AIAG VDA PFMEA and Control Plan training
I am looking for a training class on PFMEA and C-plan connections. The AIAG manuals show how a PFMEA and a C-plan should look but they are on different products so it does not help me with connecting them together. Does anyone have recommendations on a good training class that I can take? My goal is to find a class that will work through the Process flow diagram, PFMEA, and the Control Plan for the same process step(s). Many examples I have seen will highlight a section for process step "20" on the PFMEA but show process step "40" on the Control plan. If someone has an example that they could share that would also be appreciated.
Hi Sonja D, welcome to the best place to learn and share info...I recently completed FMEA and Control Plan training/refreshers courses via AIAG, they were excellent, I highly recommend them...They are not inexpensive but thorough and worth the effort.
Hope this helps...
Thank you for the information. Did they take you through a process showing how the process flow connects to the PFMEA and the control plan?
This is a fairly simple process. On the PFD, number the process steps. On the PFMEA, use the same numbering for each of the process steps and complete the PFMEA process. Use the information learned from the PFMEA process to inform the control plan. Note that the process steps on the PFD and PFMEA should match, but on the control plan, some steps may be omitted if it was determined in the PFMEA process that special controls aren't needed. Thus, on the PFD and PFMEA you might have process steps 1, 2, 3, 4 and 5, but only 1, 2 and 4 might be shown on the control plan.
Thank you Jim,
I understand the principals of the process. I am looking for training that will help me connect the pfmea and c-plan dots. The examples I have seen in the AIAG manuals do not follow through a process. I want to make sure that I am putting the correct information from the PFMEA into the control plan. Since we use Excel and not a software that automatically put the information into the C-plan from the PFMEA, I want to make sure I am doing it properly.
Thank you Jim,
The problem is that specific training probably won't help much in this regard. It's your company's responsibility to determine what needs special controls and what doesn't. The purpose of the PFMEA process is to identify the process steps that need special controls. You can learn from a training course how to do things in a very general sense, but not how to apply the principles specifically to your processes. I don't want to discourage you from being trained because there might be some useful enlightenment, but you just shouldn't expect disinterested parties to help with the idiosyncrasies of your processes.
optomist1
A Sea of Statistics
yep, let me see if I can share a bit of info from my class notes...fyi, I previously requested AIAG permission to post course screen shots, they shot that down so to speak...Cheers Optomist1
Casana
Blueberry Nut
Link - AIAG.org - Automotive Industry Action Group
Hope this helps...
Hi Optimist1 - did you take this class on line or in person? I'm looking for a class and was seriously considering the AIAG one but I'd have to do it remote (plus there's no way I'm going to Michigan in winter! :LOL:)
Also -did you take the generic FMEA class or the DFMEA version? I'm going to need both but don't want to take both classes, hoping the generic one will be sufficient... Thx for any comments!
(apologies for highjacking this thread...)
optomist1
A Sea of Statistics
Hi Casana...below what my FMEA course addressed...and btw, I can highly recommend all the AIAG courses, well constructed, thorough and a good user interface, i.e. very few IT issues.. Hope this helps
Sidney Vianna IATF 16949 News AIAG/VDA harmonized approach to FMEA IATF 16949 - Automotive Quality Systems Standard 0
S AIAG-VDA FMEA tutorial and completely filled FMEA FMEA and Control Plans 1
M AIAG-VDA DFMEA 2019 - it is compulsory? FMEA and Control Plans 7
Casana Step 7 in AIAG/VDA FMEA form FMEA and Control Plans 17
M Should there be another column in the Optimization section (step 6) of AIAG-VDA DFMEA form? FMEA and Control Plans 1
M Inconsistency of VDA-AIAG severity table for DFMEA with the manual text FMEA and Control Plans 0
M How to record the effects of adjacent systems (shown in boundary diagram) in the AIAG-VDA DFMEA form FMEA and Control Plans 0
H RPN in AIaG-VDA FMEA Manual FMEA and Control Plans 1
OpExPro AIAG VDA FMEA Rating Tables FMEA and Control Plans 5
OpExPro The note at the bottom of DFMEA occurrence tables in AIAG VDA FMEA FMEA and Control Plans 0
OpExPro AIAG VDA DFMEA Template Required FMEA and Control Plans 6
J Which OEM or customers are now requiring the new AIAG/VDA FMEA format? FMEA and Control Plans 11
C AIAG/VDA FMEA - Is the new better? FMEA and Control Plans 0
P VDA AIAG FMEA - Slides for Quality Audience FMEA and Control Plans 4
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
B AIAG-VDA FMEA - When the new format will be required FMEA and Control Plans 6
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
K AIAG/VDA FMEA & Process Control Plans FMEA and Control Plans 0
D FMEA-MSR in the AIAG-VDA Aligned Handbook - What is it? FMEA and Control Plans 5
bobdoering AIAG VDA FMEA Handbook - 2019 - something familiar about this.... FMEA and Control Plans 37
R Information on the roll out of the new harmonized DRAFT FMEA AIAG/VDA manual IATF 16949 - Automotive Quality Systems Standard 4
xfngrs What are the VDA equivalents to AIAG manuals? VDA Standards - Germany's Automotive Standards 1
L AIAG B-10 Labeling Standard vs. VDA 4902 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
M VDA, AIAG & ISO TS 16949 Standards Differences VDA Standards - Germany's Automotive Standards 1
I What is the difference between FMEA Fourth edition (AIAG) and VDA 4.2? VDA Standards - Germany's Automotive Standards 7
J Control Plans - VDA equivalent of AIAG APQP & Control Plan Manual VDA Standards - Germany's Automotive Standards 2
S VDA vs. AIAG - FMEA Ranking FMEA and Control Plans 4
Marc Honda and ISO / TS 16949 - AIAG, ANFIA, FIEV, JAMA, SMMT and VDA VDA Standards - Germany's Automotive Standards 13
Q IATF / AIAG: Control Plans and CC / SC requirements FMEA and Control Plans 1
J Which gauge R&R to use per AIAG Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
H AIAG MSA: 4th Edition (Bias Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
E AIAG Core Tool Debacle... Reliability Analysis - Predictions, Testing and Standards 1
J Adoption of automotive (AIAG) methods and documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B Wrong standard deviation calculation in AIAG SPC manual? Capability, Accuracy and Stability - Processes, Machines, etc. 13
D Locking Control Limits and SPC Sample Sizes (AIAG/Automotive Requirements) Six Sigma 2
H Quality planning sign-off in AIAG APQP Manual IATF 16949 - Automotive Quality Systems Standard 5
abrego44 AIAG PPAP manual for service part APQP and PPAP 5
K RPN/ KC) per AIAG FMEA and Control Plans 0
A PFMEA new AIAG FMEA and Control Plans 0
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 28
S AIAG CQI Auditor Qualification and 3rd Party Certification Requirements General Auditing Discussions 2
S New AIAG FMEA Process - How to complete the new format FMEA and Control Plans 36
C Detection Action for Failure Effects - AIAG 4th Edition Layout FMEA and Control Plans 5
S I have just purchased the all new Core Tools Software (CTS) from AIAG IATF 16949 - Automotive Quality Systems Standard 39
J AIAG PPAP: 2.2.11.3 Acceptance Criteria for Initial Study (page 9, 4th edition) APQP and PPAP 1
M Is there a published List of AIAG members requiring IATF certification ? IATF 16949 - Automotive Quality Systems Standard 2
