AIAG Statistical Process Control (SPC) Manual - Page 81
Comments Please
Please refer to the AIAG "Statistical Process Control" manual page 81, Section C - Description of Conditions and Assumptions, last bullit.
Please provide your comments/interpretations of the following statement:
"There exists a willingness to accept the computed index(or ratio) value as the "true" index (or ratio) value - i.e., to discount sampling variation's influence on the computed number (e.g.,a computed Cpk of 1.05 may be from a process whose "true" Cpk 1.40, or vice versa, due simply to sampling variation). Please see Appendix H, Referewnces 19, 20, and 21 for more on this subject."
Craig H.
Sam:
Not having a copy of the manual, this might be off base, but I'd like to take a shot.
I believe what they are refering to is the tendancy for us to see the numbers we generate as coming from a "magic truth box". I once went to a conference held by a major supplier to the auto industry (call them company A). Company A held this conference for their suppliers, and the suppliers sent mostly sales people, even thought the stated mission of the conference was supplier quality (go figure).
One of the big points company A was trying to make was that they had hired outside labs to test incoming raw material, and had found that upwards of 60% of incoming raw material was out of spec (not a typo). Yours truly raised his hand and started asking about test methods. You should have seen the blank stares. The blank stares continued when I asked about instrumentation.
My point is that we often spend too much time looking at the numbers, and accept them as gospel, when we should first be looking at just where the numbers come from, and how they were generated. Sure, you might get your shoes dirty, but it beats being made a fool of by relying on faulty data. Yeah, I have been caught myself, and it is a lesson I hope to never have to repeat.
Hope this helps.
Craig
Rob Nix
AIAG SPC Manual
The paragraphs preceding your reference (Section C) are describing conditions and assumptions. Then, when referring to capability measurements, it is ASSUMING four bulleted conditions (i.e. controlled process, normal distribution, customer specs, AND "willingness to accept...").
From this I would think they are saying that between you and your customer you are both accepting the idea that the results you get are ASSUMED to be correct, reality, or true - EVEN THOUGH you both likely agree that the actual true capability is unknown. It may be higher or lower; you are simply reaching an agreement that you both accept the results on the study.
IMHO :rolleyes:
Craig,
I sgree. We place too much emphasis on the final number represented by the term Cpk.
Rob, I also agree. We are making an assumption based on a condition.
However, I'm having difficulty determining what the condition is.
- First, What is a "computed index (or ratio)"? Is it the same as the CR on the previous page,
- if so, can I present the CR as capability versus Cpk?
Rob Nix
Sam,
Yes, the computed "ratio" is one of the calculations on page 80.
Your customer most often dictates what equation is required to show capability, e.g. Ford uses Cp and Cpk, GM uses CR (the reciprocal of Cp). Whatever you or your customer choose is acceptable.
Q AIAG Releases the 2nd Edition of their SPC (Statistical Process Control) Manual Statistical Analysis Tools, Techniques and SPC 19
Q IATF / AIAG: Control Plans and CC / SC requirements FMEA and Control Plans 1
J Which gauge R&R to use per AIAG Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
H AIAG MSA: 4th Edition (Bias Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
E AIAG Core Tool Debacle... Reliability Analysis - Predictions, Testing and Standards 1
Sidney Vianna IATF 16949 News AIAG/VDA harmonized approach to FMEA IATF 16949 - Automotive Quality Systems Standard 0
S AIAG-VDA FMEA tutorial and completely filled FMEA FMEA and Control Plans 1
J Adoption of automotive (AIAG) methods and documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M AIAG-VDA DFMEA 2019 - it is compulsory? FMEA and Control Plans 7
Casana Step 7 in AIAG/VDA FMEA form FMEA and Control Plans 17
B Wrong standard deviation calculation in AIAG SPC manual? Capability, Accuracy and Stability - Processes, Machines, etc. 13
M Should there be another column in the Optimization section (step 6) of AIAG-VDA DFMEA form? FMEA and Control Plans 1
D Locking Control Limits and SPC Sample Sizes (AIAG/Automotive Requirements) Six Sigma 2
M Inconsistency of VDA-AIAG severity table for DFMEA with the manual text FMEA and Control Plans 0
M How to record the effects of adjacent systems (shown in boundary diagram) in the AIAG-VDA DFMEA form FMEA and Control Plans 0
H Quality planning sign-off in AIAG APQP Manual IATF 16949 - Automotive Quality Systems Standard 5
H RPN in AIaG-VDA FMEA Manual FMEA and Control Plans 1
Sonja D AIAG VDA PFMEA and Control Plan training FMEA and Control Plans 9
abrego44 AIAG PPAP manual for service part APQP and PPAP 5
OpExPro AIAG VDA FMEA Rating Tables FMEA and Control Plans 5
K RPN/ KC) per AIAG FMEA and Control Plans 0
OpExPro The note at the bottom of DFMEA occurrence tables in AIAG VDA FMEA FMEA and Control Plans 0
OpExPro AIAG VDA DFMEA Template Required FMEA and Control Plans 6
J Which OEM or customers are now requiring the new AIAG/VDA FMEA format? FMEA and Control Plans 11
C AIAG/VDA FMEA - Is the new better? FMEA and Control Plans 0
A PFMEA new AIAG FMEA and Control Plans 0
P VDA AIAG FMEA - Slides for Quality Audience FMEA and Control Plans 4
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
B AIAG-VDA FMEA - When the new format will be required FMEA and Control Plans 6
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 28
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
S AIAG CQI Auditor Qualification and 3rd Party Certification Requirements General Auditing Discussions 2
K AIAG/VDA FMEA & Process Control Plans FMEA and Control Plans 0
D FMEA-MSR in the AIAG-VDA Aligned Handbook - What is it? FMEA and Control Plans 5
bobdoering AIAG VDA FMEA Handbook - 2019 - something familiar about this.... FMEA and Control Plans 37
S New AIAG FMEA Process - How to complete the new format FMEA and Control Plans 36
C Detection Action for Failure Effects - AIAG 4th Edition Layout FMEA and Control Plans 5
S I have just purchased the all new Core Tools Software (CTS) from AIAG IATF 16949 - Automotive Quality Systems Standard 39
J AIAG PPAP: 2.2.11.3 Acceptance Criteria for Initial Study (page 9, 4th edition) APQP and PPAP 1
M Is there a published List of AIAG members requiring IATF certification ? IATF 16949 - Automotive Quality Systems Standard 2
A The FILE recommended by AIAG MSA 4ed for LINEARITY Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
I AIAG 2018 Quality Summit - Is it worth it? IATF 16949 - Automotive Quality Systems Standard 3
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
G AIAG FMEA - Major customers of the FMEA process FMEA and Control Plans 3
R Information on the roll out of the new harmonized DRAFT FMEA AIAG/VDA manual IATF 16949 - Automotive Quality Systems Standard 4
