Agilent Power Sensor Calibration - Need a Calibration Procedure
Jerry Eldred
#11
I would recommend going to the Agilent website and downloading the data sheets for that family of sensors.
As for linearity and how to select, I would let the frequency and power level be the main factors. You might want to get a set of data sheets for the various power sensors, and do a comparison.
Some other vendors include Rohde & Schwarz, and Anritsu, who also have families of power sensors (those are the only other brands I can bring to mind at the moment).
You might also look at the other model families at Agilent, as they have a number of newer models these days (and this is not an advertisement for Agilent). So in that light of neutrality, I would also recommend checking to see what is available from the other vendors.
Back to the 8484A sensor, my GUESS would be that the 8484A was discontinued perhaps because it's technology was supported only by the older models of power meters, and the 8481D may be a little newer (not sure though). I just downloaded the latest Agilent data sheet, and it has comparative specs on quite a lot of their sensors. You can probably do the same as well for Anritsu and Rohde & Schwarz.
If anyone knows some other current brands of RF power sensors that I can't think of, it would be educational to post them here. The only one other brand that just came to mind is Boonton (although I'm not sure they are still making them).
P
powderblack
#12
Jerry,
I read your post thanks for the simplified version. In your post you mention that HP sensors are usually reference to 0dbm @ 50 MHz and then are relative from there to end of their frequency range but what about a HP sensor that can't go to 0dbm?
I speaking about model number 8487D which has a power range of -70dbm to -20 dbm.
Now my signal source generator only goes down to -20dbm but has a frequency range of 50 GHz which covers the frequency range of the sensor. Would i be correct to assume that i can do the cal factor checkpoints at -20dbm?
Jerry Eldred
#13
Not sure exactly what you are asking, but I will try to answer. Even for an 8487D (I have some 8487A's, just not the D model), there should be a 30 dB attenuator and adaptor to set a 50 MHz 0 dBm reference (this is an industry standard for those sensors. For the low power range (high sensitivity) sensors that are not able to go all the way up to 0 dBm (1 mW), there should universally be that reference attenuator, HP 11708A, I believe, and an N(m) to APC2.4mm(f) adapter. You would connect your sensor to the 0 dBm reference using that adapter and attenuator and set the 0 dBm reference that way, at the specified reference calibration factor.
Then, removing the adapter and attenuator, and using the applicable calibration factors across its frequency range, the sensor should be good for power level measurements across its frequency and amplitude range.
Hershal
Metrologist-Auditor
#14
Dear all,
Can you tell me what is the SI unit of amplitude modulation?
Also the frequency and phase modulation as well?
I wish to know how to put them in the S.I units?
I know all the units are in Hz..hertz over Hertz cancels off leaving a relative value, true?
For the calculation of amplitude,phase and freq modulation using the 8902S system,
it is stated as 3% + 1 digit (what is the digit here- is it the noise floor,resolution or what?)
Rgds
Ruben
Ruebenn, the Derived Unit is the frequency, and frequency and therefore amplitude modulation, ultimately traces back to the SI Unit of Second. Meter may have contributions as well due to wavelength.
Hope this helps.
I TS16949 - MSA for Agilent Parametric Tester IATF 16949 - Automotive Quality Systems Standard 1
I TS16949 - MSA for Agilent Parametric Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Agilent 8902A FM/PM/AM Accuracy Measurement Uncertainty (MU) 1
G Is Agilent?s automated network analyzer verification ISO/IEC-17025 compliant? ISO 17025 related Discussions 4
R Problems Making Measurements - Agilent 8902A Measuring Receiver Calibration and Metrology Software and Hardware 4
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Judy Abbott The impact of laser power on biocompatibility of the products Manufacturing and Related Processes 6
C Power Supply EN60601-1 vs EN62368-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S DC-AC Power inverter with two MOPPs IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Surge Protectors and other power protection Manufacturing and Related Processes 7
Sidney Vianna Informational APQP4Wind - Advanced Product Quality Planning for the Wind Power Supply Chain APQP and PPAP 3
U Power supply - Change From 160 to 300 Watts - Significant change? EU Medical Device Regulations 2
M MS Power Automate/Sharepoint Files Document Control Systems, Procedures, Forms and Templates 1
O Are power distribution units Multiple Socket Outlets (MSOs)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
L Medical-grade power adapter labeling Other US Medical Device Regulations 2
A Calibration of Power Supplies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B IEC 60601 Cl. 8.4.3 - ME EQUIPMENT intended to be connected to a power source by a plug / Plug discharge IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Proud Liberal Power Query to combine multiple tables of unequal number of columns Statistical Analysis Tools, Techniques and SPC 1
J Universal Power Cord with Adapters - IVD IEC 61010-2-101 CE Marking (Conformité Européene) / CB Scheme 6
L External power supplies: How close does the safety report have to match the end-use application? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
L IEC 62368-1 / Electrical Energy Source vs. Power Source? CE Marking (Conformité Européene) / CB Scheme 2
B Need For BIS Standard Mark? Imported OEM's Power supply,Li-Ion Battery Other Medical Device Regulations World-Wide 0
I Containment procedure for parts after a power outage. IATF 16949 - Automotive Quality Systems Standard 1
P UDI labeling for power module IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
E IEC 61010-1 Dielectric strength test of inner power supply Other ISO and International Standards and European Regulations 0
S Power rating for medical devices in the US - Radiotherapy devices US Food and Drug Administration (FDA) 0
T Is anyone working with N299.1 (Supply/service to nuclear power plants)? Various Other Specifications, Standards, and related Requirements 0
E IEC 60335-1 power input deviation - Table 1 Values Other ISO and International Standards and European Regulations 0
H External power supply - requirements in safety/EMC test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
K Power point training slides on DOE (Design of Experiments) Wanted Training - Internal, External, Online and Distance Learning 2
Marc Renewables, led by wind, provided more power than coal in Germany in 2018 Sustainability, Green Initiatives and Ecology 2
S Responsibilities between government owner and private subcontractor of a power plant seeking ISO 9001 certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Electrical Power Plant Supply failure in PFMEAs FMEA and Control Plans 10
H IEC 60601-1 Main Power Cord Requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Infusion Pump Power Failure Alarm IEC 60601-2-24 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Power Cord Length Issue - Medical Device Electrical Safety IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C ISO 9001:2015 - Non Applicable Design and Development (Power Plant Operator) Design and Development of Products and Processes 2
H Enclosed vs. Open-Frame Power Supplies - Overdoing it? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
J Pneumatic & Electrical Torque Tool - Calibration/Verification of 'Power Tools' General Measurement Device and Calibration Topics 2
G Medical Device Power Inlet/Outlet Voltage Labeling IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
x-files [Thermal Power plant KOSTOLAC, SERBIA] Sucessfully certified to ISO 50001 Sustainability, Green Initiatives and Ecology 1
M Is IEC 60601 compliance possible when only generic power-supply is specified? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
U IEC 60601-1, Class 1 or Class 2 on emergency power system IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Power Traceability certificate for values for voltage, current and phase General Measurement Device and Calibration Topics 1
D NQA-1 Standard Applied to Services rather than Items for Nuclear Power Various Other Specifications, Standards, and related Requirements 3
R USB power between Medical Device Data Collection Device Component IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
F Power and sample size for factorial design Using Minitab Software 4
P Medical Device Marking - Power Input Ports IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
