Always one root cause?
Pau Calvo
#21
My company works for several T1 automotive suppliers and each one uses diferent aproches to define how many and which types of RC exist or must be identified.
I usually work with 8D methodology, that in most variations identifies 3 types of RC, occurrence root cause, detection root cause and systematic root cause.
In may experience normally a failure is not only determined by one sole cause, atleast the production process, the detection process and the system have to fail.
As example: why your inspection facility have this lightning conditions? When the process was designed was taken in account? If not you may have a issue with your process design system and this problem can occur trough several parts or projects...
AMIT BALLAL
#22
Were these defects damage that the inspector created or were they ‘escapes’ that the inspector failed to ‘catch’?
So you have data that proves that the inspector who was ‘tired’ because they worked double shifts was the primary source of the ‘defects’? What was their defect rate compared to other inspectors? Did this inspector’s defect rate go down when they only worked 1 shift?
How did you determine that poor lighting was a secondary cause of defects?
Forget the talk about fishbone diagrams and why-why. These are only guessing and questions that try to lead you in the right direction. It is the data that answers the questions and proves the conclusions or claims of causality. Can you answer the above questions?
What I understood based on all the information shared by qualprod is it is for non-detection of defect (not occurrence).
qualprod, please correct me if I'm wrong.
Randy
#23
"Frequent bad inspection of product, which cause rejects." Well then beat the inspectors, strike fear into their hearts. Give 'em a time out.
Seriously could it be something as simple as they really aren't sure what is good and what isn't? or
They're hesitant to fail something because of potential upstream and downstream problems within the organization itself that could occur. or
Your inspectors just don't care one way or the other?
Sometimes cause analysis isn't scientific, mumbo-jumbo, requiring charts and graphs and super-duper analysis, it's just people being people.
#24
to be clear I've never used mumbo-jumbo or 'super-duper' analysis in terms of people but I also haven't used guesses hunches or bias that people are just plain lazy and incompetent. good cause analysis still requires evidence and data at some level - not theories and not over-analysis.
Randy
#25
A long, long time ago when my Attack Helicopter Troop was putting on a live fire demonstration for our Governor (some guy named Clinton if I remember correctly) and other dignitaries, one of our #1 gun pilots, clear of mind, so far beyond basic competence it was off the scale and probably 10,000 plus hours of stick time touched the wrong button and instead of firing 18 2.75 inch rockets, each containing 17 pounds of very high explosive were jettisoned and rolled across the ground about 75 feet below us going every way but the one intended, relieved of out load we went up like a runaway elevator nearly out of control....The outcome of this adventure resulted in an investigation by the Army Aviation Safety Office and you know what the outcome was....Oops! George said that he had just touched the wrong button, I saw him touch the wrong button, and our unit commander in the other seat told George at the time "You hit the wrong button" All the cause analysis, all of the investigation with charts, graphs and everything else resulted in what we knew from the start ...Oops you touched the wrong button. That's what I was getting at, the defects can be nothing more than....Oops and not a slam at people or anything else.
qualprod
#26
Amit
Yes, were non detected problems
Randy
They are capable ( have the competence, knowledge, know the criteria to accept o reject product) the
problems happend because inspector was tired (working two shifts for three continuous weeks) and when outside is cloudy,
the light into the inspection room is not adequate (light affects directly at inspections).
Have to detect deltas of tones in colors in labels.
Hope my explanation is clear.
#27
Amit
Randy
When everything is messed up, everything needs to be fixed.
Mike S.
Happy to be Alive
#28
Amit
Randy
If nonconforming material gets through Inspection because of the reasons listed above, it is not a failure on the part of the Inspector(s) it is the failure of Management for grossly overworking their Inspectors and failing to provide adequate resources.
Before blaming people you need to very honestly and thoroughly consider whether or not they had adequate support/facilities/tools, standards, procedures, training, and leadership.
And sometimes, even if you have all of the above, you have the very rare situation that Randy described -- an unexplainable "oops" that can't be anticipated. When the consequences of such an "oops" could be catastrophic you try to build in redundant failsafes and hope and pray they are enough.
Maybe Bill just attracted these kinda events. Also down south in Clinton country, when he was just a Governor, a technician dropped a wrench in a Titan II missile silo and caused a chain of events that caued a huge conventional explosion that killed a few people, but could have resulted in the annihilation of every living thing within a radius of several miles. Risk is all about considering probability and consequences.
