Airborne Particle Counter Calibration - 5 microns particles aerosol
MetroBioCen
Hello all. I'm trying to perform airborne particle counter calibration, but I have found troubles to count 5 microns sized particles in the aerosol. I use a Model 256 Royco aerosol generator. No problem with particle size 0,3 microns to 3 microns. I have try to calibrate Met One and Climet counters with the same result. When I generate 5 microns particle aerosol the count is erratic, with no pattern, and with just a few particles counted. Any help welcomed. Regards MetroBioCen
Marc
Another quick "Bump". Can anyone help with this one? My Thanks in advance!
BradM
Hello there!:bigwave:
I am certainly not an expert or anything; but I'll give it a try.
I guess I'm trying to figure things out here. Are you suggesting that you have an aerosol generator that is supposed to emit .3µ, .5µ, 3µ and 5µ particles.
You have two calibrated particle counters (a Met One and a Climet) and neither one of them are picking up the 5µ particles?
Now, is this when it is in free standing, testing the setup, or is it when you are challenging the HEPA filter?
If it is while you are challenging the filter, I would surmise the filter is removing the large particles. If it is free standing, then either there is an issue with the generator, or something is hinky with the two particle counters.
5µ particles should be fairly easy to pick up, if they are present
Andre
Hope that you came right with the particle generator.
Can you calibrate a Royco unit and a LasairII?
Can you give me a quotation?
MetroBioCen
Thank you everybody for your answers. :)
Well, not in esence.
Y generate an aerosol with .3, .5, 1, 3, 5 microns particles, but each one alone.
No. I'm trying to calibrate the counter. In fact I'm trying to develop the Know-How for calibrate this counters in my enterprise.
When using .3, .5, 1, 3 I see the particles presence pattern in the osciloscope, but this do not happen when I use the 5 microns particles.
It's a headache :frust: :confused:
We have Royco and LasairII counters but we have not try to calibrate them yet. We will do it in future.
Quotation? Well.....Not now, maybe in future.:D
Cheers
MetroBioCen.
MetroBioCen
Help, please!!! I had spent the whole day try to obtain a 5 microns aerosol. It is imposible. Wha I am doing wrong? I use DUKE Standards particles. Help me please.
MetroBioCen
Yesterday I found two details with my calibration procedure.
1.) I was using a Tygon transparent hose, so the enviroment light affected the measurement introducing white noise. I solved it covering the inlet with a dark cover.
2.) I used nytrogen instead of air. The noise reduced considerably.
Regards.
Still needing help on 5 microns particles aerosol.
M ISO 14644 Airborne Particle Count Testing Requirements Miscellaneous Environmental Standards and EMS Related Discussions 6
E Airborne Medical Equipment EMI/EMC IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S Airborne Survey Legal Compliance - OHSAS 18001 Occupational Health & Safety Management Standards 2
A Class 8 100,00 Cleanroom - Airborne Microbial Count ISO 13485:2016 - Medical Device Quality Management Systems 6
P ISO Class 8 particle count (annual certification vs monitoring) ISO 13485:2016 - Medical Device Quality Management Systems 4
Q ISO 3310 Clarification Help - Aperture sizes for sieves used for particle sorting Other ISO and International Standards and European Regulations 2
I Compressed air system qualification and 1 micron particle analysis Other Medical Device Regulations World-Wide 0
I FDA requirement for 0.5 and 5 micron particle monitoring US Food and Drug Administration (FDA) 0
S Cleanrooms - Particle Measuring - ISO 14644 Other Medical Device and Orthopedic Related Topics 3
R Closing out an API/ISO QMS Audit Nonconformance - Magnetic Particle Examination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S Magnetic Particle Inspection Non-Destructive Testing Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
Ron Rompen Particle Size Templates General Measurement Device and Calibration Topics 7
J Kanomax hand held Laser Particle Counter Calibration Calibration Frequency (Interval) 6
N Requirements for the Classification of Cleanrooms other than the Particle Count Other ISO and International Standards and European Regulations 5
V Image Analysis - Particle Measurement (Characterization) - Validation - Calibration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Hiac Royco 256 Particle Counter Calibrator Manual - Any Copies for Sale? Calibration and Metrology Software and Hardware 1
K SPC to apply for Particle in Clean Room Class 100 Statistical Analysis Tools, Techniques and SPC 7
E Liquid Particle Counter - Which test is for OQ and which on is for PQ? Quality Tools, Improvement and Analysis 4
S NADCAP and CCA (Particle Counting) in a Controlled Contamination Area - Standards AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Setting Control Limits for Particle Counts Statistical Analysis Tools, Techniques and SPC 9
D Which Handheld Air Particle Counter do you recommend? Other Medical Device and Orthopedic Related Topics 8
L ISO 14644 Result Sheets for Particle monitoring and related monitoring? Other ISO and International Standards and European Regulations 2
Q Interpreting calibration result of Air Particle Counter on Counting efficiency General Measurement Device and Calibration Topics 1
A Particle Counter Results - Interpreting Data for a Class 100,000 Cleanroom Other Medical Device Related Standards 12
L Magnetic Particle Inspection - Where's the threads? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
C In-House Particle Counter Calibration General Measurement Device and Calibration Topics 12
ISOsandy ISO 14644-3 - Testing Air for Particle Counts Other ISO and International Standards and European Regulations 10
E Dust Particle Counter Model: Handilaz 301 Operation Manual General Measurement Device and Calibration Topics 3
D Gage R&R on a delta measurement - Particle measurement count tool Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
I Clean Rooms Training - Particle release (personel), Sedmentation velocity of particle ISO 13485:2016 - Medical Device Quality Management Systems 2
Z Labeler Code - Private labelling for OTC (Over the Counter) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
R Contract Manufacturing - OTC (Over the Counter) vs Prescription Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
C Very Small OTC (Over The Counter) Pharmaceutical Company Requirements US Food and Drug Administration (FDA) 6
I Selling Over the Counter Medical Devices in France EU Medical Device Regulations 3
R Do generic forms bought over the counter need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S FDA and OTC (Over the Counter) Software Use Classification Medical Information Technology, Medical Software and Health Informatics 9
P Over The Counter (OTC) vs. POM (Prescription Only Medicine) Other Medical Device Regulations World-Wide 11
H OTC (Over The Counter) Wipe Product Labeling Guidelines - Question Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 6
B Over Size Diameter Counter Sinks - Shop Practice Standard or BAC Specification Manufacturing and Related Processes 3
Q Prescription vs. OTC (Over the Counter) Medical Device in Canada Canada Medical Device Regulations 4
N OTC (Over The Counter) Product FDA Label Change Requirements US Food and Drug Administration (FDA) 2
Ron Rompen Looking for counter for my inspector to tally the number of defects discovered Manufacturing and Related Processes 3
J0anne Prescription Only vs. Over The Counter Pharmaceuticals because of State Laws 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
R Would you accept company's counter offer to stay on? Career and Occupation Discussions 28
B Problems with a counter bore & the I.D. hole - .0685mm to .0762mm I.D. hole Manufacturing and Related Processes 9
A TPM Template Sheets and Counter Measure Sheets - Robot Welding Systems Preventive Action and Continuous Improvement 1
Marc Single-electron counter breaks new record World News 0
