Question... you construct this wheel combination and ship it. You put air in it. Let's say the tire is rated for... 50psi maximum.
If you think you're putting 50 in it but you're actually putting in 57 psi, you could potentially cause damage to the tire. Right? That could be a potential lawsuit. Right?
If you're suppose to put 50 and put... 20, any harm in that?
What are you contracted to do? Is there any contractual requirement with respect to air pressure?
I'm asking all of this because sometimes you do things because it's the right thing to do; not necessarily because one is told to do it.
You could set up a quick manifold, put 6-8 of these gauges on there. Have one master gauge that is calibrated. If the gauges on the manifold are within some tolerance, they're fine. You keep it simple and low cost; and you can now have assurance those gauges were checked.