M Always Date format with letters After Work and Weekend Discussion Topics 17
John C. Abnet Must COPQ always be quantified as a monetary ($) amount? IATF 16949 - Automotive Quality Systems Standard 2
Stoic Manual soldering processes - 100% verifiable, or always requiring validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
M User manual / instructions for use for class II device always required? Medical Device and FDA Regulations and Standards News 3
K Is Mold qualification / process validation always required? Manufacturing and Related Processes 7
D Is formulative testing always required IEC 62366 - Medical Device Usability Engineering 1
K Do Forms and Templates ALWAYS become Records? Records and Data - Quality, Legal and Other Evidence 4
N Witty (snarky?) Responses: Always have one prepared Coffee Break and Water Cooler Discussions 25
howste AS9100 Rev D Clause 10.2 - Is Cause always required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 39
M Does there always have to be a "correction?" Problem Solving, Root Cause Fault and Failure Analysis 16
N Do new requirements always need a validation? IEC 62304 - Medical Device Software Life Cycle Processes 5
M FDA 21 CFR 820.250 - Does "valid statistical" always mean math? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
B Is SPC data For Special Characteristics always required? TS 16949 clause 8.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Is Notification of the Test Laboratory always necessary for Supplier Changes? IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
Jim Wynne APQP, or Why Things Always Go Wrong APQP and PPAP 0
R Always Internal Audit all Line Items of applicable FDA Regulations? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
O Is SPC (Statistical Process Control) always required? Statistical Analysis Tools, Techniques and SPC 4
R Problems with Supplier - Always with 100% Sorting - No Corrective Actions Supplier Quality Assurance and other Supplier Issues 22
P CSR (Customer Specific Requirements) in TS 16949 Audits - Always required? IATF 16949 - Automotive Quality Systems Standard 27
A PFMEA a 'Live' Document and should always have Open Actions FMEA and Control Plans 15
A In-Process Inspection Results ALWAYS With PPAP? APQP and PPAP 8
G AS9100C Upgrade Audit - 4.1c&f - The "Always" NCR? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
S Ppk & Cpk - Within Subgroup Variation is always smaller than Total Variation Capability, Accuracy and Stability - Processes, Machines, etc. 18
M Is a Significant Aspect always a Significant Aspect? Miscellaneous Environmental Standards and EMS Related Discussions 13
Z Isn't 'Improvement Always' a meaningful work? Misc. Quality Assurance and Business Systems Related Topics 3
Q CAPA (Corrective Action and Preventive Action) after Correction always? Nonconformance and Corrective Action 10
Q Corrective Action - Disposition always Correction? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q Scrap + Replacement always? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Why Cp should always be greater than Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 7
P Must Key Product/Process Characteristics (KPC's) always be variables? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
R Does IVD 510k application always goes to pre-IDE and IDE process? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R Why is the first bid quotation always rejected Coffee Break and Water Cooler Discussions 7
W Internal Auditor always on duty? Internal Auditing 8
Q Purchasing mapped if not always participate? Is Purchasing a Support System? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Is Six Sigma always Green? The Impact of Six Sigma Six Sigma 8
E Correction and Corrective Action - ALWAYS DOCUMENT BOTH Nonconformance and Corrective Action 13
M Special Cause Variation ALWAYS human related? Six Sigma 6
G Is Medical Grade Gas always a drug? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
M Do nonconformances always result in corrective action ISO 13485:2016 - Medical Device Quality Management Systems 67
L FMEA - Should a severity of 9 or 10 be always followed by recommended actions? FMEA and Control Plans 2
Marc Acronym FORD Acronyms (aka 'Initialisms' - Not Always True Acronyms) List Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 17
S Welding - Is welding always a special process per ISO9001:2000 Clause 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
Icy Mountain Answering a Finding that is Not? Work instructions are not always followed IATF 16949 - Automotive Quality Systems Standard 9
Jim Wynne Another reason why things always go wrong Coffee Break and Water Cooler Discussions 14
A Customer is always right Coffee Break and Water Cooler Discussions 34
H Does a Nonconforming Material Report always generate a Corrective Action? Nonconformance and Corrective Action 9
H 7.6 investigation - Do most operations always record the gage# on all test reports? Records and Data - Quality, Legal and Other Evidence 8
Claes Gefvenberg Is the customer always right? Personally, I strongly disagree. Philosophy, Gurus, Innovation and Evolution 47
D Production before Quality - Is the Customer Always Right? Misc. Quality Assurance and Business Systems Related Topics 9
