Adding "new" medical device to existing CER - under MDD
PVC Barbie
I'm trying to determine the best route for adding "new" medical device to an existing CER and I'm hoping the technical writing experts have some suggestions. Writing/research for existing CER was outsourced about 18 months ago. Device is Class IIa under MDD.
The new device can be considered as an equivalent device (meets required criteria - biological, technical and clinical) and we are the manufacturer of both devices (hold tech files for both devices). The new device has the same intended use, design, target population and essentially same principles of operation, it only has a few minor variations.
My questions are:
1. Is it OK to add a new and not yet marketed device to an existing one for a device with long market history when the device can be considered an equivalent device?
2. If yes, would an update to the entire CER be necessary to incorporate the new device OR is an addendum to the "Equivalent Devices" section sufficient, provided that it touches on the key similarities/minor differences and justifies them?
3. Is a new literature search necessary if the original CER was not set to be updated for another 18 months and the new device has not yet been marketed (provided no new risks have been identified)?
Ronen E
Problem Solver
Moderator
Hopefully is was outsourced to someone you trust - why not ask them? Much better informed than us here.
Probably yes, but don't just gloss over equivalence. You have to thoroughly substantiate it.
These intervals sound awfully long to me. In the EU you are expected to keep your technical documentation at par with the state of the art, CER included. I think once a year is prudent (in some cases 6 months), and 18 months is quite marginal, unless it's a very mature, and quite clinically stagnant technology / field of application. 3 years is not acceptable, I would think. This is regardless of adding the new device, I'm referring to the existing one. The addition of the new device is a good opportunity to fix this.
N Adding unclassified product to the medical device registration US Food and Drug Administration (FDA) 1
F Adding a medical device in another medical device package EU Medical Device Regulations 2
S Adding claims on medical device labelling 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
P Adding an additional distributor to a current Mexico Medical Device Registration Other Medical Device Regulations World-Wide 0
K Medical device procedure tray - Adding products in Custom packs Other Medical Device and Orthopedic Related Topics 3
C Adding information to Labels - Class II Medical Devices US Food and Drug Administration (FDA) 1
U Adding another Subcontractor EU Medical Device Regulations 3
S Complexity Rating - CB adding another audit day for "high complexity" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
E Adding models to an approved Russian Registration Certificate Other Medical Device Regulations World-Wide 1
gunnyshore Adding a new facility - do I need to submit an amendment to the MDL or MDEL, or both? Canada Medical Device Regulations 3
D Adding a Class I to a sample box Canada Medical Device Regulations 5
K Adding the Notified Body Number CE Marking (Conformité Européene) / CB Scheme 2
O Adding ISO 13485 to an AS9100 QMS ISO 13485:2016 - Medical Device Quality Management Systems 13
K Relabeling or Not Relabeling - Adding our internal Part Number barcode label 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Adding Remote Site to Current IATF 16949 Certification IATF 16949 - Automotive Quality Systems Standard 2
S Adding Value prior to signing EASA Form 1 EASA and JAA Aviation Standards and Requirements 5
D Adding a new site to 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 4
J Adding a UDI Compliant Label to previously manufactured devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
4 Adding a new Company - ISO 9001 Design Exclusion Design and Development of Products and Processes 1
L IATF 16949: Adding a Remote Location between certifications IATF 16949 - Automotive Quality Systems Standard 2
T Adding an adapter to a Torque Meter to change the Range Capability, Accuracy and Stability - Processes, Machines, etc. 6
R Coexisting Investigational Use and CE-Mark - Adding a new Indication EU Medical Device Regulations 4
K Adding a New Site to Our ISO 13485 Certification ISO 13485:2016 - Medical Device Quality Management Systems 9
D Adding an extra Label on an Ethylene Oxide Sterilized Box ISO 13485:2016 - Medical Device Quality Management Systems 3
E Adding a "Scope Statement " to my Quality Policy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
W Quality for value adding or certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
somashekar Adding an other process into the system - Authorised Economic Operator (AEO) Scheme ISO 13485:2016 - Medical Device Quality Management Systems 4
Z Adding 1% error to data in a column in Minitab Using Minitab Software 3
M Is 510k Required for Adding a section on use of Disinfectants to Product Manual? US Food and Drug Administration (FDA) 3
D Adding PPAP forms to the ISO procedures Document Control Systems, Procedures, Forms and Templates 2
S FDA CDRH Premarket Review Submission Cover Sheet - adding more products 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B What to do when adding new Proprietary name under same 510(k) Other US Medical Device Regulations 2
M PPAP requirements when adding Part Transfer Robots between Machines APQP and PPAP 1
M Adding AS9100C Lead Auditor Certification to an IRCA ISO 9001 LA Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Need help in adding second location to FDA Registration Other US Medical Device Regulations 4
K Adding a Disclaimer on an FMEA FMEA and Control Plans 4
M Adding Bizminer's Industry Financial data to my Peer Company Comparison Manufacturing and Related Processes 0
D Rounding Numbers - Adding numbers in Excel - I want the average Excel .xls Spreadsheet Templates and Tools 3
F Implementing ISO 11135 - Facilities Conditions - Adding ETO Sterilization Other Medical Device Related Standards 4
Q Adding to our A2LA Scope of Accreditation General Measurement Device and Calibration Topics 2
A ISO 9001 company now adding Welding to the Scope - What needs to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
marmotte Adding a Funct. Earth. to a class II / BF device...retest needed? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Document Changes not affecting the process - Adding Logos, etc. Document Control Systems, Procedures, Forms and Templates 8
V Option for adding date-time to the copies printed from Adobe Acrobat (pdf) Quality Assurance and Compliance Software Tools and Solutions 1
V What are the Value Adding Quality Assurance Processes and how to measure them? Quality Tools, Improvement and Analysis 3
P Can 'adding a new service' be a Quality Objective? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K Quality System Manual question - Adding Satellite Facility ISO 13485:2016 - Medical Device Quality Management Systems 2
Q Adding Malicious Operator to FMEA? Quality Manager and Management Related Issues 12
F Adding a New Office Location to an ISO 9001 Certificate (Scope of Registration) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q Adding ISO13485 to existing AS9100 QMS - Summary of the differences ISO 13485:2016 - Medical Device Quality Management Systems 9
