Allowance for Slip Fit - Additional Allowance applied to GO NO GO Plug Gage
Caster
An Early Cover
Help - a bit of a heated debate going on here today
Can additional allowances be applied to a GO NO GO plug gage?
For example an "allowance for slip fit"
Yes or No would be great, but can you please also point me to an authoritative reference document one way or the other.
Re: Additional allowance applied to plug gage
What's the application? What's meant by "slip fit"? In general, it's expected that a go or no-go member will either fit or not fit, and it sounds like someone's trying to add some sort of fudge factor.
Kales Veggie
People: The Vital Few
Is your heated debate about designing the Go/NoGo plug dimensions or using it?
If it is the first (design), it depends on the final application and your customer requirements. I recall a shaft OD and a bearing ID having a 5 micron difference between maximum shaft OD and minimum Bearing ID, for example.
If it is the second (use), Jim is correct.
michellemmm
Quest For Quality
It has been years... I have not been involved in gage design since college... So, please feel free to correct me if my memory is deteriorated.
In England, there are three classes of fit:
1- Running or slip fit.
2- Interference fit
3- Press fit.
The allowance we used to add.... was "wear allowance" which was added to maximum material condition.
W
world quality
Maybe what I see is the old way of ordering gages for plug and ring.
Tolerance as stated at end
xx- precision lapped ( Plugs or Male Masters.
x - Precision lapped ring and plugs
Y - Lapped plug or ring
z - ground and polished
zz - Grounded only
This can range between 0.00002 to 0.0008 for tolerance due to size.
Caster
An Early Cover
Is your heated debate about designing the Go/NoGo plug dimensions or using it?If it is the first (design), it depends on the final application and your customer requirements. I recall a shaft OD and a bearing ID having a 5 micron difference between maximum shaft OD and minimum Bearing ID, for example.If it is the second (use), Jim is correct.
The customer print calls out a size and a tolerance. We happen to know (or at least we think we know) that the shaft that our hole fits over is much smaller. But this is not shown on our print.
It seems the arguement is that if we get really close to the gage size it gets stuck, so some people wish to apply a slip fit allowance. But then what will happen when we get close to that size?
The debate seems to have settled down for now. We're going to do "a study".
The only place I ever found a description of how to size a plug gage was in the Machinery Handbook, but I don't have a copy right now.
Has anyone got any links?
Stijloor
Hello Caster,
Machinery's Handbook. You can even search in this book.
Hope this helps.
Stijloor.
Caster
An Early Cover
The only place I ever found a description of how to size a plug gage was in the Machinery Handbook, but I don't have a copy right now. Has anyone got any links?
OK, I found this helpful link, posted here for anyone else with this situation
http://www.vermontgage.com/tech/archive/rules.pdf
Page 4 tells all...including the always mysterious X, XX, Y, ZZ class defined so I can understand it!
Thanks to Vermont Gage!
U
Umang Vidyarthi
IMO the title is not correctly worded,since Slip Fit (and for that matter,press fit/shrink fit/force fit etc.) is not applicable for GO/NOGO plug gages.
/Umang :cool:
S Bend allowance formula to calculate per degree per radii Manufacturing and Related Processes 2
S Agreement for allowance for visual criteria after submission APQP and PPAP 1
P Taper Callout - Allowance in terms I've not seen before Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D Demonstration Reliability Test Formula with allowance for 'x' Failures Reliability Analysis - Predictions, Testing and Standards 6
S Draft Angles (aka Draft Allowance) - Plastic Injection Molded Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
C Manufacturing Allowance through Statistical Method Statistical Analysis Tools, Techniques and SPC 4
V Best CAPA for slip in simple-yet-persistent oversight-review mechanism Nonconformance and Corrective Action 7
G Slip fit - Size on size dilemma for pin and plug gages Manufacturing and Related Processes 4
N Where to buy non-slip pad or material or non slip balancing machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T Bias and Linearity with Slip Gauge: Low R-Squared Value Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T Google Fit Health datas and Medical devices Application Medical Information Technology, Medical Software and Health Informatics 0
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
Ed Panek Can a single supplier fit two or more categories for risk? ISO 13485:2016 - Medical Device Quality Management Systems 2
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Where does FMEA fit in your ISO 14971 Risk Management process? ISO 14971 - Medical Device Risk Management 13
K Which clause would best fit this Nonconformance? (Supplier Related) Internal Auditing 2
H Conveying Form Fit and Function Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D eQMS/ERP System Admin Work Instructions - Where do they fit? Misc. Quality Assurance and Business Systems Related Topics 5
N AIAG 4th ed. FMEA Manual "Fit" Changed to "Appearance" - Fit severity? FMEA and Control Plans 2
Ron Rompen Question on 'Class of Fit' - Gage Pin Clearance Manufacturing and Related Processes 2
J Where does process validation fit within design & development? Design and Development of Products and Processes 7
ScottK Importing medical device for use in fit testing of packaging Other US Medical Device Regulations 3
O Design and Development Process - Does one size fit all? ISO 13485:2016 - Medical Device Quality Management Systems 13
D Where does the QMS (Quality Management System) fit in your organization? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Where does 5S technique fit into ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K Minitab Lack-of-Fit Test in DOE (Design of Experiments) Using Minitab Software 4
M Best Fit Alignment vs. Hard Datums Calibration and Metrology Software and Hardware 5
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
V Lack of Fit vs Pred-R-Square. Using Minitab Software 3
E How to Properly Apply Linearity - How does it "Fit"? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P Where do training documents fit into the ISO 9001 categories? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Nonlinear Fit for a Complicated Curve - Fitting a Function to the Data Statistical Analysis Tools, Techniques and SPC 6
K So confused with AQL - How does AQL (Acceptable Quality Level) fit with my company AQL - Acceptable Quality Level 7
A Trying to fit a GLM - Minitab 16 negative Error df Using Minitab Software 4
V What kind of Data should support Fit/Function Characteristics? APQP and PPAP 1
J Definition Form Fit or Function - Materials Composition and Manufacturing Processes? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
Q Software that will fit the bill of Igrafx Process compatible with Macintosh? Quality Assurance and Compliance Software Tools and Solutions 1
bobdoering William A. Levinson speaks on When the Bell Curve Doesn?t Fit, Part 2: Non-Normality Statistical Analysis Tools, Techniques and SPC 0
J Which chapter in Quality Manual will best fit this form (truck reservation)? Quality Management System (QMS) Manuals 1
B Where do policies fit in the setting up of a Quality Management System (QMS)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M TS 16949 and Form, Fit or Function? What about Calibration of Oven Controllers? IATF 16949 - Automotive Quality Systems Standard 5
bobdoering Goodness of Fit: Is it normal? Probably...or probably not - it's all probability Imported Legacy Blogs 0
S I am asked to fit 2 lines - Basic Minitab Question - Quick Help needed Using Minitab Software 1
P Liquid Nitrogen to shrink fit a new plug into a hole in a casting Manufacturing and Related Processes 7
Manix ELV - Vehicle Scope (where do agricultural and construction type vehicles fit in?) RoHS, REACH, ELV, IMDS and Restricted Substances 3
T Organizational Charts - Where does the Quality Assurance Manager fit in Quality Manager and Management Related Issues 30
T Accuracy of the SN 29500 FIT values - Reliability Forecast and PPM Reliability Analysis - Predictions, Testing and Standards 3
