Hi all,
Minitab and DoE novice here.
I'm working on an electrochemical system and trying to optimize two outputs simultaneously:
1. Increase signal suppression (SS (%))
2. Decrease potential peak current (ipc)
I started with a 2^4 factorial design. For SS, the initial model looked overfit, so I reduced it hierarchically, which improved things. The reduced model suggested curvature, so I followed up with a CCD using only the significant factors. However, the CCD gave a poor model summary and showed no significant factors:
S R-sq R-sq(adj) R-sq(pred)
12.5364 27.65% 0.00% 0.00%
Interestingly, my system seems to be quite variable (there's probably some complex chemistry going on that I'm not aware of), the range and degree of response is smaller in the CCD compared to the initial factorial. ipc, on the other hand, fits a linear model reasonably well.
I would very much appreciate any advice on next steps or best practice for this kind of outcome, as I'm unsure of how to make practical use of the optimization results in this case.
Happy to share any extra details if that may help.
Many thanks in advance!
