Address on Label Requirements (MDD Annex I 13.3(a))
mr.mike
Hello once again,
My question this time has to do with labelling requirements as stated in MDD Annex I, specifically paragraph 13.3 (a).
The requirement calls for an address to be present on the label.
First of all, is there a definition of "The Label"? I was looking for one in the definitions section (Article I), but couldn't find one.
Here's our conundrum:
- Presently we have only our name, website and phone number on the labels affixed to the device itself.
- The packaging box, and accompanying User Instructions, however, include our complete mailing address as well, and an email address.
What I'm hoping is that the latter is sufficient to fulfil this requirement. This is because our device labels are pre-printed, and expensive to redo. Packaging & User-Instruction labels/docs, on the other-hand, are printed as needed, and easy to modify if needed.
Judging from other threads, this is likely an "Ask your Registrar because they all interpret differently" case. Nonetheless, if anyone had any experience or advice to share, it'd be much appreciated.
thanks in advance,
MM.
MIREGMGR
And also the product's CE Mark...?
And presumably the name and contact info for your EC Rep, and any other regulatorily required information?
The argument I've heard in the past in support of 13.3a is that the outer box is more likely to be discarded at a location and time separate from the eventual end-use, when an adverse event might occur and a decision would be made that the responsible manufacturer must be contacted.
It seems to be a weakly justified requirement in the case of a device that's accompanied by IFU and that in any case is directly marked with a phone number and email address, but that's how it's been explained to us.
somashekar
Hello once again,
thanks in advance,
MM.
Hi Mike ~~
I will never link cost to regulatory requirements.
When the device is so small that the label on it cannot contain the address as required per the MDD legible and readable, then it has to have the proper symbol leading the user to the IFU where it is contained, and take the next optimum packaging label to put in the address.
The 13.1 and 13.2 of the MDD Annex I gives good practical guidelines.
mr.mike
Hi Somachekar & MIREGMGR,
MIREGMGR: Yes, the CE marking is on the device labels.
Somachekar: We have the IEC 60878 symbol for "Follow Operating Instructions", plus the actual text "Read Instructions Before Operating" on a label on the device.
Do you think this is sufficient to allow exclusion of our address on the device itself?
(given, of course, that detailed contact info is included in the IFU).
I'm still confused though.
What is the definition of "The Label" (Annex I 13.3)?
We have several labels on our device, as well as packaging labels.
Also, there is a smaller, removable part, that bears its own label mirrorring the information on the main-device (CE mark, Company name & address, serial number, country of manufacture...).
But due to restricted space, this label does NOT have the aforementioned "Follow Operating Instructions" symbol.
Also, there is a computer that is part of the system. This has only our internal part number, as well as the computer's manufacturer's detailed label.
I guess my confusion boils down to the following:
1) Are the requirements outlined in Annex I 13.3 so strict that all the information MUST be on the device itself, or (as with our address) is it sufficient just to refer the user to the IFU (with a symbol & text on the device).
2) Are the required label information outlined in Annex I 13.3 required on every label of every part of the device (e.g. in our case: main device, removable part & accompanying computer)? ...or is "device" treated as the entire, connected, functioning system, in which case a the info required by 13.3 can be on a single label attached to the main device?
Hope I'm not being to confusing with my confusions... ;)
MM.
We were given a 'non-conformity' by our notified body because we did not have the full address on our label. We had web address, town and country and also 'Read Operators Manual' symbol but had to add the full postal address.
My understanding is that 'label' means all of the markings on a device.
I believe that the only justification not to have all required elements is that of small device size making it impractical. This may apply to the detachable parts you mention.
We include our address on our serial number label, so it's not too difficult to change if needed.
The Specialist
Can information that cannot be written in full be applied using data matrices, such-as 2D matrix/barcode?
Or does the information have to be 'commonly' legible?
Just a thought. ( I am not in the know on this topic)
K
Ka Pilo
Slightly :topic:
I’m curious how the requirements e.g. user instructions, complete mailing address, email etc will fit to small products/packages. Otherwise, it will be affixed separately.
To quote direct from MDD Annex 1 13.1
"As far as practicable and appropriate, the information needed to use the device safely must be set out on the device itself and/or on the packaging for each unit or, where appropriate, on the sales packaging. If individual packaging of each unit is not practicable, the information must be set out in
the leaflet supplied with one or more devices."
So any deviation from comprehensive labeling becomes something to consider in your risk management process. The same applies to 'non-human readable' information (barcodes or matrices).
So if your device is for use in a home care setting then the likelihood that they will be able to read the barcode is nil. But a container for use in a dispensary where barcodes are already in use - then it may be OK.
