AIAG FMEA Occurrence Criteria Issue
X
xiong_xj
When I study the AIAG FMEA (4th Edition), I found an issue in occurrence criteria. The issue has been shown in the attached image.
If I follow the attached selection 1 rule, I can not determine the ranking when the occurrence rate is between 1ppm to 10ppm; And if I follow the attached selection 2 rule, I can not determine the ranking when the occurrence rate is between 50,000ppm to 100,000ppm.
Who can help to solve this problem?
Thanks a lot in advance.
Singa
X
xiong_xj
Dear Howard Atkins,
In FMEA handbook, there is only an occurrence criteria. But for this criteria, I can have two ways to understand it. Here I called it as "Selection 1 rule" and "Selection 2 rule". Anyway, each understanding way has ranking issue I marked it as "?" in the attached image.
I want to know how to solve this issue.
Thanks a lot.
Singa
Dear Howard Atkins,
Thanks a lot.
Singa
Where did the chart you're asking about come from?
X
xiong_xj
Dear Jim Wynne,
This chart is writen by myself according to FMEA (4th edition) handbook. The occurrence criteria is from this handbook, and the selection 1 & 2 rules are based on my understanding but its trouble me. So I try to ask help to know how I can use the occurrence crtiteria correctly.
Singa
Chennaiite
Never-say-die
Singa
I am pretty much sure your issue is not any different from what was raised in this thread. Just check if that helps.
Rameshwar25
Dear
The table given in FMEA manual is very confusing. I could not make a table which could satisfy >=100000PPM and less than 1 PPM. However, to ease the FMEA process, I have prepared the table which is attached herewith.
the PPM level more than 50,000 and below 100000 will be 9 because 10 is for more than or equal to 100000.
Regards
Rameshwar
K 4th Edition AIAG FMEA Occurrence, Severity and Detection Criteria for Plastics FMEA and Control Plans 1
P Occurrence Rating in AIAG FMEA Manual 4th Edition FMEA and Control Plans 5
J Which OEM or customers are now requiring the new AIAG/VDA FMEA format? FMEA and Control Plans 2
C AIAG/VDA FMEA - Is the new better? FMEA and Control Plans 0
P VDA AIAG FMEA - Slides for Quality Audience FMEA and Control Plans 4
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
B AIAG-VDA FMEA - When the new format will be required FMEA and Control Plans 5
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
K AIAG/VDA FMEA & Process Control Plans FMEA and Control Plans 0
D FMEA-MSR in the AIAG-VDA Aligned Handbook - What is it? FMEA and Control Plans 5
bobdoering AIAG VDA FMEA Handbook - 2019 - something familiar about this.... FMEA and Control Plans 37
S New AIAG FMEA Process - How to complete the new format FMEA and Control Plans 32
G AIAG FMEA - Major customers of the FMEA process FMEA and Control Plans 3
R Information on the roll out of the new harmonized DRAFT FMEA AIAG/VDA manual IATF 16949 - Automotive Quality Systems Standard 4
Marc When will Revision 5 of the AIAG FMEA Manual be released? FMEA and Control Plans 93
S Pre-release version of the upcoming AIAG FMEA Revision 5 FMEA and Control Plans 1
N AIAG 4th ed. FMEA Manual "Fit" Changed to "Appearance" - Fit severity? FMEA and Control Plans 2
Z Failure Mode Identification in PFMEA according to AIAG FMEA Rev.4 FMEA and Control Plans 6
C AIAG FMEA 4th Ed "Design Assumption" - I Need Examples FMEA and Control Plans 15
M AIAG FMEA Manual Request FMEA and Control Plans 9
D AIAG FMEA 4? Ed. Explanation: Relationship between PFMEA and Special Characteristics FMEA and Control Plans 8
V Latest revisions of Core Tools Manuals from the AIAG (APQP, PPAP, FMEA, SPC and MSA) IATF 16949 - Automotive Quality Systems Standard 3
A AIAG Design FMEA Severity Rankings - Noncompliance Government Regulation? FMEA and Control Plans 9
M DFMEA Detection Ranking in AIAG FMEA Manual 4th Ed. - Explanation wanted IATF 16949 - Automotive Quality Systems Standard 6
I What is the difference between FMEA Fourth edition (AIAG) and VDA 4.2? VDA Standards - Germany's Automotive Standards 7
R Is there an FMEA standard other than AIAG? FMEA and Control Plans 11
M What are the changes in the latest AIAG FMEA edition FMEA and Control Plans 4
Stijloor Latest AIAG PPAP and FMEA Errata Sheet APQP and PPAP 7
P AIAG FMEA manual 4th edition - Problem with Appendix C FMEA and Control Plans 3
T RPN of Action Results per the AIAG FMEA manual FMEA and Control Plans 5
P AIAG FMEA Core Tools Exam FMEA and Control Plans 4
L AIAG's FMEA 4th Edition - Presentation with changes wanted FMEA and Control Plans 8
U AIAG's FMEA Manual 4th Edition Released - 2nd July 2008 FMEA and Control Plans 77
Stijloor AIAG's FMEA 4th Edition Rollout Events. FMEA and Control Plans 3
S Are the AIAG document (FMEA, PPAP, SPC, MSA, APQP) guidelines or requirements FMEA and Control Plans 6
K Ford FMEA - differences to AIAG FMEA FMEA and Control Plans 8
R AIAG's FMEA Manual 4th Edition pushed back to 1st quarter 2008 FMEA and Control Plans 16
S Has the AIAG published the latest FMEA manual yet? FMEA and Control Plans 2
L PFMEA (Process FMEA) issue about lower RPN - AIAG 3rd edition page 55 FMEA and Control Plans 13
J Changes to AIAG's FMEA manual to happen in the 3rd quarter of 2007 FMEA and Control Plans 10
K AIAG FMEA Manual - New version in June 2007? FMEA and Control Plans 6
S PFMEA Form - What forces you to use the AIAG form for Process FMEA? FMEA and Control Plans 4
S VDA vs. AIAG - FMEA Ranking FMEA and Control Plans 4
C Is Risk Assessment Still Necessary? The AIAG FMEA Manual does not address FMEA and Control Plans 1
M PFMEA Detection Evaluation Criteria - Visual Check - Page 52 of the AIAG FMEA manual FMEA and Control Plans 2
A Sae J1739:2002 - Is it different from the AIAG's latest FMEA manual? FMEA and Control Plans 1
A AIAG Releases FMEA Update - 30 June 2001 FMEA and Control Plans 16
M Renault vs. AIAG FMEA - Would like details of it's usage and any training aids FMEA and Control Plans 4
O AIAG VDA DFMEA Template Required FMEA and Control Plans 2
