AMS2750E Offsets procedure
speck
I would like to see if anyone can shed light on how they "account for and reintroduce any intentional offsets" per AMS2750E 3.2.4. I perform all our internal SAT's and TUS's but we have never used offsets but now that we have class 2 furnaces I find that the simple thermocouple or instrument error can put me outside of the ?2?F tolerance unless I use the offsets. I need to make a procedure to document the use of offsets and not sure what the above requirement is asking, (reintroduce). My TUS and SAT forms/reports are very thorough so I can easily amend them. Any help would be greatly appreciated. Thanks
MTProcessing
We document for each furnace:
  • Calibration offset: Anything our instrument calibration technician (outside source) needs to put in. There are no limits here.
  • SAT offset: We put this in to make SATs pass. Limited to ?5?F for class 2 furnaces.
  • TUS offset: We put this in to center our TUS results. When doing an SAT, this amount has to be removed from the instrument reading before comparing to the probe reading. Limited to ?5?F for class 2 furnaces. Independent of the SAT offset.
  • Total instrument offset = Cal + SAT + TUS and needs to be the offset actually programmed into the instrument at all times (including when doing surveys).
That particular paragraph 3.2.4 is not very clear. It's talking about both manual (operator programs the furnace for a different temperature than the router calls for) and internal (programmed into the controller). It mentions calibration, SAT, and TUS offsets, when all of these are treated differently than each other. I can't really make out which part is talking about which kind of offset. Possibly "reintroduce" is referring to putting the TUS offset back after removing it to do an SAT. (Although we just remove the TUS offset mathematically on the SAT form and don't mess with the instrument programming).
I have also heard of companies specifying "half special limits" tolerance on all their thermocouples to try to avoid the need for offsets. I'm told the price difference is not very large compared to normal "special limits" tolerances.
speck
Compliments to you for your help! I have a good direction now and will also look into 1/2 special limits specification on my T/C's. This is probably what I need to do most because I do not necessarily need to add offsets for the instrument calibrations, SAT or TUS but when I use the same thermocouple lot for control and SAT and the correction factor is 1.7?F at 250?F and 3.9?F at 1200?F (?.4% allowed) it puts me out of tolerance obviously when I can't add in the 3.9?for the controller T/C error.
Which brings me to my final question on this....? If there are different calibration errors for different temperatures on the instrument calibration report, SAT report or calibration certificate, how do you enter 1 offset without having the operators enter the correct offset based on the set temperature; or can avoid this? This would create a possibility for many compounded errors in the shop by having to independently calculate the proper offset for each temperature.
MTProcessing
If there are different calibration errors for different temperatures... how do you enter 1 offset without having the operators enter the correct offset based on the set temperature?
The only requirement to account for all certified errors / correction factors is on the SAT thermocouple and thermometer when doing an SAT, and on the TUS thermocouples and logger when doing a TUS. The furnace instrument and thermocouples do not have to be corrected for any of their errors.
I agree that having operators enter different offsets based on the set temperature, while allowed, introduces more error possibility, and I have so far :cfingers: avoided needing that. We've been able to get all the TUS and SAT to pass at all temperatures with a single offset. (Well, a multi-component offset, but the "total instrument offset" is a single number for each of our furnaces regardless of temperature.)
speck
Thank you very much again for your time. The direction is most appreciated. I believe I can take a stab at writing the procedure now and will also be ordering 1/2 special limit T/C's.
Hi can I check what is the purpose of tus offsets (&purpose of centering tus results)? Isn't a temperature as accurate and close to actual conditions better?
fmp
A TUS offset is used to account for the fact that the control sensor is not actually placed in the center of the control volume. By performing a TUS you can document the characteristics of the control volume with regards to high and low temperature at the extremities of the volume and their relation to the center of the volume. You actually don't want an accurate reading of conditions at your sense point to drive your controller unless your sense point is very close or in contact with the material being processed, generally doing so is impractical so a TUS offset is used instead.
The purpose of a TUS offset is to make the controller control the actual mid-point of the control volume's temperature range so that the absolute deviation of the high and low temperatures are as close to the same value as possible.
For example an TUS reveals that the high deviation is +8°F and the low deviation is -4°F. The deviation to the center is -2°F. this oven is ±8°F
Correcting for the center gives a +10°F high -2°F low and 0°F center deviation. this oven is ±10°
Correcting for the high and low areas gives +6°F high -6°F low and -4°F center deviation. giving an oven that is ±6°F
hope that explains it.
