All ODs on the part need to be concentric within 0.07 TIR - What does this imply
True Position
#11
Re: All ODs on the part needs to be concentric within 0.07 TIR - What does this imply
Y14.5 specifies concentricity as median points of the controlled feature relative to a datum axis. ;)
Stijloor.
Right, and a square has exactly the same median point between opposite sides so it is perfectly concentric.
#12
There was a time, in the deep dark past, when dinosaurs roamed the earth and GD&T was not widely known or used. The callout in question was written in those dark ages, and it was commonly seen in the wild. While "concentricity gage" is certainly a misnomer, that's what those things have always been called. At the time the drawing in question was issued, standard practice was to use something like that (or even the centers on a lathe) to rotate the part while indicating on the target diameter. Standardized GD&T came into being (in large part) because of issues like this.
True Position
#14
Agreed, the use of concentricity when the intent is runout is very common still now. Occasionally an engineer will see 'concentricity' on his list of GD&T symbols and put it on a drawing intending runout. 'Coaxial' is also used the same way.
Stijloor
#15
Yes, very much so... Still a lot of (educational) work to do...
Stijloor.
bobdoering
Stop X-bar/R Madness!!
#16
Off topic but interested:
I thought you could not check roundness accurately rotating directly on the part due to the potential of getting a part with lobing that hides some of the out of round. Same reason you can't use a V-block? I was always under the impression that you needed something which moved completely independent of the part. (Like the two types of roundness checkers or a CMM.)
You are correct. If you place the indicator over the rollers, it is roundness. It may contain error by not being correct for the lobing in the part. If you had 3 lobe parts, it would be better than a micrometer (2 point measurement - which is only good for 2 lobe parts). Very similar to the process for choosing the correct number of jets on an air gage.
To capture roundness without influence of lobing error (and better yet, actually determining the lobing) you would have to have a roundness checker (e.g. Talyrond) or CMM with sufficient data points. However, as a lower cost (although they are not cheap!) option for shop floors, it may be adequate to use the "concentricity" gage for roundness if the lobing is known to be 3-lobe.
bobdoering
#17
I just saw a print where they called out concentricity instead of roundness (which is what they really meant). I made sure the engineer currently responsible for that part corrected the error - fast. Big difference!!
N
naghee
#18
I have to agree with True Position when he/she states that they probably mean runout. Concentricity would apply to the centerlines and not the diameter surface. Measuring the TIR on the surface of the diameter compounds the error by accumulating both the concentricity variation and the roundness varition together into one TIR number.
Not to confuse matters anymore, but has any consideration been given to total runout versus regular (any element) runout?
:confused:
The Impeller is mounted on a tapered shaft with a locking mut hold it in position. Then, the dial gauge was set, and the impeller rotated on its center axis.
No i have not considered the total runout.
I feel that, the note is not clear enough to say " the ODs need to be within a certain tolerance with reference to the OD."
If held by the shaft, and measure TIR of ODs "A", "B" and "C" what is the acceptable TIR as per the note?
Held by OD "A" and measure TIR of OD "B" and "C" what is the acceptable TIR as per the note?
held by OD "B" and measure TIR of OD "B" and "C" what is the acceptable TIR as per the note?
The problem is one of the OD is verymuch offcentric to the centerline, and I am not sure if I need to fix the drawing note.
True Position
#19
From how you posted the note, "All ODs on the part needs to be concentric within 0.07 TIR" for each of your examples the answer is 0.07.
I would setup holding on each diameter one at a time and check all of the other OD to 0.07. Rewriting it to say runout is a good idea, but the intent seems clear.
alspread
#20
You have the ability to change the print? I must have missed that. I assumed you were working with an old drawing that was going to be difficult if not impossible to correct.
If you have the ability to change the print, then by all means you should. Modern practice would dictate establish ment of an apropriate datum and specifying the relationship requirement of other features to the datum.
