Advisory Notice Requirements & Procedure and Form examples
Amanda B.
Hi all,
I need to incorporate an advisory notice procedure into our existing QPM - we currently state that we will issue an advisory notice if it becomes necessary but there are no details on the process ...I understand the definition of the advisory notice and (I think) when it should be performed, but what I'm trying to find out is if there are any particular requirements (or suggestions from brilliant minds on the forum :D) for what that advisory notice form should like and what the procedure should entail?
FYI: I started looking because we have kits in a distributors warehouse which currently hold items that we (the manufacturer) would like to pull out of the kit. From what I can tell an advisory notice is warranted here - there is no danger from the item, the test will perform to specs without the item and the item has been historically offered as a complement to the test....but we want to discontinue that practice. In order to effect the change for kits currently in the distributors warehouse, from what I can tell under 3.3 "modification of a medical device' an advisory notice would be the way to go.
Am I on the right track here? :)~ And if yes, does anyone have any suggestions on the procedure and/or form?
Thanks so much!
Amanda
Amanda B.
Do I stink? Did I say something wrong? :(
Is there anyone who can point me in the right direction on my post? Please?
I'm desparate here, my boss says, "So, what have you found out?" Me..."ummmm...." LOL.
And btw, as a newbie here I have another question..I've only posted a couple of times..and I've thanked people via message, but apparently that doesn't 'count' because my profile says I haven't thanked anyone, which makes me feel terribly rude. How does one thank someone 'officially' on the forum? :)
Thanks!! :lol:
Amanda
GStough
Hi all,
Thanks so much!
Amanda
Hi Amanda,
This is not exactly my area of expertise, but I will attempt to help. Perhaps some of the more knowledgeable Covers in this subject will jump in to help shortly. ;)
You didn't mention whether your company is registered to ISO 13485, but I'm assuming that you are. The standard (8.5.1) just states "The organization shall establish documented procedures for the issue and implementation of advisory notices. These procedures shall be capable of being implemented at any time." It leaves the "how" and "when" up to the organization so that you can fit it to your company's and customer's needs, requirements, etc.
As for a specific format, again that is left up to your organization to determine whatever will work best for you. If you haven't already done so, I'd like to suggest that you take a look at the Post Attachments List (the thin green bar at the top of this page) and see if there may be a template posted that you could use for a guide as you develop this form and/or procedure. There are many, many great documents, templates, etc. posted there and hopefully, you can find something useful for your needs or at least to provide a good foundation. :)
I hope this helps. :bigwave:
ScottK
Not out of the crisis
Hi Amanda.
not sure If I'll be much but I'll give it a shot...
As I understand advisory notices they are used to notify customers with supplementary information on an item already delivered. You say they're at a distributor so I'm not sure if that's the definition of delivered or not - I kind of consider delivered to be at the end user.
You want the distributor to remove an item from the kit. Will you need to also send out updated user instructions or carton labeling to show the new contents?
Depending on the quantity at the distributor this might be better to either send replacement kits with the current components and have distributors return the outdated ones OR grandfather the outdated ones and only send the current ones from now on.
I know if I was a distributor of a kit I wouldn't want the responsibility and potential problems of opening the kits and modifying them. I'd want to send them back to you and have you do it.
Either way I supppose a notifictation is called for... I would just write a letter, on company letterhead of course, describing the situation and how you plan to resolve it. If you want to make a formal form, by all means do, but I don't believe it's required unless your procedure calls for it.
I hope that helps a little... I've been out of hard medical devices for a while so I may be rusty.
As fars as thanks, there's three things you can do:
1) click the "thanks" button at the bottom of a post - this adds to counts
2) Click the little yin-yang button at the top of the post to "add karma" and leave a comment.
3) send a PM as you have done.
