All Measurements taken with a Variable Gage have to be Recorded 100%
John C. Abnet
Teacher, sensei, kennari
#11
Good day @jfries2. As noted in other responses, there is indeed a requirement to record actual data and not simply PASS-FAIL result. However, I would caution that we keep this requirement in context of the standard and the intent of the standard. Note the opening line in 9.1.1.1...
" ..shall perform process studies on all new manufacturing....processes..."
While product measurement is indeed a method to verify process capability, this clause is not speaking to the ongoing product verification that may or may not be part of the agreed upon control plan. The control plan is the "contract" with the customer in regards to how/when product will be verified...(assuming it is not contrary to other contractual agreements such as CSR, etc...)
Be well.
Golfman25
#12
We have a control plan requirement to measure a feature in 3-7 locations, and to record the maximum and minimum measurements. This is being performed and variable data is recorded for the min/max as required. An internal audit recorded a finding against IATF 9.1.1.1.d stating that since 3-7 measurements are required, they should all be recorded. We are debating this and probably splitting hairs, but 9.1.1.1.d does not state that all measurements must be recorded. Thoughts on this?
I think it is common practice to simply record high and low readings -- the assumption being that everything else fell within the high and low. We even had an auditor suggest this. I think it is a valid technique to cut down on data overload. I stick with it and challenge any finding to the contrary.
jfries2
#13
Be well.
Actually 9.1.1.1 is speaking to the ongoing product verification as well as initial process capability. The second paragraph begins with "The organization shall maintain manufacturing process capability"...... followed with "shall verify that the process flow diagram, PFMEA, and control plan are implemented".....
John C. Abnet
#14
The key term is "...maintain process capability..." This clause is not intended to "step on" clauses 8.6 and 9.2.2.4
The original question was ..." We are debating this and probably splitting hairs, but 9.1.1.1.d does not state that all measurements must be recorded. Thoughts on this?'
Short answer: No, all of the measurements do not need recorded. What in the standard or agreement with your customer would cause your organization to believe this to be so?
You indicated that your control plan states "...requirement to measure a feature in 3-7 locations, and to record the maximum and minimum measurements" (I will assume here that it is agreed to by the customer and no other contractual requirements exist). You have met the contractual agreement with the customer (control plan) and not violated any standard requirements (based solely on the content/context of this conversation).
Be well.
jfries2
#15
Thanks for your reply John. I agree with your conclusion. Again, this was an internal audit finding which has led to this discussion. The only obligation to the customer is the control plan, which is being met.
N R&R for Differences between 2 measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
N New (Upgraded Technology) vs Existing Equipment - Measurements Shift Design and Development of Products and Processes 4
E MSA Study on MTS dynamic rate measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Q Measurements after Calibration Expiry General Measurement Device and Calibration Topics 13
chris1price Error in data recording - Recording measurements in SAP Capability, Accuracy and Stability - Processes, Machines, etc. 2
G How many Uncertainty Measurements for Micrometers and Calipers? Measurement Uncertainty (MU) 3
T GR&R Data from Caliper Measurements APQP and PPAP 3
L Color measurements R&R: what's wrong with white? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Standard for Rounding Measurements for Labels Other Medical Device Related Standards 9
M 10 parts, 3 operators, 3 measurements GR&R study tolerance question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Uncertainty measurements for a 6 inch caliper Measurement Uncertainty (MU) 11
C MU (Uncertaincy of Measurements) definition and MU Factors Measurement Uncertainty (MU) 4
C Measurements of Major Diameters of plug thread gages General Measurement Device and Calibration Topics 12
J Can some measurements be considered information only and not need calibration? General Measurement Device and Calibration Topics 7
C Chamfer Measurements - Do you measure the height and width or the hypotenuse? Manufacturing and Related Processes 15
5 Number of 'significant digits' in measurements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
S TL 9000 Certified Companies - REMINDER - TL 5.0 Measurements Effectivity - July 2013 TL 9000 Telecommunications Standard and QuEST 1
S US and Metric Measurements in same Document Other ISO and International Standards and European Regulations 4
P Uncertainty of Measurements for Adhesive Weights for Peel Testing Capability, Accuracy and Stability - Processes, Machines, etc. 2
G Improve final GR&R value by taking average of more measurements? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
R Using Curve Fits and Predictions in place of good old Measurements General Measurement Device and Calibration Topics 3
CycleMike 7.6.1 - ".....type of measurements system" and Plug Go/NoGo gages IATF 16949 - Automotive Quality Systems Standard 4
R Procedure for Measurement Uncertainty Estimation for Electrical Measurements Measurement Uncertainty (MU) 2
C The Dreaded Uncertainty Measurements - Confidence in your results Measurement Uncertainty (MU) 1
T Implementing SPC - Control Chart for Individual Measurements Statistical Analysis Tools, Techniques and SPC 9
C Building a Dimensional Metrology Laboratory to Inspect various Physical Measurements General Measurement Device and Calibration Topics 2
S Is it alright to let the supplier do all measurements and inspection? Quality Manager and Management Related Issues 10
J TL9000 Common Measurements - Design and Development for Telecommunication Products TL 9000 Telecommunications Standard and QuEST 5
C Referencing or Using a Master Part to take Measurements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K Measurements - Sphere in contact with a plane General Measurement Device and Calibration Topics 3
V Importance of Replicate Trials/Measurements in DOE Trials Statistical Analysis Tools, Techniques and SPC 2
A Burrs affecting measurements and Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 7
F Supplier Measurements vs. Incoming (Receiving) Measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
D Gauge Analysis with 2 Complimentary Measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q Shipping Measurements (Measurables) other than On-Time Delivery ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Not Enough Resolution for Gage R&R - 79" Panel Length Measurements Help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
M PPAP including FAI Parts - Customer is requiring 5000 measurements APQP and PPAP 15
K Are Surveys and Interviews considered Objective Measurements? Internal Auditing 25
T Vernier Caliper Accuracy Issue - Inside measurements were slightly off General Measurement Device and Calibration Topics 7
R Problems Making Measurements - Agilent 8902A Measuring Receiver Calibration and Metrology Software and Hardware 4
S A2LA requirements for Electrical Uncertainty Budgets - Measurements with a slope Measurement Uncertainty (MU) 3
B MS Access to document metrics and performance measurements? Preventive Action and Continuous Improvement 1
C Measurements (Dimension) Data Anaylsis - Methods to determine trends Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Small Variation in Thickness Measurements in Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 23
M DIN6930 What table to use - Tolerances of straight line and radii measurements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J What is ratio or reciprocity-type measurements in ISO15189 General Measurement Device and Calibration Topics 2
F SPC for Dummies - Measurements by cavity in a program called QcCalc Statistical Analysis Tools, Techniques and SPC 3