If the diameter that is eccentric has no function or impact on the performance of the system, then perhaps you can apply a larger tolerance to that feature.
F Physical Part Measurement General Measurement Device and Calibration Topics 4
S Clean room not part of my certification ISO 13485:2016 - Medical Device Quality Management Systems 2
A MDR ANNEX XI part A or Part B EU Medical Device Regulations 0
J Part submission warrant for Level 1 PPAP APQP and PPAP 1
K How to handle GTINs for different configurations of one device with one part number? Other Medical Device Related Standards 0
A 60601-1 : Integrated Dry ECG Electrodes = 2 Patient connections inside 1 applied part? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
D Separation of F-type applied part and remaining parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
V Part selection for R&R studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
D Is PMCF really a continuous activity per Annex XIV,Part B? EU Medical Device Regulations 5
M 21 CFR 820 vs 21CFR820 vs 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
N BF-type applied part MOPP vs secondary IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Relabelling a component that will be sold as a spare part - Do I become legal manufacturer? EU Medical Device Regulations 2
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Anonymous16-2 21 CFR Part 11 - Steps to take if we want to validate an electronic system Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
T ISO 13485 8.3 - Non-Conforming Materials - on-line rework or part of process? ISO 13485:2016 - Medical Device Quality Management Systems 11
K IEC 62304 compliance - Code reviews as part of verification strategy IEC 62304 - Medical Device Software Life Cycle Processes 5
A 21 CFR part 11 - section 11.100 - Electronic Signature Certification Other US Medical Device Regulations 6
M AS9102B Detail Part/Assembly FAI Form 1 box 13; AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M 2xMOPP insulation for Applied Part B. IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
A ISO 41001:2018 - Clause No.8 Operations Part Quality Management System (QMS) Manuals 2
NDesouza Getting Rid of Part Marking Errors Benchmarking 40
L Wearables 21 CFR Part 11 compliance Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
DuncanGibbons How are part cut out specimens made and tested? Manufacturing and Related Processes 1
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 16
Ed Panek 21 CFR Part 820 - FDA Label Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
S CQI-23 - Molding System Assessment - Control of part weight IATF 16949 - Automotive Quality Systems Standard 5
DuncanGibbons Looking for example aerospace part CAD files to be used for a case study Career and Occupation Discussions 2
T Overvoltages consideration in Applied Part for RMS Calculation. IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
M Informational How to perform a clinical evaluation of medical devices – Part 2 – Level of clinical evidence and what sufficient clinical evidence means Medical Device and FDA Regulations and Standards News 9
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
S FAIR - If we have not produced a part in over 2 years, but nothing has changed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P Scope of application for IEC 60601-1-11 Medical electrical equipment — Part 1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Informational Creating a post market surveillance (PMS) system for medical devices – Part 1 Medical Device and FDA Regulations and Standards News 7
Ed Panek Part 11 Self Certify Memo - What else should it cover? Qualification and Validation (including 21 CFR Part 11) 5
M Informational How to perform a clinical evaluation of medical devices – Part 1 – Overview and sample of activities Medical Device and FDA Regulations and Standards News 0
rezayatmand IEC 60601-2-18 Medical electrical equipment - Part 2-18: Particular requirements for the basic safety and essential performance of endoscopic equipmen IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Question on determining defective units - I am not recording fixture to part rejected Statistical Analysis Tools, Techniques and SPC 5
C Serialised Defective Part Replacement EU Medical Device Regulations 4
B F-type applied part - Separation from ALL(?) other parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
N Use part of high risk device for establishing low risk device EU Medical Device Regulations 0
N Can we take a part from 510k cleared medical device and use it in class I device? Other US Medical Device Regulations 3
F 21 CFR Part 11 - Implicit requirements - Validation plan for a Software as a Service Other US Medical Device Regulations 1
M Informational Some things the EU MDR 2017/745 does not tell you, but you may need to know to comply with it effectively – Part 1 Medical Device and FDA Regulations and Standards News 0