M Putting AR's name and address on label - Authorized Representative Labeling Requirements CE Marking (Conformité Européene) / CB Scheme 0
B Address on Label - Medical Device Labeling Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
M Manufacturer address on the label Other US Medical Device Regulations 18
I Importer Address in addition to Manufacturer details on label EU Medical Device Regulations 13
B Different Label Address Required for EU? EU Medical Device Regulations 7
J Class IIa Medical Device - Can I over label to change an address? ISO 13485:2016 - Medical Device Quality Management Systems 3
M Address change for a company with CE/ISO13485 EU Medical Device Regulations 2
J FDA notification of address change US Food and Drug Administration (FDA) 2
N Address of Legal Manufacturing Site in ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 1
Ajit Basrur Physical Address on Product Labels (EU MDR perspective) EU Medical Device Regulations 2
A How to address Environmental & OHS Opportunities? ISO 14001:2015 Specific Discussions 6
Q Legal Manufacturing Address Change – multiple registrations at same address 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
K Changing the Address in 510(K) Approved Product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
M GDPR - Is anonymizing sufficient to address right to erasure? Medical Information Technology, Medical Software and Health Informatics 3
K Implant Card - Full Manufacturer's Address - Space issues EU Medical Device Regulations 4
S Medical Device Initial Importer (DII) Requirements - Delivery Address 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Manufacturing Company Address Change - implications for FDA Other US Medical Device Regulations 1
M Informational USFDA – Efforts to evaluate materials in medical devices to address potential safety questions Medical Device and FDA Regulations and Standards News 0
S Risk Approach doesn't address External Issues (Auditor's Comment) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
M Medical Device News FDA's Policies and Procedures Should Better Address Postmarket Cybersecurity Risk to Medical Devices Other US Medical Device Regulations 0
Marc Email Addresses - Changing your email address Elsmar Xenforo Forum Software Instructions and Help 0
B ISO 17025 8.5 Actions to address risks and opportunities ISO 17025 related Discussions 7
TheMightyWife Address Change - Medical Device Packaging Labelling Requirements EU Medical Device Regulations 7
M "Minor" Address Change Implications on Product Labeling Requirements Misc. Quality Assurance and Business Systems Related Topics 2
K Labeling - New company address Canada Medical Device Regulations 6
S How to address and implement OH&S opportunities in ISO 45001:2018? Occupational Health & Safety Management Standards 12
qualprod ISO 9001:2015 - Right method to address clause 6.1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q ISO 14001:2015 Clause 6.1: Actions to address Risks & Opportunities ISO 14001:2015 Specific Discussions 2
J How to address IATF 16949 clause 5.1.1.1 in my Quality Manual IATF 16949 - Automotive Quality Systems Standard 6
Q ISO 9001:2015 - Clarification in 6.1.2 Note 1 (Options to Address Risks) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Requirements/guidance on what constitutes the Manufacturers "Address" EU Medical Device Regulations 7
M FDA Email Address needed for CECATS 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R Actions To Address Risks and Opportunities IATF 16949 - Automotive Quality Systems Standard 1
V 21 CFR 820 Compliant way to use Kaizen to address Nonconformances Nonconformance and Corrective Action 9
R Is PFMEA (Process FMEA) for OEM sufficient to address Risk? ISO 13485:2016 - Medical Device Quality Management Systems 7
S Change of Medical Device Company Registered Address - Implications Quality Manager and Management Related Issues 3
R How to address unresolved Medical Device Software Anomalies? IEC 62304 - Medical Device Software Life Cycle Processes 2
M How to communicate the change in company address to CFDA ? China Medical Device Regulations 1
C Appropriate ways to address Competency? Generic vs Specific ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Customer Address on ISO 17025 Test Report - Is email address okay? ISO 17025 related Discussions 9
R How to address an audit of another facility that is not ISO/TS 16949 ? IATF 16949 - Automotive Quality Systems Standard 9
S Cost of business lost / opportunity lost? How to address? Quality Tools, Improvement and Analysis 13
M ISO 9001:2008 Clause 7.6 - How to address in Software Industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc Report: Facebook e-mail switch changed address books After Work and Weekend Discussion Topics 2
R Outsourcing of a Semi-Finished Product - Which major things to address in the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B ISO 13485 & Change of Address/Location ISO 13485:2016 - Medical Device Quality Management Systems 8
P CMC Decision 3 - Manufacturers Address Content Requirements EU Medical Device Regulations 4
Q How would you address a Validation Gap/Escape (Product is in the Field) Qualification and Validation (including 21 CFR Part 11) 2