chris1price
R ISO 13485 - Advisory Notice Requirements ISO 13485:2016 - Medical Device Quality Management Systems 5
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
somashekar FDA cGMP on Feedback, Advisory Notice and Customer Property 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Customer Return or Advisory Notice? ISO 13485:2016 - Medical Device Quality Management Systems 6
E Medical Device Advisory Notice Procedure ISO 13485:2016 - Medical Device Quality Management Systems 4
K Recall or advisory notice sufficient for software ISO 13485:2016 - Medical Device Quality Management Systems 9
M Informational US FDA Patient Engagement Advisory Committee – Cybersecurity in Medical Devices: Communication That Empowers Patients Medical Device and FDA Regulations and Standards News 0
M Informational MHRA Guidance – Recommendations from the independent Expert Advisory Group on the use of Paclitaxel Drug-Coated Balloons (DCBs) and Drug-Eluting Stent Medical Device and FDA Regulations and Standards News 0
M Informational The USFDA Announces General and Plastic Surgery Devices Panel of the Medical Devices Advisory Committee Meeting on March 25-26, 2019 Medical Device and FDA Regulations and Standards News 0
M Medical Device News Health Canada - Scientific Advisory Panel on Software as a Medical Device (SAP-SaMD) - Record of Proceedings – January 26, 2018 Canada Medical Device Regulations 0
W FAA Advisory Circular (AC) Requirements (FAA AC 00-56) - Internal Audits AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S Nadcap HT Auditor Advisory 17-003 Advice needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
A Advisory Notices - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
Ajit Basrur What is the German term for "Advisory Notices" ISO 13485:2016 - Medical Device Quality Management Systems 2
J Can I combine Recalls, Advisory notices, and Vigilance systems into one procedure? ISO 13485:2016 - Medical Device Quality Management Systems 2
S Advisory Services - Design and Development requirements per clause 7.3 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Advisory Notices for a Component Supplier ISO 13485:2016 - Medical Device Quality Management Systems 4
J Location of ANAB Advisory #23 - Nonconformance Classifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Ajit Basrur Anyone having ppt file on Advisory Notices ? ISO 13485:2016 - Medical Device Quality Management Systems 2
A Who is responsible of Advisory notices ISO 13485:2016 - Medical Device Quality Management Systems 5
C Established procedure for Advisory Notices - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 7
C Corrections and Removals and Advisory Notices: 21 CFR 806 (Procedure needed) Document Control Systems, Procedures, Forms and Templates 1
H What is a Purchasing "Advisory"? ISO 13485:2016 - Medical Device Quality Management Systems 4
Marc Advisory Notices - Who is responsible for dealing with Advisory Notices? ISO 13485:2016 - Medical Device Quality Management Systems 7
G Advisory Notices - What is the Requirement in ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 7
G Documented Procedures for the Issue of Advisory Notices and the FDA (Medical Devices) ISO 13485:2016 - Medical Device Quality Management Systems 2
D Implementing ISO 13485:2003 - 8.5.1 - Advisory Notices - Recall Procedure ISO 13485:2016 - Medical Device Quality Management Systems 12
Q ISO 13485 - Advisory Notices - Regulations - Quality Manual Quality Management System (QMS) Manuals 13
Sidney Vianna ISO 9001 Advisory Group (IAG) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
L Significant change notice for outsourced warehouse Medical Device and FDA Regulations and Standards News 2
S Is the document author required to be identified as part of Document Change Notice? ISO 13485:2016 - Medical Device Quality Management Systems 5
L Getting Notice of Revision and Accessing Public Draft Copies of ISO Standards Service Industry Specific Topics 2
M Informational Health Canada – Notice: Revisions to the Guidance Document: Management of Applications for Medical Device Licences Medical Device and FDA Regulations and Standards News 0
W Informational MDSAP Substantial change / Change of notice forms Document Control Systems, Procedures, Forms and Templates 2
shimonv Non-significant notice of change to notified body EU Medical Device Regulations 4
M Medical Device News Olympus Medical pleads guilty to failing to file events notice: Justice Department Medical Device and FDA Regulations and Standards News 0
M Medical Device News Health Canada Notice of intent: Strengthening the post-market surveillance and risk management Canada Medical Device Regulations 1
S Change notice while switching to injection molding technique for manufacturing EU Medical Device Regulations 1
M MDSAP Transition - Health Canada Website Notice on Apr 13 2018 Canada Medical Device Regulations 1
J Employer Warning Notice a Controlled Document? Document Control Systems, Procedures, Forms and Templates 7
S Definition Legal Hold Notice - What is a Legal Hold Notice? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
R Two Week Notice Backlash Coffee Break and Water Cooler Discussions 17
somashekar Medical Device Establishment Registration and Listing - Notice of Changes for FY 2013 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Q Should advance notice be given for Disaster Recovery Audit? Business Continuity & Resiliency Planning (BCRP) 9
T CFDA issues notice for Small Oxygen Respirators (9/16/2013) China Medical Device Regulations 0
D Relabeling due to FDA Detention Notice Manufacturing and Related Processes 6
J Training/Notice when a New Document is Released or a Document is Changed Training - Internal, External, Online and Distance Learning 13
AnaMariaVR2 Medical Device Establishment Registration and Listing - Notice of Changes for FY 2013 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
