Medical Device Quality Management Systems 4
Z Adding 1% error to data in a column in Minitab Using Minitab Software 3
M Is 510k Required for Adding a section on use of Disinfectants to Product Manual? US Food and Drug Administration (FDA) 3
D Adding PPAP forms to the ISO procedures Document Control Systems, Procedures, Forms and Templates 2
S FDA CDRH Premarket Review Submission Cover Sheet - adding more products 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B What to do when adding new Proprietary name under same 510(k) Other US Medical Device Regulations 2
M PPAP requirements when adding Part Transfer Robots between Machines APQP and PPAP 1
M Adding AS9100C Lead Auditor Certification to an IRCA ISO 9001 LA Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Need help in adding second location to FDA Registration Other US Medical Device Regulations 4
K Adding a Disclaimer on an FMEA FMEA and Control Plans 4
M Adding Bizminer's Industry Financial data to my Peer Company Comparison Manufacturing and Related Processes 0
D Rounding Numbers - Adding numbers in Excel - I want the average Excel .xls Spreadsheet Templates and Tools 3
F Implementing ISO 11135 - Facilities Conditions - Adding ETO Sterilization Other Medical Device Related Standards 4
Q Adding to our A2LA Scope of Accreditation General Measurement Device and Calibration Topics 2
A ISO 9001 company now adding Welding to the Scope - What needs to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
marmotte Adding a Funct. Earth. to a class II / BF device...retest needed? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Document Changes not affecting the process - Adding Logos, etc. Document Control Systems, Procedures, Forms and Templates 8
V Option for adding date-time to the copies printed from Adobe Acrobat (pdf) Quality Assurance and Compliance Software Tools and Solutions 1
V What are the Value Adding Quality Assurance Processes and how to measure them? Quality Tools, Improvement and Analysis 3
P Can 'adding a new service' be a Quality Objective? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K Quality System Manual question - Adding Satellite Facility ISO 13485:2016 - Medical Device Quality Management Systems 2
Q Adding Malicious Operator to FMEA? Quality Manager and Management Related Issues 12
F Adding a New Office Location to an ISO 9001 Certificate (Scope of Registration) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
