AMS2750E - Noble metal as a Load sensor
CHT
I am seeking a clarification on SAT vs Load sensor usage on instrumentation type "B"
Refer to the type B instrumentation, the additional load sensor will be performed.
However, if we select Type N,K sensor which will be restricted the usage per 3.5.1.3 defines to use the sensor at 1260 deg.C = 1 time
At the time we do the SAT - it is counted as 1 use. That means we cannot operate the furnace at that temperature? How can we comply this
Anyway, does the noble metal (Type R,S) load sensor be way to comply this requirement? because there has no restriction for noble metal non-expendable sensor, but It is quite rare to find people using type S as load sensor.
R SAT (System Accuracy Test) temperature according to AMS2750E AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S AMS2750E Offsets procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A Critical Characteristics - Sheet metal stamping APQP and PPAP 9
T Accessible metal parts connected to secondary ground IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Metal parts bonding/grounding on Class II, internally powered with functional earth? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J ISO 13485 for Metal Finishing Medical Device and FDA Regulations and Standards News 5
A Metal Enclosure Connected to PCB Ground for ESD Reasons IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Lighting Standard for Metal Processing Inspection Manufacturing and Related Processes 4
K Quality Control/Assurance in the Metal Industry Quality Tools, Improvement and Analysis 10
M 'Active' device? Software/laptop with attached camera 'looking' at passive metal probe EU Medical Device Regulations 3
J Raw material certificates - CC - Safety products - Sheet metal stamping IATF 16949 - Automotive Quality Systems Standard 1
A Literature review/HACCP validation of metal detection Food Safety - ISO 22000, HACCP (21 CFR 120) 0
M Informational US FDA paper – Biological Responses to Metal Implants Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final guidance – Metal Expandable Biliary Stents – Premarket Notification (510(k)) Submissions Medical Device and FDA Regulations and Standards News 0
Q IATF rule for single site - Ingots from scrap metal recycling company IATF 16949 - Automotive Quality Systems Standard 0
V Thinning percentage in sheet metal forming per SES (Suzuki Engineering Standard) Manufacturing and Related Processes 1
F AS9100 D - Verification of purchased product - Sheet metal and aluminum extrusion stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F MOPP in battery powered device with metal enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Error proofing ideas sheet metal punches Manufacturing and Related Processes 8
D IEC 60601 Defibrillation protection test - Metal foil IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Ron Rompen Crack testing of powdered metal parts General Measurement Device and Calibration Topics 4
A Test method for presence or absence of hexavalent chromium on a metal coating RoHS, REACH, ELV, IMDS and Restricted Substances 4
R Statutory/Regulatory for NACE Code 25.9 (Manufacture of fabricated metal products) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Industry Standards - Sheet Metal a Machine Shop Manufacturing and Related Processes 1
J Measuring an Untrue Radius - Metal Stamped and Formed Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
S Metal Radiographic and Ultrasonic Testing - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
J Receiving Inspection for Metal Strips & Wires Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
V Root Cause help needed - Sheet metal breaking at press Problem Solving, Root Cause Fault and Failure Analysis 9
Ron Rompen Help with Corrosion (Humidity) Testing Procedure - Sintered Metal Steel Parts Manufacturing and Related Processes 9
C DFAR 252.225-7008 - Is aluminum, say T6061, considered specialty metal (i) steel? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Ron Rompen Sintered Metal Machined Parts Rust Removal Methods Manufacturing and Related Processes 8
J Internal PPM's in a medium sized metal stamping plant Quality Manager and Management Related Issues 6
G Metal Scale (SIP-Societe Genevoise) change in size over time? General Measurement Device and Calibration Topics 8
G Metal Stamping Process Audit Questions Manufacturing and Related Processes 8
B Mitigation of emission of flames, molten metal, poisonous or ignitable substance IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N Control of Metal Plating Baths - Contamination from base metals Service Industry Specific Topics 4
T Technical automotive metal stamping cliffnotes needed! Training - Internal, External, Online and Distance Learning 4
L Caliper Calibration Standards - One for CNC and one for Sheet Metal? General Measurement Device and Calibration Topics 9
E Composites - Metal Bond - Removal of excess film adhesive Manufacturing and Related Processes 1
P Validation of Class I Metal Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 3
A MIL STD 105 D or ISO 2859-2? Receiving Metal Sheets Quality Tools, Improvement and Analysis 6
P Testing Zinc Coating on Expanded Metal Manufacturing and Related Processes 7
L Calibration of Metal Rulers General Measurement Device and Calibration Topics 13
M Supplier Nonconformances - Key Points to ask a Metal Stamping Supplier Supplier Quality Assurance and other Supplier Issues 7
B Plating Shop - Forums specifically related to the plating / metal finishing industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
H Determining Takt Time in Metal Stamping Lean in Manufacturing and Service Industries 9
B Determing Machine Capability in a High Mix, Low Volume Sheet Metal Shop Manufacturing and Related Processes 4
T Electrical Surgical Tool with Big Metal Applied Part IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
