Adhesive Seepage from Die Cut Parts Edge
somashekar
#11
Can you compare processes between the two Suppliers?
One could be die cutting on a Rotary Fabricator, the other on a Punch Press. That would also determine what kind of tooling is being used to cut the parts.
Are both adding a secondary liner to the 3M product? Is that different? Just my :2cents:
I cannot compare process. That would have solved the problem.
I am for certain that the process is not same.
There is no secondary liner that is added.
try2makeit
#12
I don't know the circumstances or what your requirements were when the part was set up with your secondary supplier in regards of what level PPAP was asked of them or it was waived. But if you have a Control Plan handy that may be able to tell you what process they are using.
thelabelguy
#13
I'm learning a lot from this thread. Glad I found it. I just started working in the labeling industry, and I was tasked to learn about die cut adhesives. Thanks. :thanx:
QAengineer13
#14
I was reading through the forum response for adhesive seepage, here are few things I learnt when I used to work for Medical Tape/ Adhesive manufacturer.
We had a similar issue with adhesive oozing (seepage) which was seasonal because the manufacturing plant environmental condition was different form the storage and also the transportation conditions. It could also be the die cut and coating method which needs to be reviewed by comparing the two supplier manufacturing method and conditions.
I do know some suppliers use Cornstarch to prevent the sides from sticking to each other, it can be ok for industrial tapes but not for Medical tapes.
If this event is for a particular batch then the Adhesive batch record ( Cof C's)/ mixing time( if applicable), Liner- Substrate ( C of C's) chemistry, machine parameter conditions in the manufacturing batch record is worth reviewing.
F Standards for testing of adhesive electrodes for use with TENS machines IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
E Composites - Metal Bond - Removal of excess film adhesive Manufacturing and Related Processes 1
M Process Controls - Wood Glue Adhesive Failure Manufacturing and Related Processes 7
L Product numbers & sources for ASTM D3359 adhesive tape Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
P Uncertainty of Measurements for Adhesive Weights for Peel Testing Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Latex Adhesive Labels used in Medical Device Packaging Other US Medical Device Regulations 7
B Is a temperature gauge needed for adhesive requiring storage in a cold environment? Manufacturing and Related Processes 8
B Appropriate Standards for Food Packaging Adhesive Manufacture Food Safety - ISO 22000, HACCP (21 CFR 120) 7
somashekar Application of parts with PSA (Pressure Sensitive Adhesive) - Is Validation required? ISO 13485:2016 - Medical Device Quality Management Systems 8
M Diebond adhesive blowholes seen after thermal curing on chip to plastic bottle mount Manufacturing and Related Processes 4
R Process Validation - Adhesive Bonding, what to validate and how? Qualification and Validation (including 21 CFR Part 11) 10
S Autoclavable Adhesive for Medical Grade Polycarbonate ? suggestions? Manufacturing and Related Processes 3
Q PPAP for Materials - Rolls of adhesive tape, rolls of films and sponge material APQP and PPAP 5
D Is a vendor of Class ll (Orthodontic Adhesive) required to be ISO certified ISO 13485:2016 - Medical Device Quality Management Systems 2
A Adhesive Longevity Tests - Glued Silicone used in a Shower to Bond Glass Panels Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
P Raw materials as bulk materials (polymer, adhesive, etc) for PPAP IATF 16949 - Automotive Quality Systems Standard 1
H Medical Device Adhesive with USP class VI, suited for oral 'use' ISO 13485:2016 - Medical Device Quality Management Systems 3
K Any adhesive needed for PVC and PC natural bond? ISO 13485:2016 - Medical Device Quality Management Systems 1
M Sampling Plan for Alumin High Pressure Die Castings Manufacturing and Related Processes 0
M CQI-9 monitoring of temperature in die Various Other Specifications, Standards, and related Requirements 2
S IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA - Die casting) IATF 16949 - Automotive Quality Systems Standard 5
A Aluminum Die Casting Product Traceability Manufacturing and Related Processes 10
kedarg6500 Availability of 5/8" 17.75 TPI Thread Ring Gauge & Die Nut Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Z Stamping Press Die Specification Manufacturing and Related Processes 2
Hershal 19 "Hot Shots" Fire Fighters Die fighting Arizona Fire World News 1
V When to Notify Customer about Die Modification APQP and PPAP 4
V Query on TS 16949:2009 Certification for a Tool and Die Sales & Service office IATF 16949 - Automotive Quality Systems Standard 3
C Inspecting a Profile Tolerance for a Die Cut Gasket Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
F FMEA Optimization for our Die Setup Process FMEA and Control Plans 2
V PPAP 7 of 8 Cavities after an injection mold die repair? APQP and PPAP 7
D FMEA for Laser Cutting of Die Cast parts in AM60B Magnesium FMEA and Control Plans 1
J Causes of Porosity of Die-Castings and How to Improve Die-Casting Manufacturing and Related Processes 10
A Tool and Die Manufacturing Job Progress Tracking Tools / Spread Sheets Manufacturing and Related Processes 7
A Powder Coating Chipping for Aluminum Die Casting Parts Supplier Quality Assurance and other Supplier Issues 11
T PFMEA of Die casting Process--Help needed? FMEA and Control Plans 5
S "Acceptable" PPM Level for Aluminum Die Casting Benchmarking 3
A Seeking a Die Casting Supplier in China - Guangdong, Zhejiang and Jiangsu Supplier Quality Assurance and other Supplier Issues 6
A Helical Cooling for Aluminium Die Casting Dies Information wanted Manufacturing and Related Processes 3
A Aluminium Die Casting DFMEA example wanted FMEA and Control Plans 6
N In Process Control checksheet for Die Cutting (eg. carton) Document Control Systems, Procedures, Forms and Templates 2
J Salt Spray Test on 3 year old Zinc Die Casting Chromed part per ASTM B 117-03 Manufacturing and Related Processes 2
T How can I streamline a corrugating firm especially in tool and die making Manufacturing and Related Processes 4
L Work Instructions for One Time Tool Build - Tool and Die Shop Manufacturing and Related Processes 6
P Variables Gage R&R study for 8 Cavities tool - Die casting industry Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
P Generic Label Die Cutting Process flow Manufacturing and Related Processes 5
T Die Cutter for Kevlar Fabric Manufacturing and Related Processes 10
B Electronics Die Component - Military Standard 883 vs. MIL STD 750 TM2010 B. Various Other Specifications, Standards, and related Requirements 4
S How can I die cut foam - I'm thinking of a simple hand machine? Manufacturing and Related Processes 15
A Process or Work Instruction (WI) to Change a Progressive Stamping Die Manufacturing and Related Processes 2
W How can I deterime the load of the DCM? Die cast machine loading Lean in Manufacturing and Service Industries 4
