All Measurements taken with a Variable Gage have to be Recorded 100%
I've not yet had time to complete a gap analysis for transition to IATF from TS - I am transitioning summer 2018.
Someone from management asked me today about a "rumor" they heard. The rumor was that any/all measurements taken with a variable gage have to be recorded 100% once we are under the IATF standard. I find this hard to believe, but can anyone at least guess what FACTS this confusion may have come from? TIA! :thanx:
Peters
If record is required.
If required - digits are needed.
If not required - no record and no problem.
9.1.1.1 Monitoring and measurement of manufacturing processes
d) records of actual measurement values and/or test results for variable data;
When you are recording variable data, you are now required to record the actual value.
What is not acceptable is just a checkmark (yes we tested).
Ok that makes a little more sense I think, if I understand you correctly. It sounds like you're saying that wherever there are special characteristics or that otherwise require SPC using variable gages, we just can't have a sheet out there to record GO/NG - that we have to record actual result. I don't know how anyone could say they were doing SPC if all they did was record accept/reject, so actual readings is of course what we're already doing. What had people nervous was the thought that we had to start recording every variable measurement we do, regardless if special characteristic or otherwise required by customer. So does it apply like I'm saying here, or is it truly that every variable measurement has to be recorded?
Golfman25
According to the verbage, if you measure it you need to record the actual measured value. So it doesn't deal with only SPC. There may be non-spc measurements you take that need to be recorded. So if it's burdensome, you'll likely review everything to see if it makes sense to measure it any longer.
JamesHawes
We have just completed the IATF transition audit with 0 Majors and 8 minors. One of our minors was on this topic. We have gages that we zero to a master ( the master is the nominal spec) and the operator writes how far they are from zero which would be measuring to the tolerance. ex. 25.125 +-.125 spec, the operator would write +.023 or whatever value would be. The auditor finding was they had to write it as 25.148 not +.023. How does everyone else interpret this?
Golfman25
Your auditor sounds like a tool. You recorded the actual value. You didn't do the math. I would push back on that one. What BS. I think the requirement was to get away from ok, or check. Stuff like that. Good luck.
jfries2
We have a control plan requirement to measure a feature in 3-7 locations, and to record the maximum and minimum measurements. This is being performed and variable data is recorded for the min/max as required. An internal audit recorded a finding against IATF 9.1.1.1.d stating that since 3-7 measurements are required, they should all be recorded. We are debating this and probably splitting hairs, but 9.1.1.1.d does not state that all measurements must be recorded. Thoughts on this?
Sebastian
ISO 9000:2015
3.8.10 Record - document stating results achieved or providing evidence of activities performed.
Auditor witnessing measurements is able to state conformity to monitoring requirements. Now. What about yesterday, last week when only records are available?
W "Accurate to ±2%" means "64% of measurements should be within 2% of the actual value"? US Medical Device Regulations 4
G Why are 17025 scope angle measurements limited to 5 to 85 degrees? ISO 17025 related Discussions 2
F Recording Electrical Measurements ISO 17025 related Discussions 2
N R&R for Differences between 2 measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
S Is using ANSI/ASQ Z1.4-2008 the correct sampling plan to determine Pass/Fail of Apparel measurements? AQL - Acceptable Quality Level 8
N New (Upgraded Technology) vs Existing Equipment - Measurements Shift Design and Development of Products and Processes 4
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Q Measurements after Calibration Expiry General Measurement Device and Calibration Topics 13
chris1price Error in data recording - Recording measurements in SAP Capability, Accuracy and Stability - Processes, Machines, etc. 2
G How many Uncertainty Measurements for Micrometers and Calipers? Measurement Uncertainty (MU) 3
T GR&R Data from Caliper Measurements APQP and PPAP 3
L Color measurements R&R: what's wrong with white? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Standard for Rounding Measurements for Labels Other Medical Device Related Standards 9
M 10 parts, 3 operators, 3 measurements GR&R study tolerance question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Uncertainty measurements for a 6 inch caliper Measurement Uncertainty (MU) 11
C MU (Uncertaincy of Measurements) definition and MU Factors Measurement Uncertainty (MU) 4
C Measurements of Major Diameters of plug thread gages General Measurement Device and Calibration Topics 12
J Can some measurements be considered information only and not need calibration? General Measurement Device and Calibration Topics 7
C Chamfer Measurements - Do you measure the height and width or the hypotenuse? Manufacturing and Related Processes 15
5 Number of 'significant digits' in measurements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
S TL 9000 Certified Companies - REMINDER - TL 5.0 Measurements Effectivity - July 2013 TL 9000 Telecommunications Standard and QuEST 1
S US and Metric Measurements in same Document Other ISO and International Standards and European Regulations 4
P Uncertainty of Measurements for Adhesive Weights for Peel Testing Capability, Accuracy and Stability - Processes, Machines, etc. 2
G Improve final GR&R value by taking average of more measurements? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
R Using Curve Fits and Predictions in place of good old Measurements General Measurement Device and Calibration Topics 3
CycleMike 7.6.1 - ".....type of measurements system" and Plug Go/NoGo gages IATF 16949 - Automotive Quality Systems Standard 4
R Procedure for Measurement Uncertainty Estimation for Electrical Measurements Measurement Uncertainty (MU) 2
C The Dreaded Uncertainty Measurements - Confidence in your results Measurement Uncertainty (MU) 1
T Implementing SPC - Control Chart for Individual Measurements Statistical Analysis Tools, Techniques and SPC 9
C Building a Dimensional Metrology Laboratory to Inspect various Physical Measurements General Measurement Device and Calibration Topics 2
S Is it alright to let the supplier do all measurements and inspection? Quality Manager and Management Related Issues 10
J TL9000 Common Measurements - Design and Development for Telecommunication Products TL 9000 Telecommunications Standard and QuEST 5
C Referencing or Using a Master Part to take Measurements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K Measurements - Sphere in contact with a plane General Measurement Device and Calibration Topics 3
V Importance of Replicate Trials/Measurements in DOE Trials Statistical Analysis Tools, Techniques and SPC 2
A Burrs affecting measurements and Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 7
F Supplier Measurements vs. Incoming (Receiving) Measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
D Gauge Analysis with 2 Complimentary Measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q Shipping Measurements (Measurables) other than On-Time Delivery ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Not Enough Resolution for Gage R&R - 79" Panel Length Measurements Help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M PPAP including FAI Parts - Customer is requiring 5000 measurements APQP and PPAP 15
K Are Surveys and Interviews considered Objective Measurements? Internal Auditing 25
T Vernier Caliper Accuracy Issue - Inside measurements were slightly off General Measurement Device and Calibration Topics 7
R Problems Making Measurements - Agilent 8902A Measuring Receiver Calibration and Metrology Software and Hardware 4
S A2LA requirements for Electrical Uncertainty Budgets - Measurements with a slope Measurement Uncertainty (MU) 3
B MS Access to document metrics and performance measurements? Preventive Action and Continuous Improvement 1
C Measurements (Dimension) Data Anaylsis - Methods to determine trends Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Small Variation in Thickness Measurements in Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 23
