AMS 2750E - Digital Instrument Calibration Accuracy Requirements
Dr_bld
Hello, I have a question regarding digital instruments calibration accuracy.
In our company we have new device (cryo chamber) for deep freezing and tempering. Class 2, Instrumentation type B. Temperature controller as well as over-temperature controllers (2 instruments for min and max temperature) have accuracy of 1 degC. According to AMS 2750E Table 3 note 4, the sensitivity of those instruments is correct. However, in the Table 3 in line “Digital instrument” it is stated that those instruments have to be calibrated with accuracy of ± 2 degF (±1.1 degC). For our processes we use Celsius scales that means that we have to calibrate our instruments with accuracy of </SPAN>±1.1 oC. According to that all of instrument have to operate with accuracy of 0,1 degC. Is my way of understanding of AMS2750E standard correct? I my point of view our instrumentation do not meet standards requirement.
Is it allowed to change the calibration accuracy to 1 degC (make it more restrict, but with lower accuracy)?
dwperron
If I understand correctly, you have a controller that you calibrate to 1°C accuracy. The Table 3 minimum accuracy requirement for your controller would be no less than ±1.1 °C, so your controller meets the minimum accuracy requirement. No problem there.
As for changing your calibration accuracy to 1 °C, in the heading for Table 3 under Calibration Accuracy it refers to Note (1) which reads "Instruments of equivalent or greater accuracy are acceptable" so you are fine there.
Q AMS 2750E Sensitivity Requirements Field Test Instrument AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q AMS 2750E System Accuracy Test (SAT) Frequency AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M SAE AMS 2750E Relocation Hot or Cold Recording Sensor Manufacturing and Related Processes 1
S AMS 2750E Heat Treat Furnace System Accuracy Test SAT Report question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q AMS 2750 E or F Continuous Furnace TUS Data Collection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J AMS 2750 E Clause3.5.17.13 TUS Pass/Fail Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R DFARS Compliance - Purchasing Aluminum Alloy 7075 -T73511 per AMS-QQ-A-200/11 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M SAE-QQ-A-250/11A has been superseded by SAE-AMS-4027N AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Salt Bath Probe Style SAT requirement Waiver per AMS 2750 Rev E Section 3.4.7 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E AMS-H-6875 compared to MIL-H-6875 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Could Fluke thermometer be used in SAT test in accordance to AMS 2750 ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
B Urgent Help With Calibration Issue AMS 2750 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Douglas E. Purdy Relation of Aluminum 6061-0 to AMS 4025 or AMS 4027 Various Other Specifications, Standards, and related Requirements 3
B Inhouse Calibration Plus TUS in accordance with AMS 2750 rev E? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 31
S AMS 2750 - Instrumentation Calibration Requirements Manufacturing and Related Processes 12
L Calibration Uniformity Procedure for AMS 2750 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S AMS 2750 rev E - Changes Detailed - Work In Progress Manufacturing and Related Processes 13
S SAE AMS 2750 rev E - Changes Matrix? Manufacturing and Related Processes 13
L Determination of AMS 2750D Furnace Classifications AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B AMS 2750 Furnace Instrument Calibration Operating Range AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
C Nadcap AMS 2750 Data Storage - I'm looking for pre-packaged software AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M How are ISO-17025 and AMS-2750 related? ISO 17025 related Discussions 2
N AMS 2750D Process Audit Check Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M What other standards meet AMS 6415? Various Other Specifications, Standards, and related Requirements 1
C Furnace Classes in relation to AMS 2750 to determine Calibration Interval Calibration Frequency (Interval) 2
K Pyrometry Question - Furnace and Oven Instrument Calibration IAW AMS 2750 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
P Standards Subscription - Online web site that provides AMS, NAS, SAE etc, standards Various Other Specifications, Standards, and related Requirements 1
S SAE AMS 2175 Radiographic Report of Casting Other ISO and International Standards and European Regulations 8
G S30100 steel bar spec - related specs, ASTM or AMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J AMS 4218 Spec, Equivalent AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G Understanding AMS 2750D compliant calibration report - items under 3.2.6.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
G AMS 2750 - Tell me what troubles, specifically, you have had with AMS 2750 Various Other Specifications, Standards, and related Requirements 4
D SAE AMS 2750D - Pyrometry - Heat Treating procedure wanted Reliability Analysis - Predictions, Testing and Standards 12
A AMS Specification QQ-N-290 - What does the class 1, Type IV (QS) mean? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Ams 7875(pwa53-5) Various Other Specifications, Standards, and related Requirements 5
D CQI-9 vs. AMS 2750D - Are there discrepancies? Various Other Specifications, Standards, and related Requirements 1
Q Need New AMS 2750 Compliant Temperature Data Logger Manufacturing and Related Processes 8
D SAE AMS 2750D - Pyrometry - Heat Treating - Does anyone know of a good class? Training - Internal, External, Online and Distance Learning 5
D AMS 2750C - Guidance under AMS 2750C for when a furnace fails a uniformity survey? Various Other Specifications, Standards, and related Requirements 2
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
DuncanGibbons Technical Data Package vs Digital Product Definition APQP and PPAP 0
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
A Digital Timer Calibration Requirements General Measurement Device and Calibration Topics 3
A Feedback of typical maintenance problems with LMI digital probes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
O Mitutoyo Digital Caliper to PC USB question General Measurement Device and Calibration Topics 2
J Integrity of electronic digital records - Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
C Teaching Metrology - Vernier vs Digital General Measurement Device and Calibration Topics 8
M Informational TGA presentation: Digital Devices Webinar 3, 20 June 2019 Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – Digital Health Update: Mid-Year Update on Software Precertification Program Medical Device and FDA Regulations and Standards News 0