C AMS2750E - Noble metal as a Load sensor AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
B Determining SAT Offsets vs TUS Offsets per SAE AMS 2750E AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
Q Tool Wear Control Charts to Help Control Machine Tool Offsets Statistical Analysis Tools, Techniques and SPC 6
S Article 22 Procedure Pack Labelling EU Medical Device Regulations 4
N EU MDR - Applicability Article 22 Systems and Procedure Packs CE Marking (Conformité Européene) / CB Scheme 4
M Example of statement for procedure pack MDR Article 22? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
R Procedure, Frequency and Acceptance Criteria for Replicate, Recalibration, Before-After and Intermediate Checks ISO 17025 related Discussions 8
B FDA-Medical Device Reporting (MDR )procedure compliant with 21CFR section 803 US Food and Drug Administration (FDA) 0
M MDR - Is a formal GSPR Procedure required? EU Medical Device Regulations 20
Moncia Production Planning procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
L Purchasing procedure and workload ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Roles and accountabilities procedure? ISO 13485:2016 - Medical Device Quality Management Systems 9
K Procedure equals a process? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 24
M EU MDR - RA procedure for EU EU Medical Device Regulations 5
F Procedure for Device End of Life/Obsolescence Other Medical Device and Orthopedic Related Topics 3
A MAH license transfer (medical device registrant) procedure in Indonesia Other US Medical Device Regulations 0
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
J Manufacturing procedure / work instruction depth ISO 13485:2016 - Medical Device Quality Management Systems 12
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 2
U Product Lifecycle Procedure Guidance Design and Development of Products and Processes 7
V Datron 4707 or 4708 33K, NAVAIR or TB cal procedure General Measurement Device and Calibration Topics 1
R MDR Article 22: Systems and procedure packs Other Medical Device Regulations World-Wide 12
I Containment procedure for parts after a power outage. IATF 16949 - Automotive Quality Systems Standard 1
F ISO 17025:2017 Format for Procedure and Records Document Control Systems, Procedures, Forms and Templates 3
H Statistical Techniques Procedure - What should be included Document Control Systems, Procedures, Forms and Templates 4
E AS9100 installtion procedure AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
S Procedure on Privacy Policy in the ISO 13485 quality management system ISO 13485:2016 - Medical Device Quality Management Systems 3
K 820.200 Servicing Procedure - Our system (because there is an API involved) is classified as Class 3 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
D Substance of concern (SOC) management procedure wanted Reliability Analysis - Predictions, Testing and Standards 2
M Informational TGA Consultation: Proposed clarification of the regulatory requirements for medical device systems and procedure packs Medical Device and FDA Regulations and Standards News 2
M Different procedure templates for different standards - We have two different management systems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
N Validation procedure, Major NC CAP - Equipment Validation process is not effective ISO 13485:2016 - Medical Device Quality Management Systems 5
T Something between a manual and a procedure? Document Control Systems, Procedures, Forms and Templates 9
R ISO 13485 Software validation procedure and Quality Objectives Monitoring wanted Document Control Systems, Procedures, Forms and Templates 1
L I'm looking for Translation Procedure Guide MEDDEV 2.5/5 Rev.2 (NOT Rev.3) CE Marking (Conformité Européene) / CB Scheme 0
D Risk Assessment Procedure in accordance with ISO 17025:2017 ISO 17025 related Discussions 5
F Internal Audit - Procedure example Internal Auditing 5
J ISO 17025 - Please share a sample procedure for monitoring the validity of results ISO 17025 related Discussions 1
U Own Procedure was not effectively implemented Problem Solving, Root Cause Fault and Failure Analysis 3
M Procedure or Specification For Extending Gages Calibration Calibration Frequency (Interval) 2
A Process Control / Control Charting Procedure Capability, Accuracy and Stability - Processes, Machines, etc. 1
R Real Example of a currently marketed Procedure Pack CE Marking (Conformité Européene) / CB Scheme 1
DuncanGibbons Additive Manufacturing/3D printing for aerospace (certification procedure) AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
A Certification procedure for OEM/PLM collaboration in the medical device industry in the US - Who bears the regulatory responsability? Other US Medical Device Regulations 10
B AS NZS 5131 - Procedure on Concessions with focus on Steel Fabrication Document Control Systems, Procedures, Forms and Templates 0
alonFAI Please share a medical device company NCMR procedure Other Medical Device Related Standards 4
M Informational MDCG 2019-3 Interpretation of Article 54(2)b – Pre- market clinical evaluation consultation procedure with the involvement of expert panels Medical Device and FDA Regulations and Standards News 0
M Scrubbed version of a labeling procedure that is MDR compliant wanted EU Medical Device Regulations 3
