P
1.1.1 The Corrective Action Coordinator will issue rework instructions as necessary. The supervisor of the area is responsible for carrying out the disposition of the product according to the NCR form.
a) Rework is sent to the appropriate process. Corrected product or material is subject to all product inspection required by the process to demonstrate conformity to requirements.
b) If disposition is “use as is” the item is placed back in the process.
c) When completed the NCR form is Transferred to QC to be filed and entered into the Nonconforming Material database.
d) In the case of customs all NCM will be scrapped and will be exempt from all procedures.
e) Scrap is logged on the Scrap report F-830-002 Scrap Report
5.21.2 If Nonconforming Product is detected after delivery or use, Quality Control or Management will contact the customer and take appropriate remedial action, and initiate a corrective action request form (F-852-001).
1.3 Sheet cut at the shears shall be scrapped without documentation as long as it is not due to operator error. Example (wrong cut lengths or as long as it has not been forwarded to the next step of process.) Material cut from drops will be exempt also, as long as it has not moved to the next process.
1.4 Test pieces will be allowed in areas as long as they are tagged not for production use. These parts may be used for machine set up only. (Bender presses, etc.) These parts shall be marked as set up part and then may be thrown in scrap bin.
That is a section of our Non Conforming procedure...1.1 D and 1.3 are the parts I think may be called into question.
