The more I keep reading the more I get confused. My question is ANAB Heads Up 170 states: To assist CBs in planning the transition as early as possible, as outlined in SR 001, ANAB has been given approval to provide each CB with a copy of the 9104/1 ballot draft document.
Given that this document is still in draft and currently being balloted, there may be changes when published; however, the 9104/1 rewrite team is fairly confident that any changes will be minimal. ANAB highly recommends that CBs start the transition process internally and begin discussions with customers, being aware that there may be some changes a few months down the road when the 9104/1 is published.
So should a CB start using the AS9104/1 draft audit day tables for existing clients as they schedule AS9100C audits now? If not what tables should CB's use for the new revision?
I realize we are not suppose to use the draft version for new clients but not exactly sure about existing ones.
Thank you
